Question about RCA DRC220N DVD Player
Language Selection for RCA DRC 220N
I have the RCA DRC 220 dvd player but I have No remote for it. How do I access the menu?? For some reason the player defaults to French when playing a dvd. I can't get to the menu to reset the language. Is there some way to reset the dvd player without using a remote?
Try to find an original remote in a pawn shop, sometimes they have extra remotes because broken dvd players, or other reasons they only know.
Posted on Dec 08, 2008
Rca dvd player stuck
There are a number of possibilities, jammed gears caused by a disc or gears out of time, some have a very small loading belt located under the draw in most cases, excessive ware and tare on plastic gear linkage.
Sep 05, 2012 | RCA Televison & Video
DVD player won't play new movies
Try this
1.While the previews are playing, press the Menu Button on your DVD player remote to access the DVD's Main Menu.
2.Go to Scene Selection and press your Enter or Ok button on your DVD player remote.
3.Highlight Scene 2 and press the Enter or Ok button. This will start the DVD in Scene 2.
4.Use your rewind or reverse button on your DVD player remote to rewind back to the beginning of Scene 1.
Walt Disney Home Entertainment Technical Support
1-800-723-4763, Monday's 9:30-7:30 and Tuesday through Friday 9:30-6:30 CST
Excerpt from email tech support Walt Disney
Dec 07, 2007 | RCA B27TF680 27 in. TV/VCR/DVD Combo
RCA DRC-285 DVD Player won't respond
hi, 2 things usually cause this kind of behaviour 1-the dvd+r have been burnt at a high speed 2-the dvd player itself is a bit old when you burn your dvd+R always burn them at a lower speed lowest if possible it'll take longer but it's well worth it and you wouldn't have a problem playing them back
Aug 22, 2007 | RCA DRC-285 DVD Player
I purchased a RCA DRC-8335 DVD/VCR RECORDER COMBO
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
Jul 31, 2009 | Televison & Video
User Guide for RCA DVD RCR 110D A1
The manual for this remote control is embedded in the operating manual of the DVD Player DRC 220.
icon_arrow_download.gif RCR 110D A1.pdf
Apr 16, 2009 | RCA (DVDCP33) Media
I can't get rid of closed captioning!
Closed captioning can come trough 4 sources 3 of them access a digital file and display it to the screen. ALL must be set to off on each device:
Embeded in actual program video source--unlikely your problem.
TV decoder cotrolled by TV menu under "language"
Cable box--ditto for menu selection
DVD player or VHS tuner--Ditto for menu
Sep 17, 2017 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Hooking up & seeing a dvd player?
does the dvd have a coax output for coax antenna input on the tv? you can use that untill you can get the video input selection straight with the tv and a remote that supports rca's extra functions such as menu , tv/av button
or
also if there is a( wake-up) on/off timer in the tv menu , then you can also set it to come on with the video input instead of a tv station,set it a few minutes after the time it is when you set it( then just turn off the tv set after the time is set and you have exited the menu, then it will come on with the video input instead of a tv station)
otherwise you will need that remote that supports the video input selection on your tv
Jan 08, 2009 | RCA F20625 20" TV
I have an rca dvd player. when i watch dvds they play in spanish. i have no remote. how can i change the language?
you can do 1 of 2 things ,you can buy a cheap universal remote and program it to your brand of player,once doing that you can hit the menu button and there should be a setting for language and you canswitch it to another language ,or there should be a menu button on the front of the player just push that and try different buttons on the front to be able to scroll thru your options.
Dec 05, 2008 | RCA DRC220N DVD Player
Can?t power on
You have a power supply problem,
  • Secondary look for faulty diods
  • look for a part pc817 opto coupler small squar 4 pins
  • look for tl421 transister
  • Look for any bloated caps
Hope this will help
Nov 03, 2007 | RCA DRC220N DVD Player
RCA DRC220N DVD Player Logo
332 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
