Question about Garden
Need a manual for a mountfield Quantum XM 35. petrol lawn mower
4 Suggested Answers
SOURCE: I have a Mountfield lawn mower model Hp 474 and
mountfield will email you one if you go on there website www.mountfield.com
Posted on Mar 22, 2010
  • 3 Answers
SOURCE: Webb Diplomat 350 Petrol Lawn Mower stops running 10 minutes
The 'DIPLOMAT' series of WEBBs is bad news, its NOT a WEBB! Webb were swallowed by qualcast-atco-suffolk, who dunped Webbs tooling, & dressed up punches & commodores in thin disguises, dumped the briggs & stratten engine for their own alloy job, & charged a rip off premium for the Webb decals!
The qualcast suffolk alloy engine suffers from a WIPAC electronic ignition unit. As it gets old, it fails, sometimes completely, sometimes as it warms up. Once cool, it works for a while again.
Not too hard to replace, but hard on the wallet, £69 genuine, £40 fake! On the whole its not too bad an engine if cared for & oil changed often. better to look on ebay for a cheap used HONDA engine & transplant! R-E-L-I-A-B-L-E !............I did! ( £35 honda gc series, 5,5hp! )
Posted on Apr 02, 2010
Testimonial: "Thanks very useful information.....Many Thanks"
hunter19_46m
  • 7482 Answers
SOURCE: I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
Why does my Mountfield Petrol powered lawn mower cut off instead of idling while I empty grass cuttings?
what engine does it have, how old is it and does in not have a bar you have to hold in to start/stop the engine?
Mar 07, 2015 | Garden
My mountfield hp164 petrol mower starts but wont run smoothly even when the engine is warm it is constantly idling erratically
Check sparkplug ie remove and clean. Set gap normally 1mm. Check s/p lead has firm connection. Check manual for correct fuel requirements. Other wise take it to the mower repair shop. It's not worth your time to muck around with it. Too frustrating!
Apr 17, 2013 | Garden
1997 Mountfield 21" Emporer Petrol
check the FUEL plug. when unscrewing the fuel bowl it is the nut holding the bowl on. It sounds like it may be clogged
Jul 17, 2011 | Garden
I am looking for a Mountfield HP 470 Lawnmower instruction manual
I have a Mountfield HP 470 Petrol Mower 8 years old and I have started it the for the first time and it runs but seems to be hunting or missing as I cut the lawn.
Mar 24, 2011 | Garden
I have a Mountfield bvs153 petrol mower. The
It fails after it has 10 minutes to warm up right?
I think you should run it till it fails and then test it for spark.
My guess is that your coil is going bad and heat just triggers the failure. After a while even cooling down wont help.
The good news. If you need to replace the coil its a pretty simple job that can be done with a few hand tools and a new coil. It shouldnt be too expensive either. 25-35 dollars for a new one if your shop around online or go to Ebay.
The only thing special you need to do once you have removed the recoil cover and removed the old coil is to take a piece of thin cardboard *(I actually recommend the box the coils usually come in. But a playing or business card will do) Put this paper between the coil and the flywheel to set the coil gap. Tighten on the screws and then pull out the paper. Put the recoil cover back on and you are done!
Good luck and be careful.
Oct 12, 2010 | Poulan "" Push Mower
Mountfield mower manual
it seems this mower is made by Homelite with the Mountfield name on it.
May have to see if you can locate a source for homelite to find this manual.
cheers
Sep 26, 2009 | Garden
I need onwers manual for Mountfield Laser Delta mower
Have you Contacted Mountfield about a Manual? You can Contact them Using the Options at this Site Addy;
http://www.mountfield-online.co.uk/contact?jssCart=13a24ca4de2a2610f7213de8a0539ffb .
For an Engine Manual you can Contact www.outdoordistributors @ 877-707-2787 or Contact Tecumseh @ 800-558-5402.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
1,294 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
