Question about Refrigerators
Hi! I have a Danby DAR604bls fridg and the problem is that every once in a while ice is forming in the back inside and is blocking the drain. This create huge ice making without drainage and when de-icing occurs, I have water coming down on the floor. Any solution to that problem?
  • Refrigerators Master
  • 43,501 Answers
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 23, 2010
What can cause water in my fridge
dont know what kind of refrigerator you have but this might help:
http://ask.metafilter.com/68706/Why-does-my-fridge-create-a-pond-inside
Frost free fridges in correct working order do not need to be defrosted, not even once a year. This problem is also completely fixable with at most a couple hours labour.
Water in the bottom of the fridge is caused by three things:
  1. plugged drain tube.
  2. plugged or frozen defrost pan.
  3. some other defect in the drain system.
Your drain pan is located in your freezing compartment of your fridge. It collects the condensate that is melted off the refrigeration coil by the defrost heaters. It directs the water to the drain tube system which takes it to the outside of the fridge where it is evaporated, often with an assist from the waste heat from the condenser.
If your fridge is equipped with a pan heating element and the element fails ice will form on the pan and eventually block the drain. This would account for the cyclic problem cured with a manual defrost that kat and nimsey lou report. The same symptoms can present themselves with a partially blocked drain (corn kernels are a common drain blocker). A secondary symptom of this condition is clear solid ice in the bottom of the freezer compartment. If a manual defrost doesn't clear a blocked pan the blockage is full and not ice and disassembly will be required to clear the blockage.
At the top centre back of your fresh compartment you'll usually have a small cup of rubber or plastic. If that cup has water or ice in it the problem is actually a blockage of your drain tube. Because it is a narrow spot the blockage is often at the exit of the cup or on the outside of your fridge where the tube takes a 90 degree bend down to the evaporator pan. If you can remove the cup do so and clean it out otherwise you might need to remove the tube/90 from the back; it's about 75/25. Sometimes a flexible piece of plastic, like a zip-tie, can be used like an drain auger to clear the blockage. Why does my fridge create pond inside
Jan 02, 2015 | Refrigerators
Leaking under neath front of refrigerator
Usually any defrost water sits in a plastic pan and evaporates away in normal operation. If the pan becomes brittle it cracks and leaks water. Pull the fridge out and look on top of the black pot (compressor) Is there a plastic drain pan sat on top of it?
Sometimes if the fridge is working hard a lump of ice can form on the pipework going back to the compressor which melts causing some water at the front of the fridge.
Lastly, the insulation under the fridge may have broken down, allowing condensation to form and drip. If the drain was blocked, the water would be inside the fridge, not underneath.
Apr 20, 2012 | Kenmore Refrigerators
My bottom freezing compartment some how gets water in it and then it freezes what could be the problem?
Hello
The water comes from the self defrost cycle.It is supposed to drain out to a collector under fridge.
Sounds like your drain got clogged causing ice block to form.
Turn off fridge and use hairdryer to melt ice block. You should be able to see a drain hole.Continue to melt using Hair dryer and hot water.Once ice is out of drain tube use some flexitube to gently push out any obstruction(usuually a pea or lima bean!)
Good as new.
Any feedback much appreciated
Jul 28, 2011 | Kenmore Refrigerators
LEAKING INSIDE DOWN THE BACK AND UNDER CRISPERS, AND ICE FORMING INSIDE
The drain hole / drain tube in your freezer are probably blocked or even frozen shut so that the defrost water is leaking into fridge. See my answer here:
http://www.fixya.com/support/t8706684-water_leaking_inside_refrigerator
Mar 16, 2011 | Kenmore 64802 Top Freezer Refrigerator
I HAVE A DANBY GAS REFRIGERATOR WHEN IT WAS NEW ,7 YEARS AGO I NEVER HAD TO CLEAN AND BRUSH THE VENT PIPE IN THE BACK OF THE UNIT. NOW EVERY 3 MONTHS IT SEEMS I NEED TO BRUSH THE PIPES OTHERWISE I GET A...
the smell you get is bacteria from the condensate(it is similar to the legionaire bug)cover all electrics and spray with a strong clorine bleach solution.and because it gets a little greasy(check your windows)all the dust and s..t sticks to it....the clorine will clean it off.also when degreased use a vacuum cleaner to remove all dust.
some people only clean behind there fridges once every ----- years.
treat the back of a fridge the same as your bathroom for cleanliness.
Aug 21, 2010 | Danby (DAR604BLS) Refrigerator
Stopped cooling in bottom but freezer still works
make sure there isn't something blocking the air flow from freezer into refrigerator. If possible, unplug for a little while and see if water leaks out from back wall where evaporator is. It may be frozen up, blocking the fan from pushing air through. Listen closly to back wall to hear if fan is operating, it might be hitting ice build up. If fan is not running at all, that;s your problem.
Jul 15, 2010 | Danby (DAR604BLS) Refrigerator
Fridge drain is overflowing into base of fridge, causing build-up of ice over base, which then 'sticks' the salad boxes to the base of the fridge, making them difficult to draw out. I have to scrape the...
Some insect would have gone into the drain pipe and blocked the outlet for the water to flow and it gets collected inside.
First please clean the drain pipe and remove any block.
Defrost your refrigerator at least once in three days.
Excess ice formed in the freezer chamber will result in less cooling and melting of ice and make it run down.
The above remedies should solve your problem
Jul 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I was chipping ice from the inside of my mini fridge like an idiot and i poked a hole in it
If you heard what sounded like air rushing out,You have killed it.
If you only punched through the plastic liner,you're fine.
Jan 26, 2009 | Danby (DAR604BLS) Refrigerator
Leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Oct 28, 2007 | Refrigerators
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
