Question about Zenith R57W46 57" Rear Projection Television
Seeing doyble figures on one side and colors bleeding
  • rrmartinez May 30, 2008
    I am getting the red colored projection coming in differently than the others.
  • rpgwv May 30, 2008
    seeing double figures on scrren on left side and now on the bottom as well
R57W46 57 in. Zenith TV
Posted on May 26, 2008
  • Zenith Master
  • 8,617 Answers
Need to replace the convergence ICs. Post your model number and I will post a link where you can get replacements.
Posted on May 04, 2008
Maytag doyble oven glasstop the front burners stopped working ..anyway to fix this at low cost?
None I am aware of . the single small burner cost is over 75.00 online
Dec 05, 2017 | Maytag Kitchen Ranges
2006 HYUNDAI Sonata I figured I'd bleed the the rear brakes after replacing the rotors and pads. 120,000 Miles with no previous brake issues besides normal replacement of front rotors and pads. After...
Try re-bleeding ALL wheels starting with furthest away - pass rear, then driv rear, then pass front and driv front. That should get your pedal back. To reset light you need ABS reset tool and it's EXPENSIVE. Have a good competent shop reset it for you. Body shops can reset them also.
Feb 27, 2011 | 2006 Hyundai Sonata
Need instructions for power steering pump replacement on a 1992 pontiac trans sport. FAST PLEASE!!! has a 3.8L engine with a/c. thankyou for your help!
-- from the 1990-1999 Lumina / Silhouette / TranSport Repair manual ---
1992 Pontiac TransPort Power Steering Pump REMOVAL AND INSTALLATION
  1. Disconnect the negative battery cable.
  2. Disconnect and cap the power steering pump hoses.
  3. Remove the accessory drive belt.
  4. Remove the power steering pump pulley using a suitable puller tool.
  5. Remove the pump mounting bolts and remove the pump from the vehicle.
See Figures 1, 2 and 3
Fig. Fig. 1: On some vehicles, you must use a puller to remove the power steering pump pulley
Fig. Fig. 2: Power steering pump mounting-early model vehicle shown
Fig. Fig. 3: Power steering pump mounting-late model vehicle shown
  1. Installation is the reverse of the removal procedure. Tighten the pump mounting bolts to 18 ft. lbs. (25 Nm).
  2. Bleed the power steering system to remove trapped air. Air in the system could cause noise and or damage to the pump.
This procedure requires the help of an assistant.
  1. With the engine OFF, the wheels off the ground and turned all the way to the left, fill the fluid reservoir to the FULL COLD mark on the fluid level indicator.
  2. With an assistant checking the fluid level and condition, bleed the system by turning the wheels from side to side without hitting the stops. You should repeat this at least 20 times, making sure to keep the fluid level at the FULL COLD mark.
Fluid with air in it has a light tan appearance. This air must be eliminated from the fluid before normal steering action can be obtained.
See Figure 4
Fig. Fig. 4: Power steering bleeding procedure
  1. Start the engine, and while it is idling, recheck the fluid level and add as necessary to reach the FULL COLD mark.
  2. Return the wheels to the center position. Lower the front wheels to the ground and continue running the engine for 2 or 3 minutes.
  3. Road test the vehicle to make sure the steering functions properly and is free of noises.
See Figure 5
0900c152801dbcfb.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 5: Torque specificatio
Jan 02, 2011 | Pontiac Trans Sport Cars & Trucks
Photos come out totally blurred with colors mixed. Happens on all sizes of paper (photo quality).
  1. Make sure that there is letter, A4, or legal unused plain white paper in the input tray.
  2. Touch Setup on the display.
  3. Touch Tools .
  4. Touch Self-Test Report . A self-test report prints. Figure 1: Self Test Diagnostic Pagec01154260.png
  5. In the Print Quality Pattern section on the test page, look at the color blocks for any lines. Figure 2: Print Quality Patternc01154261.png
  6. If there is no color bleeding in the Print Quality Pattern color blocks, print a document to determine if the issue has been resolved.
If you have completed all of these steps and are still experiencing a problem, continue to Step three. Step three: Check the paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
If you have completed all of these steps and are still experiencing a problem, continue to Step four. Step four: Check the printer settings
  1. In the software program you are trying to print from, click File and then click Print . The Print window opens.
  2. Make sure that your printer is selected and then click Preferences . The printer Preferences window opens.
  3. Click the Printing Shortcuts tab.
  4. The Printing Shortcuts tab lists most printing needs, but you might need to modify some of the options. Options on the Printing Shortcuts tab:
    • General Everyday Printing
    • Photo Printing-Borderless
    • Photo Printing-With White Borders
    • Fast/Economical printing
    • Presentation printing
    • Two-sided (Duplex) Printing
    NOTE: These general printing shortcuts have pre-selected settings.
  5. To change the settings from the ones that are available on the Printing Shortcuts tab, click the Features or Color tab. Options on the Features or Color tab include:
    • Print quality : If you are unhappy with the quality of your printouts, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches your paper type exactly, select it rather than Automatic.
    • Paper size : Make sure this matches your paper.
    • Print in Grayscale : Print a document in shades of gray.
    • Orientation : Specify how the document is positioned on the page.
    • Paper Source : Select the tray that you want to use for printing.
    • Two sided printing : Print on both sides of the paper.
    • Color Management : Specify the color space that the printer will use to interpret image data.
    • Pages per Sheet : Specify the number of pages of the document to print on each sheet.
If you have completed all of these steps and are still experiencing a problem, continue to Step five. Step five: Clean the printhead
NOTE: Do not clean the printhead unnecessarily because this wastes ink and shortens the life of the ink nozzles on the printhead.
  1. Make sure that there is plain white paper in the input tray.
  3. Touch Tools .
  4. Touch Clean Printhead . The HP All-in-One cleans the printhead and prints a test page.
Step six: Service your productIf you have completed all the steps listed above and are still experiencing a problem, service the product
Dec 07, 2010 | HP Photosmart C8180 All-in-One InkJet...
"Check Color Cartridge" displays even after replacement of cartridge -though I don't think original cartridge was empty- and stops printer from printing. The new cartridge is installed properly, and...
  1. First, check your cartridges. HP cannot guarantee the quality of remanufactured or refilled cartridges.
  2. Second, make sure your paper is not causing the problem. Paper that does not accept ink well can cause your images to smear or bleed. Plain paper is not the best choice for high-density graphics. Click here to see how to pick the best paper for your project .
  3. If the paper is not the problem and you are using genuine HP cartridges, print a clean test to see if the printer and cartridges are functioning properly. Load the printer with clean, plain, white paper and print a clean test page. To see how to print a clean test page, see your printer's User's Guide , or see HP Deskjet Printers - How To Print Internal Tests , or HP All-in-One Product Family - Printing Self-Test Reports .
  4. Evaluate the clean test page. Different printers produce different pages, but you should recognize elements from the examples below on your test page. In general, cartridge and printer problems are indicated by streaks, missing colors, or wrong colors.
    • Examples from a good printer and cartridges (your test page may not look exactly like this): Figure 1: Solid colors that match color dots on cartridge labelc00059224.gif Figure 2: Pattern unbroken, or broken in only a few placesc00059225.gif
      c00059227.gif If your test page looks more like the good examples above than the bad examples shown in the next two sections below, the printer and cartridges are probably not causing the problem. Click here to continue troubleshooting .
    • Examples from a failing printer or cartridges - streaked or broken bars or lines Figure 3: Fading, missing, or streaked bar - low-ink or empty cartridge, clogged nozzles, or electrical problemsc00059228.gif
      Figure 4: Color completely missing (magenta bar missing below)c00290898.gif Figure 5: Lines broken randomly - clogged nozzlesc00059231.gif
      Figure 6: Lines broken in pattern - dirty contacts or other electrical problemsc00059232.gif
      Figure 7: Color completely missing (magenta pattern missing below)c00290899.gif If your test page looks like these examples, you probably have a cartridge that is empty, has clogged nozzles, or dirty contacts. Click here to continue troubleshooting .
    • Examples from a failing printer or cartridges - colors do not match the color dots on the cartridge label (Note: do not compare the test page colors to the colors of the examples on this web page. Your monitor may not display the colors properly). c00059234.gif c00059235.gif If your test page looks like these examples, you probably have a cartridge in which the inks have mixed. Click here to continue troubleshooting .
Oct 26, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
Colors appear to be bleeding out to the side.
have you tried the blue convergence adjustment via menu
Aug 25, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Full bleed printing
feed the stock thru the Multi prupose tray. Set a custom size in the PDD to 5 mm larger diamension for W and H. this fools the machine to thing larger stock is being printed. feed your original stock. do not scale to fit....and presto, you can print to full bleed...
Sep 10, 2008 | Xante Ilumina Digital Color Press Printer
I have a 2001 2.O Jetta. Cant seem to figure out why it keeps overheating. Have changed the thermostat. Fans are working properly. Any suggestions?
1 how is it overheating ?
2 check the heater core see if it is pluged
3 what color is it in the radeaidor
4 check to see if any of your hoses are squeezeing together
Sep 01, 2008 | 1998 Volkswagen Jetta
Bleeding colors
Only thing I can think of is the pages were somehow warmed.
I would try heating them to maybe 120-130 degrees to see if that releases them.
Thats about the only suggestion I can come up with. You don't want to get them hotter and remelt the ink .
May 08, 2008 | Xerox Phaser 8200 Laser Printer
Color 'bleeds' or smears when watching HD channels on Toshiba 53HX71
Sounds like the same problem i had recently, Take the front off, (its safe so your ok) You will see the 3 lenses which are ajustable, Just keep adjusting 1mm at a time until it solves this, Took me about 45 mins to get it perfect, Persist and you will get there!! Hope this helps
Mar 17, 2007 | Toshiba 53HX71 53" Rear Projection...
Zenith R57W46 57" Rear Projection Television Logo
90 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
