Question about Connex CX-4300HP CB Radio
After i hooked up my new connex4300 i hear the a/c when i turn it on is my antena too close to my radio?
  • 29 Answers
Hello Shot
This is a weird one. Don't know exactly where to start but here is some ideas. Power filter to the power input, may be run power w/gnd from the battery, try a different antenna, run a ground wire to the radio and or antenna. other than this ya got me but maybe one of these ideas will work. Good luck and thanks for a good question and let us know what fixes it.
Ray
Posted on Aug 23, 2010
I HAVE 4RUNNER 94 ,RADIO WAS CHANGE , NOW THE ANTENA DONT GO UP WENT I TURN ON THE NEW RADIO
did you hook up the blue wire from the radio to the blue wire in the dash? that blue wire is for power ant. it is called the remote wire
Feb 17, 2011 | 1994 Toyota 4Runner
I bought a new antanea 3 ft fiberglass with mirror mount when hooked to radio needle swings all the way to the red and i dont transmit or receive but when hooked back to old antenae works fine old antenae...
Mirror mounts need alot of Ground to tune correctly. Most mirrors don't ground to the door good enough, not to mention the reflection of the radio signal off the cab. Be sure it's grounded good and the nylon insulator is place.
Jan 14, 2011 | Cobra 29 LTD CB Radio
Radio recieving and putting very poor.
Just because its a magnet mount doesn't mean its a 100%. I've sold 4 little wheels made by wilson in the past 2 months and they had a ground problem. If you grab the base of the antenna does it give you more squesh? If so it has a ground problem. Have you had that antenna matched to you truck if not that could be your problem. You need to have your SWR checked on your antenna.
Jul 13, 2010 | Galaxy Radios DX-33HML 40-Channels Base CB...
I hooked up my cb radio. my friend could hear me i couldnt hear h
Is the tone high pitch? if so he was too close to you (feedback).
If the tone was low then could be a voltage problem, or a microphone fault.
more like to be an incorrectly wired microphone if the radio is new?
Jun 18, 2010 | Radio Shack TRC-521 CB Radio
Radio and cd player only play out of left dash speaker. It seems to me that equalizer works ok,(only one speaker to check it with) but when I fade over to right side channel, nothing. The antenae is hooked...
I had this same problem. After reading other ideas and some trial and error, I finally got it. Most Caravans have an Infinity system (the speaker grill will say Infinity on it) ,which uses an amplifier to run the door and rear speakers. I had to ground the clip wire that was originally attatched to the strap ground on the factory installed radio. Then I also had to hook the wire on the new radio for power antenae (blue and white on my unit) to a blue wire on my new harness. This wire came from the last wire of 7 wire harness that had the other 6 wires for speakers. The original wire appeared to be green/red on my vehicle. After I connected both, the speakers cameon and sound great again.
Apr 26, 2010 | 1997 Dodge Caravan
Power antena after markit how to make it work with radio
on the radio there is a cable that is for Power Antena you might have to set a cable out to the area you are instslling the antena if this car already had a power antena you only need to hook up the leds from the old if not then like i said you need to get positive cable out to the antena and ground it to chassis
Apr 01, 2010 | 2000 Mercury Sable
I have hooked up my converter box but its not receiving any signal. do i need to buy a new antana? Or what could be the problem?
make sure u have the antena hooked to box and box hooked to tv, make sure antena wire is actually hooked to an antena if wire is coming out of the wall, otherwise u more than likely need a new antena, or box it's self is bad but if it turns on and u see somtin on the screen like make sure antena is hooked up then the box is probaly good
Nov 18, 2009 | Insignia Digital-to-Analog Converter for...
Sony explod,every thing works but the radio
MAKE SURE THE HOOK UP IS TIGHT IN THE BACK OF THE UNIT.
Jun 17, 2009 | Sony Xplod CD Player w/MP3 Playback...
Tried to used CB without antena
If you were trying to transmit without the ant. then your assumption about the demise of your radio is correct.If you hooked it up using an inline fuse ,then just change the fuse. If you hooked up without a fuse, then no, you can not fix it. Please rate this answer.
Apr 09, 2009 | Cobra 29 LTD CB Radio
Background noise
I'm not an expert but I am a daily operator. First check your ground connection, just because the radio turns on doesn't mean the ground is good enough. If this unit is mobile there are several things you can do to reduce the noise. First you need to find out if the noise is coming in thruogh the antena or the power supply; turn on your radio and vehicle, unhook the antena. If the noise goes away or is reduced you know that it is RF noise. this is interference from some outside source, powerlines, TV, just about any thing that uses electricity or electronics can cause noise. relocating the antena may help. Check you antena connections. Check your SWR. This is only a few of the things you can check.
Apr 06, 2008 | Connex 4600 Base CB Radio
Connex CX-4300HP CB Radio Logo
56 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Mitch Davis
Mitch Davis
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
