Question about Delta TP300 Shopmaster 12-Inch Portable Planer
I need to replace the belt on my Delta 12 1/2 inch planner. I have the cover off on the side where i raise and lower the planner.
  • 2,100 Answers
I think the belt is on the other side, put that cover back on, take off the top, take off the gears that lift it, take off the drive side cover, I think the belt is held on with a pulley with a ridge on it, Has to come off, One ridge is going one way to stop it from going in and the other is going the other way to stop it from going out. Now , your planer may be set up a little different, But I think it should be close, If the belt is on the side you have off, just keep going, You will see what I am talking a about. I had the same planer years ago, so they might have changed it. Hope this helps.
Posted on Aug 23, 2010
Delta 22 540 12" planer
in my experience with this planer there isn't a locking mechanism. I have included a link for a parts diagram and you can see there isn't any replacement part for a locking mechanism. I would pull the cover off and see if the screw thread is rusted or seized from non-use over the years. You might oil the bearings at top and bottom of the raising screws!
http://www.ereplacementparts.com/delta-22540-type-inch-planer-parts-c-3275_3571_3577.html
Aug 25, 2013 | Crafts & Hobbies
How do you change the cutter bar bearings on a delta 12 inch planer
You are looking at a major disassembly to get at the cutter head bearings, everything is built around the cutter head. The motor drives the cutter head on one end of it and the cutter head drives the rollers at the other end. Most of the components have to be removed to get the cutter head and it's bearings out. You can go to www.ereplacementparts.com and do a search on your model number for a good breakdown of your planner and see what you need to remove to get at the cutter head and it's bearings.
Sep 03, 2012 | Delta Masonry Tools
Water pump 2000 3.0 liter dodge caravan
For The 3.0 Motor. (3.3 Way down the line.)
Drain cooling system.
Remove timing belt. Refer to Engine for procedure.
Remove water pump mounting bolts.
Separate pump from water inlet pipe and remove water pump.
Timing Belt Removal
Raise vehicle and remove accessory drive belt splash shield (Fig. 66).
Remove accessory drive belts.
Remove crankshaft pulley and damper (Fig. 68).
Support engine and remove right side engine mount.
Remove engine support bracket (Fig. 67).
Remove timing belt covers (Fig. 67).
Mark belt running direction for installation (Fig. 69).
Loosen timing belt tensioner bolt (Fig. 71) and remove timing belt.
Remove crankshaft sprocket flange shield (Fig. 68). CAMSHAFT SPROCKETS To remove camshaft sprockets
Hold camshaft sprocket with Spanner Tool MB-990775. Loosen and remove bolt and washer (Fig. 70).
Remove camshaft sprocket from camshaft. To install camshaft sprockets:
Place camshaft sprocket on camshaft.
Install bolt and washer to camshaft. Using Spanner Tool MB-990775, hold camshaft sprocket and torque bolt to 95 Nm (70 ft. lbs.) (Fig. 70). TIMING BELT TENSIONER
Install timing belt tensioner and tensioner spring.
Hook spring upper end to water pump pin and lower end to tensioner bracket with hook out (Fig. 71).
Turn timing belt tensioner counterclockwise full travel in adjustment slot and tighten bolt to temporarily hold this position (Fig. 72).
INSTALLATION
Install timing belt on crankshaft sprocket and keep belt tight on tension side (Fig. 69). Install belt on the front (radiator side) camshaft sprocket. Install belt on the water pump pulley, rear camshaft sprocket and finally on the timing belt tensioner.
Rotate the front camshaft sprocket in opposite direction to take up belt slack. Check that all timing marks are aligned (Fig. 69).
Install crankshaft sprocket flange (Fig. 68).
Loosen tensioner bolt and allow spring to tension timing belt.
Turn crankshaft two full turns in clockwise direction. Turn smoothly and in clockwise direction ONLY.
Align the timing marks on the sprockets and tighten the timing belt tensioner locking bolt to 28 Nm (250 in. lbs.) torque.
Install timing belt covers.
Install engine support bracket.
Install right side engine mount.
Install crankshaft damper and pulleys (Fig. 68). Tighten damper center bolt to 135 Nm (100 ft. lbs.) .
Install accessory drive belts.
Install accessory drive belt splash shield (Fig. 66).
Be sure to also replace all the cam and crank seals why you are there. Might as well put a belt on too.
FOR THE 3.3 OR 3.8 MOTORS.
Drain Cooling System.
Remove accessory drive belt.
Remove right front lower fender shield.
Remove water pump pulley bolts and remove pulley.
Remove water pump mounting screws. Remove water pump.
Remove and discard O-ring seal.
Clean O-ring groove and O-ring surfaces on pump and chain case cover. Take care not to scratch or gouge sealing surface
Installation
Install new O-ring into groove.
Install water pump to chain case cover. Tighten screws to 12 Nm (105 inch lbs.) .
Rotate pump by hand to check for freedom of movement.
Position pulley on pump. Install screws and tighten to 30 Nm (250 inch lbs.) .
Install accessory drive belt.
Install right front lower fender shield.
Refill Cooling System.
FOR THE 2.4 MOTOR
Disconnect negative cable from battery.
Raise vehicle on a hoist. Remove right inner splash shield.
Support engine from the bottom and remove right engine mount.
Remove right engine mount bracket.
Remove timing belt idler pulley.
Hold camshaft sprocket with Special tool C-4687 and adaptor C-4687-1 while removing bolt. Remove both cam sprockets.
Remove rear timing belt cover.
Install new O-ring gasket in water pump body O-ring groove. CAUTION: Make sure O-ring is properly seated in water pump groove before tightening screws. An improperly located O-ring may cause damage to the O-ring and cause a coolant leak.
Assemble pump body to block and tighten screws to 12 Nm (105 inch lbs.) . Pressurize cooling system to 15 psi with pressure tester and check water pump shaft seal and O-ring for leaks.
Install rear timing belt cover.
Install camshaft sprockets and torque bolts to 101 Nm (75 ft. lbs.) .
Install timing belt idler pulley and torque mounting bolt to 61 Nm (45 ft. lbs.) .
Install timing belt. Refer to Engine for procedure.
Install right engine mount bracket and engine mount. Refer to Engine for procedure.
Fill cooling system.
Lower vehicle and connect battery cable.
Mar 29, 2012 | Cars & Trucks
How do I replace the drive belt on my dewalt planer
Hi ladyccowboy1,
The drive belt is on the side with the handle (you might already know that :>)).
Take the top off, then remove the lifting gears. Remove the side cover. You'll see the cutterhead pulley that has ridges on it to keep the belt from moving in and out. Remove the pulley.
Change your belt and reassemble.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 24, 2011 | Delta TP300 Shopmaster 12-Inch Portable...
93 accord timing belt installation
  • Car jack
  • Jack stands
  • Torque wrench
  • Chain wrench
  • 3/8 inch drive ratchet
  • 1/2 inch drive ratchet
  • 10 mm wrench
  • 12 mm wrench
  • 10 mm socket (3/8 inch)
  • 14 mm socket (3/8 inch)
  • 17 mm socket (1/2 inch)
  • 19 mm socket (1/2 inch)
  • Timing belt
  • Balancer belt
  • Bottle of Liquid Paper
  • Disconnect the negative battery terminal. Using a ½-inch-drive ratchet and the 19 mm socket, turn the center bolt on the crankshaft so that number-one cylinder piston is at top dead center (TDC). You will know you ware at TDC when the mark on the crank is in alignment with the arrow on the timing cover.
  • Disconnect the cruise control connector and remove the cruise control actuator. Loosen the upper mounting bolt with the 14 mm socket. Use a 12 mm socket to loosen the lower nut then use a 10 mm socket to loosen the adjuster from the power steering pump and remove the belt.
  • Loosen the upper air conditioner mounting bolt using the 14 mm socket. Use the 12 mm socket to loosen the lower nut and adjusting bolt on the alternator and remove the alternator/AC belt. Remove the valve cover using a 10 mm socket.
  • Place the jack behind the left front wheel where the arrow is located indicating the jack location, and raise the vehicle. Put the jack stand under the subframe behind the jack, then lower the jack. Remove the left front wheel for easy access to the crank pulley. Using a block of wood atop the jack, place the jack under the oil pan and lift with slight pressure to hold the engine in place. Remove the side engine mount using a 17 mm deep socket.
  • Take off the dipstick, pipe tube and upper timing cover using a 10 mm socket.
    Then remove the timing belt adjuster rubber seal without loosening the adjuster nut. Take off the crankshaft pulley bolt. Use the chain wrench to hold the the crankshaft pulley while turning the crankshaft pulley bolt with a 19 mm socket. Use the 10 mm wrench and 10 mm socket to remove the bolts on the lower cover. Remove the lower cover and mark the location of the cam, crank and balancer shaft with Liquid Paper. Remove the balancer shaft belt and timing belt. Install the timing belt and the balancer shaft belt in the reverse order of removing them. During Installation of the crank pulley, coat the threads of the crank pulley bolt with engine oil and tighten it to 159 foot-pounds. Finally, adjust the tension of the power steering and alternator belts as well.
    Feb 03, 2011 | 1993 Honda Accord
    Drive belt for planer epn 7582 n to replace a broken one
    if you need a part check tool parts direct. if you have the belt, pull the side off opposite the handle that raises and lowers it. you have to roll the old belt off and then you have to roll the new one on. it will be tight and hard to do. if it isn't, there is something loose and that is not good.
    Aug 31, 2010 | Delta TP300 Shopmaster 12-Inch Portable...
    How to put a starter on
    3.8L Engine
    1991-92 VEHICLES
    1. Disconnect the negative battery cable.
    2. Remove the right side cooling fan.
    3. Remove the serpentine drive belt, as outlined in of this repair guide.
    4. Disconnect the A/C compressor upper support brace, then lay the compressor in the fan opening.
    5. Raise and safely support the vehicle.
    6. Detach the engine oil cooler lines at the flex connector.
    7. Unfasten the retaining bolts, then remove the flywheel inspection cover.
    8. Remove the starter motor retaining bolts, carefully lower the starter and remove the shims, if used.
    9. Detach the starter motor wiring, then remove the starter from the vehicle.
    Fig. Fig. 12: Starter motor removal and installation-1992 3.8L engine shown
    To install:
    1. Attach the electrical connectors to the starter terminals. Tighten the battery terminal nut to 80 inch lbs. (9 Nm) for 1991 vehicles and to 12 ft. lbs. (16 Nm) for 1992 vehicles. Tighten the "S'' terminal nut to 27-35 inch lbs. (3-4 Nm).
    2. Position the starter motor and shims, if used, to the engine and tighten the mounting bolts to 32 ft. lbs. (43 Nm).
    3. Install the flywheel inspection cover. Tighten the retaining bolts to 89 inch lbs. (10 Nm).
    4. Attach the engine oil cooler lines at the flex connector.
    5. Carefully lower the vehicle and position the A/C compressor.
    6. Install the A/C compressor upper support brace.
    7. Install the serpentine drive belt, as outlined in of this repair guide.
    8. Install the right side cooling fan
    9. Connect the negative battery cable.
    Fore other engine and sub-models, review autozone.com (free register).
    Hope helped with this (remember rated this help).
    Oct 29, 2009 | 1992 Chevrolet Lumina
    How to change belt
    THERE IS A LITTLE HANDLE AT THE SIDE
    PUSH IT UP THEN TAKE OUT THE OLD ONE
    AND REPLACED
    May 10, 2009 | Delta DP350 Shopmaster 1/3 Horsepower 12...
    LOWER LEFT TRACK - FOR RAIL TO RAISE AND LOWER.
    I have a Delta 5 in 1 Crib and I am having a hard time keeping the side rail up on the left side...... Pin doesn't seem to be working! How can I fix this very soon due to my second lil one on his way soon?????
    Jun 06, 2008 | Delta Luv Delta - Baby Products 5-in-1...
    Delta TP300 Shopmaster 12-Inch Portable Planer Logo
    94 people viewed this question
    Top Delta Masonry Tools Experts
    ray gallant
    Tom Chichester
    Are you a Delta Masonry Tool Expert? Answer questions, earn points and help others
