Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
If you are having problems with your gas dryer not heating
the most common problem is that the ignitor goes bad. Even though it glows
sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different
things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Hello - Typically error code AD indicates that the Auto Dry option has been selected. Using no heat in any Auto Dry cycle will result in long drying times and/or wet loads at the end of cycle. I would suggest selecting other option or resetting the unit. You may either unplug it or flip the household breaker off for approximately two minutes. Restart unit, select a normal cycle and verify if it will heat. If the dryer does not heat the unit it could possibly have a faulty heating element, blower assembly or a communication problem with the control panel. Contact a professional to move forward accurately.
Hello Patty Hanna - Typically error code AD indicates that the Auto Dry option has been selected. Using no heat in any Auto Dry cycle will result in long drying times and/or wet loads at the end of cycle. I would suggest selecting other option or resetting the unit. You may either unplug it or flip the household breaker off for approximately two minutes. Restart unit, select a normal cycle and verify if it will heat. If the dryer does not heat the unit it could possibly have a faulty heating element, blower assembly or a communication problem with the control panel. Contact a professional to move forward accurately.
