How to remove rear door panel on 2003 Jeep - Audio Players & Recorders
  • 1,188 Answers
I am assuming you are asking about the 2003 Jeep Cherokee, these are the instructions for the Cherokee, if not, please repost your question specifying which Jeep you have.
Remove all screws securing the interior door panel on. There is a screw on the top portion, and two in the handle.
  • 2 Gently pull on the interior door panel to release the plastic clips that fasten the panel. Use caution to avoid damaging the plastic clips.
  • 3 With the door panel loose, release the two wire connections to the window- and door-lock switches. You must also remove the lock-mechanism poles.
  • 4 Remove the four screws holding on the speaker. Remove the wire connector and set the speaker aside.
  • 5 Remove the window seal by gently pulling. Make note of how each wiring harness is fed through the door panel.
  • 6 There are two clips that secure the window to the track. Using needle-nose pliers, gently pull the clips off of the window. Carefully lift the window out of the track and set it aside.
  • 7 Remove the motor from the track system by removing the three bolts holding the motor to the track. Remove the unit from the door and place it on a flat surface.
  • 8 Remove the lower cable guide by pressing on the tab with a screwdriver and releasing the guide assembly. You must also remove the window-guide mechanism. Make sure it is turned so that you can connect the cable in the guide.
  • 9 Install the replacement window motor and guide assembly onto the door panel using the three bolts. Make sure the cables are aligned properly before reinstalling the window in the vehicle.
  • 10 Install all peices in the reverse order.
  • Read more: How to Replace the Window Motor on a 2003 Jeep Grand Cherokee | eHow.com http://www.ehow.com/how_6534717_replace-2003-jeep-grand-cherokee.html#ixzz0xNocSDED
  • Read more: How to Replace the Window Motor on a 2003 Jeep Grand Cherokee | eHow.com http://www.ehow.com/how_6534717_replace-2003-jeep-grand-cherokee.html#ixzz0xNosJL4f
  • Read more: How to Replace the Window Motor on a 2003 Jeep Grand Cherokee | eHow.com http://www.ehow.com/how_6534717_replace-2003-jeep-grand-cherokee.html#ixzz0xNp4YDQ0
    Posted on Aug 23, 2010
    I need to replace rear door speaker cover
    remove panel for access. use panel removing tool (cheap) will save clips/mounts.
    Dec 25, 2013 | 2012 Jeep Compass Sport 4dr SUV 2.0L...
    The rear a/c is making a clicking sound/2003 Lincoln Navigator
    you have a bad blend door actuator the clicking sound you hear is the plastic gears inside it slipping the panels covering rear unit can be removed once removed cut a/c on once clicking starts you should be able to tell which one it is they are about the size of a cell phone usually twoo or three screws holding on to air box and one small electrical connector remove and call ford dealership with part# listed on the actuator and purchase new one these are not available aftermarket that i know of
    Jul 30, 2010 | 2003 Lincoln Town Car
    How do you remove rear drivers side door panel on 2002 jeep
    Several steps in here; review the KJ-2002-Liberty-Service-Manual-PDF-Secc-23-Body (page 128 and next).
    I hope help you with this. Remember rated this help, good luck.
    Sep 04, 2009 | 2002 Jeep Liberty
    How do I remove the door panels froma 2003 jeep wrangler
    You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
    Jun 25, 2009 | 2003 Jeep Wrangler
    How to change tail light bulb in 2003 lincoln ls
    I can provide 2002, don't have 2003. may be similar. please rate as solveed problem if this is what you needed.
    SECTION 417-01: Exterior Lighting 2002 Lincoln LS Workshop Manual
    REMOVAL AND INSTALLATION Lamp Assembly —Rear Removal and Installation
    1. Remove the luggage compartment door trim panel.
      1. Remove the 13 pin-type retainers.
    1. Remove the rear lamp assembly.
      1. Disconnect the electrical connectors.
      1. Remove the nuts.
      • If necessary, install new bulbs.
    1. To install, reverse the removal procedure.
    Mar 22, 2009 | 2003 Lincoln LS
    Need to replace interior driver side door panel on 2003 jeep wrangler, full size doors. how do i get it off?
    to remove the door pannel there is 2 screws and then like everything ells on jeep there are little clips that you need to pull off, try removing the screws and then pulling from the interior pannel
    Mar 21, 2009 | 2003 Jeep Wrangler
    Door panel removal
    there are a few screws you need to remove before pulling off the panel. one is in the inner door handle, the other is behind the inner door release handle and there may be one in the very top left of door panel
    Dec 30, 2008 | 2005 Jeep Liberty
    Remove right rear door panel 2003 Buick LaSabre
    You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
    Nov 02, 2008 | 2003 Buick LeSabre
    480 people viewed this question
     Grubhead
    Grubhead
