Question about GE JKP45 Electric Double Oven
Front panel with the clock settings is dim.
Can the display be brightened on the clock area as it appears dim.
Otherwise how does one replace the light?
  • 54 Answers
The only way to brighten is to replace the ERC or computer
Posted on Jul 03, 2008
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
DIM DISPLAY ON GE PROFILE WALL OVEN
when they are dim like this,it needs replacing as its a driver chip that drives the readout and illuminates it you can send in the board for rebuild or purchase outright,as they dont supply any component specs to repair the control panel
Feb 03, 2013 | Ovens
I have a Frigidaire Range model PLES389DCC, it's top cooking function well, but display panel PF show, the clock start from 12:00 (after off/on circuit breaker) and kicking. I have order the control panel...
The clock may be set for 12 or 24 hour time of day operation.
The clock has been preset at the factory for 12
hour operation. When the range is first plugged in or when
the power supply to the range has been interrupted, the
timer in the display will flash and PF (power failure) will
appear in the display.
To set the clock:
1. Press Clock . "CLO" will appear in the display.
2. Example for 1:30. Press the numbers 1 3 0 to
set the time of day to 1:30. "CLO" will disappear
after 4 seconds and the clock will start. Or you may
press Start. "CLO" will disappear and the clock will
start.
Nov 29, 2010 | Frigidaire Ovens
The control panel light is very dim. It is hard
we had the same problem....my husband removed the panel and I clean the inside glass panel & it resolved the problem. It is a convection oven and steam comes out just below the clock area which I believe causes the problem.
Jul 12, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Display light faded and now gone
Supposedly the electrolytic capacitors on the display board need to be replaced. See: http://applianceguru.com/forum1/18842.html
Jan 15, 2009 | Thermador SC302T Electric Double Oven
Temp/clock display faided
its the display theat is fading away. I've haad meter's do the same thing after awhile and there's nothing you or I can do. Thanks for using Fixya
Dec 23, 2008 | Thermador SC302T Electric Double Oven
GE JKP45 Electric Double Oven Logo
570 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
