Question about Amana Heating & Cooling
It just quit running. i flipped the breaker on and off to reset it but didn't work.
  • Amana Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Aug 22, 2010
Etq7000gen..runs but when I flip up the breaker no power.
why would you flip the breaker if it's running?
Jan 04, 2018 | Dryers
The power went out and when it came back on our stove is not working. No lights on the display. The stove is dead. Is there a way to reset the oven???
Did you trip a breaker. Try to flip the breaker switch that goes to the oven. You may have to flip all the switches and flip them back on to get the correct breaker switch.
Jun 14, 2017 | Kitchen Ranges
Pool shut off, went to investigate and found that the pool motor and flipped a breaker, reset and when I tried to turn motor on again, the motor just hummed but didn't turn over.
The pump needs to be disassembled to inspect for an obstruction in the impeller area or possible bad bearing in the motor, often caused by a leaking shaft seal
Aug 03, 2011 | Pentair Pool & Spa
Just quit. Is there a fuse involved in the strip?
Hi, the strip has a breaker on the cord end. You need to check that it has not flipped to the open position. If it is flipped, then you need to reset it. Usually pressing it will reset it. If not, then there may be an internal problem with the unit.
JOe
Jan 21, 2011 | Tripp Lite Waber Multiple Outlet Strip...
My dry quite working after my was work in electric box he was flipping power on and off
Your dryer is a 220 appliance and should be on a circuit all by itself. Are the items in your circuit box labeled (Lights? kitchen, etc.) One should be labeled "dryer". If you cannot locate one that is labeled for your dryer, Check out the position of the circuit breakers. If the dryer breaker is turned off it will be in the oppoite postion of the others.Caution: DO NOT do what he did and begin flipping breakers! If your dryer breaker is in the off position,is you should be able to flip it back on. Before you do this, have the dryer turned off.
If this does not work, unplug your dryer and leave it unplugged for 5 minutes or so, so that the dryers' operating system can reset itself. Then try turning it back on.
Dec 16, 2010 | Maytag Dryers
Honeywell MagicStat 3200 Fan continues to run--I flipped furnace breaker off for an hour, set stat to off, & flipped breaker back on. fan still runs. Fan control is on Auto.
Hello,If just installed the thermostat check that the wires are not touching anywhere.If not the case you have a open(tripped) HIGH LIMIT at the furnace and the blower will continue to run untill it is reset.
Oct 30, 2010 | Honeywell Programmable Thermostat Heater
Circuit breaker problem
if you turned the breaker to the left to turn off you must turn the breaker all the way to the right to reset it same as if you turned to the right you must turn to the left all the way to reset which ever way you turned the breaker off you need to follow thru the process in order to reset that breaker breakers are spring loaded flip it completly off than on
Apr 24, 2010 | Water Heaters
Breaker blew and when flipped back on, microwave didn't work
yes there is a 15 amp fuse that needs to be changed in behind the front control panel
Aug 21, 2009 | Whirlpool MH7140XF Microwave Oven
Thermostat blank, system not operating reset breaker, worked for a bit, then quit again
you have a short ether in the force air unite or the condenser you can usually tell buy what breaker flips. and there is where you start look for a short
Jun 28, 2009 | Heating & Cooling
Heating & Cooling Logo
122 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
