Question about Daewoo Televison & Video
I have a 6427TF Sylvania 27". I do not have the remote, I plugged in my digital cable box to it using a/v cords. How do I switch the tv over to use the cable box?
  • mlsullivan Aug 23, 2010
    There is none.
    The only buttons are menu, channel, volume, and power.
  • Daewoo Master
  • 11,800 Answers
Press Menu button on the case, use PR - button to move in the menu to Source, use Vol+ to go in it and in there select the correct AV entry. Exit the menu by pressing the Menu button.
Posted on Aug 23, 2010
  • Daewoo Master
  • 736 Answers
Look for an input or video or auxiliary button on the television itself.
  • Loretta Northcutt
    Loretta Northcutt Aug 23, 2010
    Sometimes you can go into the menu as if you were going to complete a channel scan or manually add or delete channels. Then you might be able to use the channel button to scroll up to the video input.
Codes rca universal remote r20052 3910p
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Apr 22, 2012 | Televison & Video
Sylvania 15 inch digital/analog LCD TV HDTV. Once
try doing the auto search method on the cable remote. sometimes this works when the codes do not. if it doesn't then it is what it is.
Jun 26, 2010 | Televison & Video
I have a sylvania tv, i dont have the remote, i connect a digital reception on it, tv only show one channel, i cant tell if the tv on cable or antena, the menu on the tv is no help, can u help
hmm could that be a "sylvania 6427 gff".. i have seen a suffix of FF, GFF and GFG ... but not TE ... at any rate those are actually CRT displays .. probably the last of their kind ... they produce a really good but standard defination picture ... when you first turn it on it should come up with a setup menu ... if the cable is connecgted at the time it should find at least a few digital channels ..probably no standard channels ...most of those models do have standard and digital tuners but not sure about your TE model ...you might try unplugging your set for a few hours ... when you turn it back on it should come up with the menu system ...you will likely need a cable box to get most of the cable channels... but you may be able to get some ..you could try hookinng up rabbit ear antenna to see what local channels you can get ....
Apr 10, 2010 | Sylvania 6427TE 27" TV
I am trying to program a universal remote for the Sylvania 6427tv
try these four codes
0054, 0030, 0020, 0096
hope this helps
Cheers
Little Dish Fitter
Sep 01, 2009 | Televison & Video
Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
002,
008,
155,
198,
227,
231
Here are the codes for the 1st solution.
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
Jun 18, 2009 | Sylvania LC320SS8 32 in. LCD Television
Need some codes to put in my remote control for sat. tv
Some codes for Sylvania tvs are 0020, 0030, 0054, 0096 also 0171, 0179, 0180 1nd 8083. They depend on the model number and the universal remote used. Sometimes remote uses three digits...drop the first digit and use the last three.
May 03, 2009 | Sylvania 6427TE 27" TV
Need to program a universal remote to work on Magnavox TB100MW9
Most of these are new and codes do not exist for them. You'll need a universal remote that has a learning feature so it will learn the code. Walmart has them for $16-$19.
Nov 11, 2008 | Philips Magnavox 27MS343S 27" TV
Digital converter
if you do not have cable or satilite tv, you will have to purchase converter box. If you have either on of those services you will be in good shape.
May 03, 2008 | Sylvania 6427FB 27" TV
Televison & Video Logo
143 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
