Kenmore HE2 Washing Machine Leaking
Water leaking from bottom of door during rinse cycle
a garment was caught in between door and seal and washer went through complete cycle.
water now leaks profusely during rinse portion of cycle.
bellows seal appears to be ok, but water continues to leak.
1. in your opinion does seal need to be replaced, and
2. is it the same proceed as in previous post on replacing the bellows seal.
the model number is 11047532600
  • 3 more comments
  • Anonymous Aug 15, 2008
    Water leaks from the bottom door of the front load Whirlpool washer. The problems appears after washing 2 pillows. The water was found behind the glass door at the bottom.
    What is the solution?
  • alynch1016 Nov 11, 2008
    The water leaks through the bottom of the door during the rinse cycle. I hate this GD machine.
  • gaborkcsr Jan 28, 2009
    I have the same problem. Not the first time it happened. The first time it was out of level. Second time it might of had too much sud. But this time i`ve done everything i could. Cleaned drain trap, made sure it was level soo on..... i should not have this problem from day one.
  • Anonymous Mar 15, 2014
    Water leaks
  • Anonymous Mar 23, 2014
    leaks at center bottom of tub when in wash and rinse cycles
  • 5,911 Answers
Have you looked behind the bellow under the folds to make sure there's no rips or tears? The bellow could appear okay on the outside, but still could have a tear somewhere out of plain view. I had this happen to me before.
The inner seal from the bellow to the tub could also be loose now. If you said a garment got stuck and the washer continued through the cycle, this could have loosen the seal where it attaches to the wash tub. You would need to tighten the band clamp around the facing of the tub if this is the case.
A good way in determining where the leak may be coming from is to remove the lower panel under the door. Start a wash cycle and watch to see where the water is coming out.
Now...if the tub seal is loose it may require some disassembly to get to. If you're going to go the route of disassembling the washer front, and have never replaced the bellow before, it probably wouldn't hurt to replace it anyway. My rationale: It's better to disassemble the washer once, rather than possibly having to do it all over again in the near future.
You can get a replacement bellow at searspartsdirect.com. Just type in your model number and look under the "Door and Latch Parts" section for item number 1 (part #8540952). It only costs about $32.
If you need instructions on how to replace the bellow, just go to my profile and look under my "Tips and Tricks". There is a write I posted there giving step-by-step instructions. If you cannot find it, or have any further questions, please post back and let me know. I hope this helps answer some of your questions.
Posted on May 04, 2008
When I go and try to run the cleaning cycle, the machine will start to spin, then puts no water in and after about a minute en rL error is display. Some time the clean cycle will start with out a problem...
"rL" indicates a garment has been detected inside the wash tub. Garments are detected by weight. The wash tub must remain empty during a Clean Cycle. If you inspect the wash tub and it appears to be clear, inspect the area around the door bellow (rubber door seal) for loose items. It is common for small garments, such as socks and underwear to get lodged in the rubber folds. Pull back the folds around the door and inspect the perimeter of the seal. If you need further guidance please let me know. I hope this helps you.
Jul 26, 2011 | Kenmore HE2 Plus Front Load Washer
Water is leaking during the wash cycle. Nothing shut in the door. Been happening with the fuller loads.
try wiping or cleaning off the bottom part of the door,i've seen pieces of hair on the door and water leaks down the pieces of hair through the door,if that's clean then check for a hole in the rubber boot seal,most likely there's a hole in it
Feb 21, 2011 | Kenmore HE2 Plus Front Load Washer
Water leaking at time the washer is being filled, not during wash cycle. Leak appears to be starting a bottom left side of the machine toward the front from the middle of the side. Observation does not...
you say water only leaks when it fills correct? am wondering if its the hose that feeds in to the washer
this would be from the inlet solenoids check the clamps in the machine.
Dec 02, 2009 | Kenmore HE2 Plus Front Load Washer
HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
John
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Leaking from bottom of washer
Do you have the little door at the bottom to collect lint and stuff that goes through the washer? I had a leaking problem once when I simply didn't tighten it enough. Check that.
May 06, 2009 | Kenmore 94702 Front Load Stacked Washer /...
My front load kenmore washer door gasket is garbelled
Something probably got caught in the seal and pulled it out of place. If u run washer so that it fills up and starts tumbling,,, and there is no water leak,, there is a good chance u can repair this yourself. So if there is no water leaking,,, you can try and take out the bottom front panel and twisting, or shoving it back into place. If there is water leaking,,, than chances are its ripped or broken, and will need to be completely replaced
Mar 13, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Washing Machines Logo
2,234 people viewed this question
Top Washing Machines Experts
