Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
My oven suddenly does not work. The power works and the range works.
  • Kenmore Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on Aug 23, 2010
Testimonial: "Thanks, I believe you are correct. I'll replace it."
Stove top want heat up
the bulb i am sure is ok . but you have had a power failure to the burner . it could be the burner itself . if all the burners do not work the power to the range may be the problem .. ck the main fuse and make sure the 220 power is ok mm
Jul 12, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My Frigidaire Oven display panel won't come on all of a sudden. Burners and oven light work. It could be from a surge in electricity. How do I 1) check fuses or breaker? Where are these located? How could...
If the burners and oven light are working, then you have power coming in. It's most likely a defective EOC. If you haven't tried turning off the circuit breaker for 5-10 mins to reset any glitch associated with a surge or spike, do so. If this doesn't reset the control, the EOC will need to be replaced.
Jan 05, 2018 | Frigidaire 30" Self-Cleaning Freestanding...
All stove top elements and oven wont work
Go to your home circuit/fuse panel and reset the fuse or circuit breaker for the range.
Dec 30, 2009 | Frigidaire FEB27S5A Electric Single Oven
Oven not coming on/heating up although top plates are working
If the burners are heating up but seem to take along time to get up to heat and your oven doesn't seem to be working you may have only 115 volts of power going to the range rather than the full 240 volts that are needed to power up the bake/broil oven elements.Check circuit breaker(s),check range receptacle behind the range for 240 volts,check for full power at the terminal block on the back of the range where the cord connects to the range.Good luck!
Nov 22, 2009 | Smeg Ovens
Oven elements suddenly quit
check your power supply for 240volts, at your service panel and have it checked at the range thats the easiest step to start with and if both elements are that way thats what it sounds like now,theres no internal fuse I know about.
Jul 23, 2009 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
My front left burner on elec.range model FEFL67GCA does not work.
If it's just quit all of a sudden then I assume it's burned out.You will have to remove the glass top to get to it. The new burner has two wire connectors that plug in. CAUTION: Make sure you disconnect electrcal power to the stove before working on this!
Apr 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
GE XL44 oven not working, but the broiler is...???
CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
Jan 28, 2009 | GE JGRP17 Gas Single Oven
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
396 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
