Question about Ovens
Cant remove glass cover to replace bulb on Simpson La Stella Atlas series oven
I have a Simpson Atlas Mira. Was having a hard time getting the glass cover off too so looked on the net for a solution. Couldn't find one so I persevered and sorted it...
The glass cover has a screw-off thread (like a glass jar) which unscrews anti-clockwise (lefty loosey). I had to give it a good few wiggles and pulls before it would start unscrewing. I also had to use a damp towel to get a proper grip - it's a slippery little bugger - but I got it in the end!
Hope this helps someone - good luck!
JD Hamilton, NZ
Posted on Jan 15, 2011
  • Kelly
    Kelly Apr 08, 2011
    thanks (:
Hi there, We are in a rental with an old Simpson Mercury stove and the oven light has blown. How do I get the light cap off? Many thanks Diane
it will be difficult
it is a normal thread in the glass cover and the problem is that burnt on fat is in the threads making like loctite
you will need strong hands or a tool like multi grips to turn the glass
make sure that you have the correct bulb as normal bulbs are not heated Pyrex treated glass to withstand the oven temperature and are only available from service agent spares or from the manufacturer
Sep 08, 2017 | Ovens
How do I remove the door on a simpson la stella wall oven to make cleaning easier
go to your authorized service agent and ask for a parts diagram for the door hinges
that will show small locks that when the door is open can be rotated into the slots of the hinges and lock the hinges open
from there you lift the door up and out of the hinge slots
Jun 08, 2017 | Ovens
Simpson Model la Stella Oven Thermowave not working Fan works and other settings OK
Burnt out element , thermostat or switch, test with meter.
Nov 10, 2016 | Ovens
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
Correct wattage bulb in Simpson La Scala electric oven.
if you are refering to the light inside the oven, I dont think there is a problem with wattage as the oven is rates to high wattage
and it is also inside the oven, so in an area that can cope with heat.
if possible check remove the old bulb and check the wattage on the glass or on the side of the fitting.
I personally would recommend that a 40W should be suitable.
I hope this was useful
May 23, 2011 | Ovens
How do I replace the lightbulb. NEFF B1442 series 3 Oven
1. Some glass covers are held on with a wire clip over them. It should be visible.
2. Some have a 'ring' which is screwed to the oven cavity around the light cover. On that design the screws need to be removed from the surrounding retaining ring.
3. On may later model the glass light cover screws into place. Those covers should 9hopefully) be able to be unscrewed the same you you'd remove a jar lid.
Nov 07, 2009 | Ovens
Can not set clock on Simpson La Stella oven
How do i set the time on a Simpson La Scala wal oven
Jun 30, 2009 | Electrolux Ovens
Oven
Pry back the bulb glass cover wire spring and remove glass cover. Use heavy rubber gloves or a plastic bottle opener(piece of serrated soft plastic/rubber) and unscrew counterclockwise.
Mar 05, 2007 | Whirlpool GBS277PR Electric Single Oven
Ovens Logo
640 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
