Question about Mitsubishi WS-55511 55" Rear Projection Television
Tv powers down every time we try to start it. We turn it on and it immediately turns itself off.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Please do the self check it has: when it shuts off and power light goes off, on the front of the set press and hold both MENU AND INPUT for at least 5 seconds and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat the error code four more times.
If this information helped you rate this solution as very helpful and I will if you post a comment here tell you what it means.
I do this here for free.
SD TECH
Posted on Aug 23, 2010
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Televison & Video
WHEN I TURN THE TV ON IT IMMEDIATELY SHUTS OFF....THEN, I CAN'T TURN IT ON UNLESS I UNPLUG IT FIRST. IT SHUTS OFF IMMEDIATELY AGAIN.....AND SO ON!! I WAS THINKING THAT MAYBE THERE WAS A ''FUSE'' OR SOME...
This sounds like a serious overload of the power supply circuitry - as the TV tries to start up, it is sensing an overload and therefore shuts itself down to protect itself (and you if it overheated).
Primary causes of such overloads in older TVs is a fault in the power supply circuitry itself, or a fault in the line output circuitry (the bit that generates the high voltages TV's use, and also the bit that scans the picture left to right).
Both types of fault require expertise and test equipment well beyond DIY level, to diagnose and repair.
Suggest you call a repair shop who should give you a free estimate as to likely cost of repair. Then you can decide if it worth it or not.
Oct 08, 2009 | Zenith B27A11Z 27" TV
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
May 19, 2009 | Philips Magnavox 32PS55S 32" TV
RCA TV quit working
is it back projected if so lamp needs changing if not power supply faulty
Dec 08, 2008 | RCA HD52W58 52" TV
Sony KP-65WS500 65 in.
Check your CRT boards on the end of the tubes for burn spots, and burnt components, check the resistors to make sure they are not shorted, burnt, and they read the correct resistance. Check the diodes to make sure they conduct in one direction only and are not shorted or open.
Mar 24, 2017 | Sony KP-65WS500 65" Rear Projection...
Set wont turn on red light just keeps blinking
this is a malfunction of the power supply block (inside your TV-device),or over load of it.please contact the nearest repair shop.
Aug 08, 2008 | Sony Televison & Video
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
TV LED Flashes then TV shuts itself off
capacitor problems in power supply or a regulater isolate the power suppley by disconecting the line output stage/unplug scan coils for example and run a 60w bulb as a dummy load one wire to earth and the other to rail voltage colecter of line output transister if the bulb glows steady the power supplys fine
Jun 25, 2007 | Philips 27PT81S 27" TV
Mitsubishi WS-55511 55" Rear Projection Television Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
