Question about GE Nautilus 24" Built-in Dishwasher
After replacing my garbage disposal, my dishwashr stopped working. I did forget to remove the stop plug from the disposal unit. But even after doing this the unit still does not work. It does turn on but no water drains out. In addition when using the sink it appears that some water may be getting into the dishwasher.
  • racingray200 Aug 23, 2010
    The drain hose appears to be in the same position as it was before. Where is the solonoid inside the dishwasher. And does it pay to replace it versus getting a new dishwasher?
    I checked the drain hose, and it appears to be in the same location as before. The dishwasher does not start to fill it with water when I turn it on. Where is the dishwasher drain solonoid?
  • GE Master
  • 3,361 Answers
The drain line from the dishwasher MUST be secured HIGHER then the drain port in the disposal.
If this is not the issue,the dishwasher drain solenoid is not functioning correctly.
Posted on Aug 22, 2010
Garbage disposal quit working. Just stopped
Press reset button located on bottom of unit.
Use broomstick down inside disposal to make sure cutter disc rotates freely.
Copy following link for troubleshoot and illustrations:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 19, 2013 | Emerson Evergrind E202 1/2 HP Garbage...
My garbage disposal will not start from a dead stop.
The motor start winding has gone bad, or capacitor burned out.
Generally disposals are replaced when motor goes bad.
Mostly because the disposal is sealed unit and cannot be easily disassembled.
If you have local motor-repair guy, who has disposal bearing parts, and can get the disposal apart, then repair might be possible... but the bearing seal would be hard to replace.
Copy following link for replacing garbage disposal with tips from when I did apartment maintenance.
Oct 30, 2012 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Water flows out of garbage disposal vent when ever we use the dishwasher
Most likely the whole thing needs to be taken apart and cleaned, not just the disposal, but the plumbing as well.
I have often had to do this for others.
Very often the problem has been people put things in the disposal that plug up the plumbing, like eggshells, bananana peels, and other fruits & vegetables that readily plug the system.
I have had to take such apart too many times to count.
Oh, yes.
If your dishwasher empties into the disposal ( that is normal) you may find your 2 choices are to repair or replace the disposal, or remove the disposal all together and hook the dishwasher drain directly to the plumbing.
God bless your efforts.
Jul 04, 2017 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposal won't stop running
Check switch. replace switch. If switch checks out, then replace disposal to avoid risk of overheating and in-wall short.
Copy following link to repair, troubleshoot and replace disposal:
Add a comment as needed, or repost question with detail
Dec 18, 2011 | KitchenAid Batch Feed Garbage Disposal...
We are having a problem with the actuator. once the the disposer is started it won't stop unless we turn off the breaker. is this fixable, or do we need a new unit?
Replace disposal with type that uses switch for more reliability
Mar 13, 2011 | KitchenAid Batch Feed Garbage Disposal...
My Kitchen Aid superba does not drain. It just happened after I replaced my garbage disposal. I folllowed all of the instructions. How do I check for blockages, etc?
easy job, DISCONNECT POWER..... YOU FORGOT TO KNOCK OUT THE DRAIN PLUG ON THE DISPOSAL.... remove the drain hose off of disposal and push a screwdriver into the opening..does it go thru or does it stop...if it stops..take a hammer and knock the end of screwdriver forcing out the plug...remember, to remove plastic plug from inside of disposal....Do not turn power back on until finished
Jan 23, 2011 | Dishwashers
The water is still in the bottow of the dishwater and the cycle is in the heating mode. The dial is making noise as if it wants to move forward, but it can't. It stop well before the heating cycle...
Have you recently installed a garbage disposal? If so, you probably didn't knock out the plug where the drain hose from the dishwasher attaches to. Just disconnect the hose from the garbage disposal, use a punch or screwdriver and tap it out with a hammer. (Don't forget to remove the plug from the grinder area) Then reconnect the hose.
Jun 24, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
Stopped up garbage disposal. no grinding action when turned on
Hello there:
you will need to make sure that all of the hoses from the unit are free of debris first ok
than if you need to remove the blade assembly and clean out the area around the unit and than reassemble the blades and see what happnes ok if not you will need to remove the entire unit and see what is making the unit malfunction. ok
best regards michael
Aug 27, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
My gargabe disposol won't turn off.
sounds like the wall switch needs to be replaced.
Apr 05, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
GE Nautilus 24" Built-in Dishwasher Logo
51 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
