Question about Sony KDL-46XBR4 46 in. LCD Television
I own a sony Bravia KDL-46XBR4 flat screen. When it is first turned on, it is dark on the right 2/3 of the screen. The left 1/3 is ok. After about 1/2 to 1 hour later everything is normal. Thank you, Michael Coumas. Email coumas@sbcglobal.net
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
tvservice306
  • 458 Answers
SOURCE: "Plaid" screen on sony Bravia
go sony web
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
Posted on Mar 13, 2010
welcomejee
  • 10594 Answers
SOURCE: have a sony kdl-46xbr5 bravia
I need bit more detail about dark and cloudy screen at right side.
Does this change in screen start from center part instantly like it divides screen in two sections or screen gets darker gradually?
Thanks.
Posted on Sep 10, 2010
SOURCE: My Sony Bravia KDL-46XBR4 screen
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDL46XBR4
Above is your user manual and support site, to download.
http://72.9.159.100/avs-vb/showthread.php?t=1261602
Worth a look at above, Hmmm??
http://www.eserviceinfo.com/index.php?what=search2&searchstring=sony+kdl-46xbr4
Above is your service and repair manual for download.
What is happening is there is an internal "Fault" that is causing the Protection Circuitry , to detect the problem, and attempt to shut down the set. When we keep restarting the set, it may work briefly again, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Sony, in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
Posted on Dec 18, 2010
SOURCE: I have a sony Bravia KDL-52W3000 LCD tv. Approx.
I have the same tv with the same problem. My tv is about 3 1/2 years old. I took it to the shop yesterday and today they told me that I had a bad lcd panel and a bad FL1 circuit board. They also told me it was going to be $3800.00 dollars to fix. I am now on my way to buy another tv, needless to say it will not be a Sony. Sony knows about this problem and refuse to do anything about it. Good luck.
Posted on Jul 28, 2011
Portion of the screen is very dark, gets better after 20 minutes
Your LCD panel has failed, it will be cheaper to get a new set. If I have helped you please sign my guest book
http://www.back2lifeelectronics.com/Guestbook.php
Apr 17, 2014 | Sony Bravia XBR-Series KDL-46XBR4 46-Inch...
We own 2 Sony TVs. FD Trinitron Wega KV-27FV310 and LCD Bravia KDL 40S4100. Both have now lost 1/2 a screen. Top 1/2 on the Wega and left 1/2 on the Bravia. Our son plays XBox 360 on them. What i
On the WEGA the panel control module and possibly the left side planer board is done for. On the other sounds like the planer board on the dark side is done a well.
Get your son a Gaming type monitor cause this will continue to happen due to the higher refresh rates demanded on the gaming software.
Sorry Ed Pinero
Feb 03, 2013 | Sony BRAVIA Televison & Video
Sony BRAVIA XBR KDL-46XBR4 HDTV LCD Television
you need to replace defective capacitors in the power supply of the tv
Jan 05, 2013 | Sony Bravia XBR-Series KDL-46XBR4 46-Inch...
I have coloured vertical lines covering my Sony Bravia LCD tv screen. The TV is only 2 years old. I have sound but a very distorted picture. The cable company has checked and says it's a tv problem. I will...
I also have a 2 yr old Sony KDL32xbr4 that now has multi-colored vertical lines on the screen. I contacted Sony and they say they have "no known issue" of this sort for this model. I find this rather puzzling since I have found numerous postings on the web. They told me to try the factory reset. Whatever. Might as well have said "don't buy a Sony". 2 years! $1300 for a tv and it lasts 2 years! Makes me sick to my stomach.
Jan 02, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Nov 26, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony KDL-46XBR4 much darker on the right side of screen
ITS THE PANEL ASSY. I JUST HAD MY REPOACED. SONY WILL HONOR A COURTSEY WARRANTY UNTIL 2012
Nov 26, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Sony KDL-46XBR4 46 in. LCD Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
