Question about Amana Heating & Cooling
My air conditioner just quit working. how do i run my own diagnostic or just get it running again. i switched the breaker on and off to try and reset it but it didn't work this time.
  • 139 Answers
First does the furnance blower work ? go outside to condensor unit .their will be a dissconnect box connected to the unit. open door to dissconnect pull out connector or fuse holder to see fuses check with ohm meter replace the bad one time delay fuse s only p/s turn the breaker off before pulling dissconnect out please be safe good luck
Posted on Aug 23, 2010
Had a short power outage now the unit will not run. breaker ok and 234 volts to outside unit but inside unit will not come on. is there a reset or something
Try turning the unit off at thye meter box or the isolator switch out next to the outdoor unit of the air con. Leave off for 15 minutes and then switch back on again. Some Air cons get screwed up with power surges... Leaving off at the mains for a while often resets them. If the air con was running at the time the power went off, it may have damaged one of the electronic boards... Do you get any flashing lights or displays showing what could be an error code ??
Jul 16, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
My coleman Mach Rv air conditioner with built in heat strip keeps tripping it's internal circuit breaker when running for any length of time. Just replaced heat strip with new one experienced same issue. I...
There should be an overload protection device in series with the low voltage wiring(t-stat wiring) Is it resting on the heat strip or too close to it? It is a saftey device to shut off the heat strips if the fan quits or a fire in the heat strip section. check that or by pass it, if it stays running then ur thermal protector is bad, couple bucks at the parts house.
Nov 06, 2010 | Coleman Mach III Air Conditioner
It just quit running. i flipped the breaker on and off to reset it but didn't work.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 22, 2010 | Amana Heating & Cooling
Ac quits and then i reset breaker at rv park; voltage varies from
Incoming voltage fluctuations appear to be your problem. 94 volts is not enough to run that AC without causing problems. 114 volts will be o.k.
Remember, when voltage goes down, your amperage draw goes up. That will trip the breaker, and eventually weaken it if it happens too often and it will start tripping at even lower amperage's. Low voltage also will shorten the life of the components. So basically when running at 115 volts, the circuit will handle it, but when you get as low as 94 volts, it will trip that breaker due to higher amperage draw.
Jul 06, 2010 | Dometic Rooftop RV Air Conditioner
A/C stopped running
Check relay to make sure it hasn't overheated. Check power to compressor to see if it is getting any power.
Jul 20, 2009 | Dometic Rooftop RV Air Conditioner
Location of reset switch
The only reset switch on the air conditioners if the actual 120Volt Circuit Breaker located in your coaches breaker panel. Locations vary depending on unit type. If that does not work, you have other issues.
Jun 30, 2009 | Coleman Heating & Cooling
I have a ruud achiever uaka outdoor central air system, the first time i ran it this summer it tripped the breaker. It stayed on for a good hour as it cooled the house to the desired temp. then it turned...
start components are likely bad causing comp to pull high amps tripping breaker careful resetting the breaker they can explode stand off to the side
you need service all so have preventive maintenance done on the unit
Jun 19, 2009 | Ruud UAKA037 Air Conditioner
Air conditioner will trip breaker when trying to cycle back on
The compressor motor , once warm is grounding out due to wear and is going bad.Have the compressor replace while it is still clean is cheeper and easier that doing it after a burn out,which  will eventually happen,if the compressor is tripping the brreaker as I suspect..
Apr 22, 2009 | Dometic Rooftop RV Air Conditioner
Electric Furnace Trips Breakers
it is normal for a breaker that is run right on the edge (50 amp and your furnance to use 45) to get weak after a while . the first thing you should do is change the breaker with the same type and amp rateing . it should take care if it
Jan 16, 2009 | Heating & Cooling
Heating & Cooling Logo
83 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
