Boot manager compressed
I stupidly started compressing hard drive to save space and i shut computer down before it was finished now when i try to start computer i m in a loop boot manager compressed press cntrl alt del ,i cant get get into safe mode with F8 my comp is ASUS A6000k any ideas ican get into bios and thats all
You are stupid!!! of course there is another way!!!!
http://answers.yahoo.com/question
/index?qid=20080612115923AAgIovt
Guru my ***!!!!
Posted on Jan 17, 2009
I accidently compressed the hard drive and now my boot manager is compressed and it will mot boot up what can I do to retrieve the back operational
Posted on May 05, 2009
  • 86 Answers
Sorry to tell, format and reinstall everything, next time if you need space upgrade hard drive or buy an external HD
Posted on May 04, 2008
  • darrenlms Sep 18, 2010
    How do I format my drive?
Why does it take my computer a long time to boot up, loading, and shutting down?
indicates that then hard drive is on the way out
first step is to save everything onto an external hard drive
then take it to a computer repair shop for an inspection
check how much space is on the hard drive because if you have a lot of junk on it , that slows down the start up and shut down p[rocesses
you can go to device manager and do a defrag of the hard drive to free up space
Aug 09, 2017 | Time Computers & Internet
Boot manager compressed press ctrl+alt+del
Causes of BOOTMGR Errors
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source.
This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
Make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs
Data and Power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error.
also make sure you have set it boot from you hard drive in BIOS
Restart your computer and enter BIOS mode.
On most computers this is done by pressing the Delete ot F2 key but will vary depending on your computers bios other keys Acer: - Ctrl+Alt+Esc , ALR PC: (F2) or (Ctrl)(Alt)Esc) , Award BIOS: (Del) or (Ctrl)(Alt)(Esc).
Scroll over to the "Hard Drives" tab, and make sure your computer has the hard drive assigned to be on.
Often during BIOS you can select auto-detect or change options with your hard drive to make sure Windows can recognize it.
Once you've selected your desired options, continue to boot.
or
The solutions might be very simply... remove your hard-disk and attached to other PC or laptop as an external hard-disk.
When it is detected, go to my computer, right-click, untick that (stupid) option, immediately you see the message uncompressing and its done.
Put your hard-disk back in to your machine its ready..
w7
insert your OS CD
go to DOS window and type in your OS driver (usualy C:/
type in bootrec /FixMbr
then type in bootrec /fixboot
then type in bootrec /rebuildbcd
then type in exit
restart your computer
it will work 100% only if you prompt at the same order
Hope this helps.
BOOTMGR Is Compressed
The Windows operating system allows you to compress the files on your drive to conserve disk space.
In some situations, this compression process will compress files required for the operating system to boot.
Files that are compressed must be decompressed prior to execution.
Since the operating system has not loaded, boot files cannot yet be decompressed.
In this case, the operating system will fail to load and a "BootMgr is compressed" message will appear.
An easy way around this problem is to boot from the Windows DVD, and use the provided interface to access your drive properties and decompress it.
Turn on the computer, and insert your Windows DVD.
Press a random key on your keyboard once you see the "Press any key..." message.
This interrupts booting from the hard drive and forces a boot from the Windows DVD.
Click the "Next" button at the bottom of the Windows 7 dialog, and then click the "Repair your Computer" link Below.
http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7
http://msdn.microsoft.com/en-us/library/aa364219(v=vs.85).aspx
File Compression and Decompression
Select the "Load Drivers" button at the bottom of the "System Recovery Options" dialog, and click the "OK" button on the "Add Drivers" dialog.
This opens a file browser on your screen.
Click the "Computer" icon, which is located on the left hand side of the screen.
This displays an icon for your disk drive.
Right-click your hard drive, and click "Properties.
" This opens a Local Disk Properties dialog.
Click to deselect the "Compress this drive..." option at the bottom, and then click the "Apply" button.
Select the "X" icon to close the file browser window.
This takes you back to the Install Windows dialog.
Press the "X" icon at the corner of the Install Windows dialog.
This opens a cancellation dialog. Select the "Yes" button on this dialog to restart your computer.
Aug 06, 2013 | Computers & Internet
My bootmgr is copressed.
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from. make sure there are no disks in cd floppy usb drives Test all power and data leads that attach to your hard drive IDE,SATA the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat ribbon 40 pin IDE it will be the fist to fail Make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs Data and Power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error. also make sure you have set it boot from you hard drive in BIOS Restart your computer and enter BIOS mode. On most computers this is done by pressing the Delete ot F2 key but will vary depending on your computers bios other keys Acer: - Ctrl+Alt+Esc , ALR PC: (F2) or (Ctrl)(Alt)Esc) , Award BIOS: (Del) or (Ctrl)(Alt)(Esc).
Scroll over to the "Hard Drives" tab, and make sure your computer has the hard drive assigned to be on. Often during BIOS you can select auto-detect or change options with your hard drive to make sure Windows can recognize it. Once you've selected your desired options, continue to boot. or The solutions might be very simply... remove your hard-disk and attached to other PC or laptop as an external hard-disk. When it is detected, go to my computer, right-click, untick that (stupid) option, immediately you see the message uncompressing and its done. Put your hard-disk back in to your machine its ready.. w7 insert your OS CD
then type in exit
it will work 100% only if you prompt at the same order Hope this helps. BOOTMGR Is Compressed b> The Windows operating system allows you to compress the files on your drive to conserve disk space. In some situations, this compression process will compress files required for the operating system to boot. Files that are compressed must be decompressed prior to execution. Since the operating system has not loaded, boot files cannot yet be decompressed. In this case, the operating system will fail to load and a "BootMgr is compressed" message will appear. An easy way around this problem is to boot from the Windows DVD, and use the provided interface to access your drive properties and decompress it.
Turn on the computer, and insert your Windows DVD. Press a random key on your keyboard once you see the "Press any key..." message. This interrupts booting from the hard drive and forces a boot from the Windows DVD. Click the "Next" button at the bottom of the Windows 7 dialog, and then click the "Repair your Computer" link Below. http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7 http://msdn.microsoft.com/en-us/library/aa364219(v=vs.85).aspx File Compression and Decompression Select the "Load Drivers" button at the bottom of the "System Recovery Options" dialog, and click the "OK" button on the "Add Drivers" dialog. This opens a file browser on your screen. Click the "Computer" icon, which is located on the left hand side of the screen. This displays an icon for your disk drive. Right-click your hard drive, and click "Properties. " This opens a Local Disk Properties dialog. Click to deselect the "Compress this drive..." option at the bottom, and then click the "Apply" button. Select the "X" icon to close the file browser window. This takes you back to the Install Windows dialog. Press the "X" icon at the corner of the Install Windows dialog. This opens a cancellation dialog. Select the "Yes" button on this dialog to restart your computer. Hope this helps
b>
Jan 15, 2013 | Dell Mini 910 Netbook
Boot manager compreessed
Sadly the startup repair option or any other repair option in windows 7 startup recovery failed to solve this problem. this can be solved by
reboot your pc
select the repair your computer option
command prompt
at the prompt type notepad (since the recovery option boots from a seperate wim image it has notepad built into it )
press ctrl + o which invokes the open file dialog
go to the open file field (ALT+N) and type c:\boot and also see for the c:\bootmgr
file. right click it and deselect the option of "compress files to save disk space"
when we apply the boot manager is again decompressed. also if someone finds this harder we can directly deselect the compression option by reversing the process used to compress the drive
thats it . we are done
Apr 16, 2011 | Computers & Internet
Does storing a lot of pictures on my PC cause it to run slower?
It could, depending on how large your hard drive is. Side note, if these are important, back them up so you won't lose them.
One way to save space is to put your hard drive in a compress mode.
Go to start, computer, select the hard drive, right click then under properties click the box that says "compress to save space". It will save space and also help it run faster.
Oct 17, 2010 | Dell Dimension 4600 PC Desktop
Boot manager is compressed
Go ahead and try to restore your Operating Systerm with whatever disks the manufacturer came with the computer. As an aside though, the need to compress a drive with multiple gigs of space anyway ... overkill? If you do not have the disk, use any OS startup, XP/Vista/Win7/ whatever OS you prefer. You did not state the HD size, but the compression (and consequent uncompression) will slightly slow down processing after all is done. Good Luck !!! More questions, jaye.ellen@gmail.com
Apr 21, 2010 | Gateway MX6959 Notebook
BOOTMGR is compressed press Ctrl+Alt+Del to restart
Insert Microsoft Windows Vista Installation Disc.
Press any key when it says "Press any key to boot from CD".
After that you should see "Windows is loading files..."
KEEP pressing F8/F9(can't rmb which, just press both alternately) while
the progress bar loads..... Dun let go until you reach "Advanced boot
information" where you should see Safe Mode, Safe Mode with Networking,
Last Good known configuration etc...., just select Safe Mode with
Networking(or Safe Mode/Safe Mode with Command Prompt) and press Enter.
Wait for the files to load and there should be "Safe Mode" on 4 corners
of your monitor.
Just be patient and wait. A windows would soon pop up and says "Install
Windows". Don't worry, click next. Now at the bottom of this window, you
should see "Repair Windows". Click on it, and there are several options
available here. For this case, which is "Bootmgr is compressed.", CHOOSE
THE LAST OPTION - "Start Command Prompt".
OK type these things (Only works if you have Firefox, can't think of
anything else) below and follow closely:
When Command Prompt is started, type the command below first to ensure
that C Drive or whichever drive which contains all your system files is
selected:
LOOK FIRST!
X:System> (The string on the left is what appears on command prompt,
may differ on other computers.)
Now TYPE "C:" or "D:", depending on the hard disc volume you are
using...
SO IT BECOMES:
X:System>C:
PRESS ENTER
THE RETURNING COMMAND WOULD BE:
C:>
If you get this, very good, continue with the steps below.
Now Type:
CDProgram FilesMozilla Firefox
PRESS ENTER
THE RESULT SHOULD BE SOMETHING LIKE THIS:
C:>CDProgram FilesMozilla Firefox (Press ENTER)
C:Program FilesMozilla Firefox (<<<<< Result)
Now type "firefox".
wait for Firefox to launch now.
it doesn't matter if no internet is available.
Now on firefox, go to File > Open File
Double click "My Computer", and you should see your hard disc there,
but don't double click on the hard disc. Instead, click once on the hard
disc, RIGHT CLICK, and choose properties. AT THE BOTTOM, UNTICK, I
REPEAT, UNTICK THE BOX SAYING "Compress this drive to save space
etc....". NOW CLICK APPLY, WAIT, AND I MEAN WAIT PATIENTLY OK? AFTER
THAT CLICK ON "OK".
AFTER PRESSING OK, DO A QUICK LOOK AT YOUR DRIVE BY DOUBLE-CLICKING IT
NOW. IF ANY FILES/FOLDERS ARE BLUE IN COLOUR INSTEAD OF BLACK,
RIGHT-CLICK IT, CHOOSE PROPERTIES, CLICK ADVANCED BUTTON (Beside
Read-Only Box and Archive Box), UNTICK, I REPEAT, UNTICK the 3RD BOX
Which says "Compress contents to save disc space".
Click OK, Apply and close the folder/file properties.
Now close the box opened by firefox, close firefox, close command
prompt AND AT THE BOTTOM RIGHT OF THE FIRST WINDOW WHICH POPS UP
MENTIONED EARLIER, PRESS RESTART.
for xp:
Boot Manager is compressed
If by accident having compressed the entire boot partition, then Vista will display the following error:
BOOTMGR is compressed. Press Ctrl+Alt+Del to restart
Check points for fixing compressed boot-manager:
* Boot into Windows Recovery Environment (WinRE) and perform a “Startup Repair”.
* If the above doesn’t solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press “Load Drivers” (Instead of “Next”) and use the mini Windows Explorer to right-click the boot-drive and deselect “Compress this Drive” and choose Apply to sub-folders and files.
* If that also fails then boot into WinRE again, and go to the “Command Prompt” and execute these commands:
o compact /U C:ootmgr
o compact /U C: tldr
Mar 30, 2010 | Compaq Presario 700 470024-192 Notebook
I load parallel (vistas) on my macbook pro but the space for it got full too quickly. I compressed the C drive and after the first reboot it did't want to bootup all the way. saying bootmgr is compressed...
If you can slave the drive into another computer or laptop and go to that drive through My computer,you right click on the drive and go to properties and you will see a box way at the bottom(under general) that says "Compress drive to save disk space" ,it probably has a checkmark in it from when you chose to compress it...take out the checkmark and click apply,then ok.Power down the computer and remove the drive and put it back into the original laptop(computer)..making sure all your cables are reconnected,then power up and it should boot back to normal.*Note*..make sure the jumpers to the hard drive you are working with are set to slave then back to master when going to slave in the other computer and back to master in the main computer,this applies to IDE hard drives.If you are using USB(sata) drive,then your computer should decide automatically whe you plug the drive in to make the changes.Please let me know how you make out,or,if you have problems with the proceedure..I will be happy to help you further if needed:)
Mar 20, 2010 | Apple MacBook Pro Notebook
My lab top hard memory is parted in c and d and I am running out of space in c drive. How to put them together
1. Go to the Start menu and open Control Panel
2. Select the System and Maintenance option if you are using the Control Panel Home View and Administrative Tools if you are using the Classic View
3. In the Administrative Tools section, select Create and format disk partitions.
4. For Classic View users, select the Computer Management option and select Storage. When done, click Disk Management
5. When the list of your drive is displayed, choose the one with which you want to merge your partitioned drive with (e.g. disk D:) and select Delete Volume.
6. Hence, select your drive C: and the option Extend Volume. You computer will automatically select empty available spaces on your hard disk, and you can alter them if you wish to do so.
Regards.
Sep 30, 2009 | Computers & Internet
HP NC 6000 windows 2000
1st try last known good configuration
if that doesn't work
then get the setup cd. start the setup and press r or enter repair console when asked. it asks for your password, login, then run chkdsk make sure it does the check even if it says the disk is marked clean. I dont remember which switch it was you can see them with chkdsk /?
Do that and try starting windows again.
If that failes do a repair install from the windows setup.
Jun 08, 2008 | Microsoft Windows XP Professional
Computers & Internet Logo
3,087 people viewed this question
David Payne
David Payne
