Question about HP Pavilion dv6000z Notebook
Computer with vista 7 boots up to a black screen with a flashing underscore cursor. I can only use the f10 key. what do i need to do or where do i start to fix this problem.
    Problem Solver:
  • 10 Answers
First Make sure to Remove all external devices and media. Be sure to check the optical drive, flash memory slot and try once again to boot to BIOS by tapping f10 make sure you start tapping the f10 key as soon as you power on the NB if boot to BIOS then do a BIOS default by pressing f9 and then f10 to restart the NB press enter if prompted
check if the issue is resolved or if you not able to get into BIOS by f10 then run the Hard drive test from Diagnostics then is F2
power on the NB tap f2 to boot to Diagnostics and run self test for hard drive and if the fails then hard drive needs to be replaced or if the test passes and still issue is not resolved
then Re-Seat the Memories on then if still issue not resolved
then try F11 recovery this will format the Hard drive an install the fresh copy if operating system still same issue or unable to run recovery then contact manufacturer
Posted on Aug 23, 2010
Why is there a black screen on hp pavillion windows 7 "boot mnr missing"?
Windows 7 - black screen with blinking cursor
  1. Remove any CDs, DVDs, or memory cards from the computer.
  2. Disconnect all devices from the computer except the original mouse, monitor, and keyboard. Leave the power cord connected.
    1. Restart the computer.
    If it starts normally, start plugging devices in one at a time until you find one that may be causing the black screen
    1. Press the F10 key repeatedly during the first startup screen until the Entering setup message displays.
    2. Press the F5 key to restore the defaults. Use the arrow keys to select YES , and press Enter .
    3. Press the F10 key to save the changes and exit. Use the arrow keys to select YES , and press Enter .
      The computer restarts.
    4. If a Windows Error Recovery screen displays when the system restarts, select Start Windows Normally , and press Enter .
  • If this doesn't resolve it, follow the procedure below.
  • Aug 17, 2014 | HP 5188-7103 Compaq Motherboard Gl8e...
    How can i fix my laptop cursor's blinking
    FIRST:
    When your computer is booting up you have the option to press F2 or F12.
    PRESS F2 -Set Up
    When your in the Set Up go down to Boot Device Configuration(BDC)
    Now under Hard Disk Boot Priority
    You Will see first boot device
    second
    third
    and boot other device
    FOR THE FIRST BOOT DEVICE SELECT "HARD DISK"
    After you have made the first boot device hard disk press F10 TO SAVE and RESTART
    These are the steps to follow if you have Windows Vista and are dealing with a Black Screen with Blinking underscore. :)
    May 16, 2014 | Lenovo 3000 N200-0769
    Dell latitue D610 stuck on black screen with a blinking cursore.. help?
    First, try and boot into safe mode by powering off your computer then powering it back on and tapping the f8 key, after that you should see safe mode and other options below it, click the first option which is safe mode, then go into your start menu and go to your system restore which in Windows 7 and Vista is located in accessories and then system tools, then choose a restore point earlier than the date you are on. This is a temporary fix and you will need to get a virus removal done asap. Hope this helps.
    Live Technical Support
    My Youtube Channel
    Mar 24, 2013 | Dell Latitude D610 Notebook
    Why do not restored disks work for Acer Aspire M1100?
    Turn off the computer Henry then turn it back on and hold down the alt key and tap F10 and make sure you remove any disks from the CD drive.
    It would appear that the hard drive is having boot sector issues.
    http://www.ezsystemrepairs.com
    Nov 08, 2012 | Acer Aspire M1100-U1402A Refurbished AMD...
    EMachines black screen flaching underscore??
    The problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
    Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
    Apr 26, 2012 | Computers & Internet
    Dell Inspiron 1420 will no longer boot
    you need to enter setup by tapping one of the f keys or the delete key. i'm not sure which it is for this model. when you enter the bios setup change the boot order to boot to the dvd first. hit f10 and save the change then reboot with your install disk in the drive. it should start installing.
    Sep 06, 2009 | Dell Inspiron 1420 Notebook
    Computer won't boot Windows Vista. Screen goes black with cursor arrow.
    In this case you have to do the PC restore . you can do that in dell machines by shutting down the machine and when it is coming back on just HOLD DOWN THE CTRL ket and the START HITTING f11 key in this case you will lose the data which you have the on the c drive but this issue will get resolved .
    Else you can try to restart in the safe mode with networking and then go to the system restore and then select the bold dates in which you have idea you system was working fine . selct the date and then do the system restore . In this case you will not lose the data but you will lose the updates which you have done after that date .
    in both the cases system will work .
    Mar 25, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
    Black screen
    Is your HDD LED flashing? -Try pressing F8 on startup to show the boot menu option of your OS if it is Windows. If it does appear use Safe Mode first. If not successful try re-installing your OS.
    Sep 14, 2007 | Dell Dimension 4700 PC Desktop
    HP Pavilion dv6000z Notebook Logo
    97 people viewed this question
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
