Whirlpool top loader washer LSR7233EQ0 drains, but does not spin. Best troubleshooting advice?
  • joeyndan Jul 30, 2008
    Is this worth repairing?
  • 177 Answers
You probably broke the coupler between the motor and transmission. However If it agitates the coupler is not broke.
Posted on May 04, 2008
Whirlpool Model# LSR7233EQ0
Check the level sensor and the drain pump for clogging, if this is clean then the control panel is a suspect as the processor does not advance in cycle
check for tips : washing machine tips .
Jul 03, 2012 | Whirlpool 3.2 cu. ft. Plus Washer
How do I repair my Whirlpool Ultimate Care 2 LSQ9549L Top Loader Washer?
check the motor coupling,if the coupling is broken you'll hear the motor run but the agitiator won't move and no spin,the coupling connects the motor to the this video
May 30, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool top loader washer will not spin
Could be one of several different things depending on the age and model. If its less than 10 years old and is a top load washer its probably a motor coupling (connects the motor to the transmission kinda like a belt) or lid switch. If the water is draining out but the washer is not spinning its probably the motor coupling. If it still has water in it and won't spin, its probably the lid switch. If your washer is a front loader there could be several things going on. Hope that helps.
Aug 29, 2011 | Whirlpool Washing Machines
Whirlpool front loader washer is not spinning
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Dec 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Top loader series 80 Kenmore doesn't stop after the whole wash cycle, it goes directly to 2nd rinse, then spins again and stops?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Since it does everything else, the problem points to the timer.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers with an extensive troubleshooting section.$FILE/L-55.pdf
Oct 14, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool direct drive top loader will not spin
Hi, Is the humming noise coming from the timer area? Do you know if it agitates ok?
When you have it in spin cycle, Try lifting the lid and see if the hum stops.
The reason for these questions is that on this model, if it drains the water out but does not spin, it is either lid switch, coupler, or transmission.
If it's the coupler, it will not agitate either.
Please let me know so I can assist you further.
May 30, 2009 | Whirlpool LSR8433K Top Load Washer
Troubleshooting Whirlpool Push to Start Mechanism for Washer
What kind of whirlpool do you have? is it a top loader or a frontloader. If it is a top loader is there water entering the washer? does it not agetate? Does it not Spin. If it does not wash or spin it is a possible bad lid switch close the lid. Do you hear a click? If you have no CLICK sound you have a bad lid switch.
Jan 22, 2009 | Whirlpool Push to Start Mechanism for...
Does not spin
The close pin most likely broke the switch. Unplug the washer, remove the screws that hold the top and flip it back and remove the cabinet. with the cabinet off it is easy to replace the lid switch. Cost should be $20. to $30.
God Bless and Happy New Year.
Dec 31, 2007 | Whirlpool LSR6334LQ Top Load Washer
Washing Machines Logo
342 people viewed this question
Top Washing Machines Experts
