Question about LG Goldstar GWHD5000 wall/window Air Conditioner
What maintance do goldstar conditions need? My cooler is not working as well and I cleaned the front filter. I'm not sure what window conditioner I have.
  • 139 Answers
These units need to be cleaned every few years. so take it outside, get your garden hose; and clean the coils on both sides. front an back coils need to be clean. a coil cleaner should be used but good water presure should do fine. try not to get switches to wet. or cover them first. spray coils clean. let dry in the sun. tilt unit to get most water out then blow dry with a fan or just wait till its dry it will work like new after your done.good luck
Posted on Aug 23, 2010
Can you add btu or something to the cooler so it can cool faster?
As much as you and i might like to it is not possible. But you can check you filter and see that its clean that will improve the air flow acroos the coils
Jul 23, 2011 | Goldstar R5050 Air Conditioner
HI there, I have a Goldstar WG1205R 12000 BTU window air conditioner that has no filter, blows slightly cool air and the fan power is very weak for 12000 BTU's How can I improve the performance of...
Sounds like you have a 220 volt air conditioner plugged into a 120 volt outlet.This will cause the conditions you are describing.
Put a filter on it please.
Jul 10, 2011 | Goldstar Heating & Cooling
Where is the drain hole on goldstar window ac my ac keeps dripping water inside the house
Hello, make sure the unit is tilted toward the outside a bit, if it is level the condensate will collect in the front and start dripping inside the house. Also, if the unit has a drain make sure it is clean so the water can drain out properly.
Jun 07, 2011 | Goldstar KG6000R Window Air Conditioner
Works and appears to blow out semi cold air, but not cold enough to cool room down......
Hello, first thing is check the condition of the filter on the front of the unit, if it is dirty wash it and let it dry then reinstall it. Also, it is a good idea to clean the evaporator coil with a can of coil cleaner that you can pick up at any heating and cooling store. Just spray cleaner on evaporator coil and let it dry. If this does not solve the problem tjen the unit might be undercharged and will need a hvac tech to recharge it.
Apr 27, 2011 | Goldstar KG6000R Window Air Conditioner
Goldstar 6000 AC
Be sure the condenser coil is clean. I use a foaming type cleaner.
Jul 26, 2010 | Goldstar KG6000R Window Air Conditioner
Where is the filter
It's behind the front grill underneath the vent. Some window A/C you can slide the filter out from the side or the bottom. Some you have to pull the whole front cover out. Some is part of the front grill and is not removable, and can be cleaned out instead of replacing.
Jul 09, 2010 | Goldstar R5050 Air Conditioner
Dirty filter
Yes just soap and water is fine for cleaning them. Just be gently and dont tear the filter. Make sure they are nice and dry before you put them back in.
May 22, 2010 | Goldstar KG6000R Window Air Conditioner
Weird Smell after ac shut down and fan runs alone
if it's weird like musty then clean the machine, coil, new filter or clean the washable filter and make sure it's draining well but if its weird as in burning wires have the machine checked before you use it again.
May 20, 2010 | LG Goldstar GWHD5000 wall/window Air...
My goldstar air conditioner has a lot of mold growing in where the fan blades are and the vent. How can I clean this or get rid of the mold
Air condition and coil cleaner,can be found at your local hardware store.
I have used simple green full strenght,cleans and kills mold.
Jan 18, 2010 | LG Goldstar GWHD5000 wall/window Air...
How to clean the filter
The filter is behind the front grill. Pop off the grill, should just pop off, pull down from the top under the vents. the filter is behind there.
Sep 18, 2009 | Goldstar KG6000R Window Air Conditioner
LG Goldstar GWHD5000 wall/window Air Conditioner Logo
116 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
