Question about Whirlpool Duet GHW9150P Front Load Washer
Get code 02 F - what does that mean? - Whirlpool Duet GHW9150P Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 23, 2010
My stove is flashing F7 02 CODES With constant beeping.
First things first. Brand and Model number. Although most fault codes have are similar across major appliances it is necessary to find a correct solution.
Apr 06, 2016 | Kitchen Ranges
WHAT DOES 01/02 MEAN WITH FAULT CODE PO300 01/02
Not sure on at code reader..
But usually 300 is random/multiple misfire
And if u mean 01/02 as in 301/30 then those are the cylinder w issues..hope that helps alitle
Sep 17, 2014 | Autel MaxiScan MS509 OBD-II-EOBD Scanner...
Code F-02 on hotpoint WT960
Check and clean the filter and drain hose. Make sure the hose isn't kinked.
Apr 22, 2012 | Hotpoint Ultima WF860 Front Load Washer
Replaced:plugs,wiresdistributor,fuel pump.truck wouldn't start before but now it starts but i am getting po135,po141,po147.po300 codes
P0135 means 0xygen heater circuit malfunction, P0141 mean 02 heater circuit bank1 sensor 2 (this is catalytic monitor) P0147 means 02 heater sensor circuit bank 1 sensor 3, P0300 is random misfire. You will get all the 02 code because of the misfire correct the misfire and the 02 should correct.We will start with the plug wire and make sure the firing order is correct 1996 chevy blazer that will make it a 4.3 engine size check the firing order firing order is 165432 also check the coil (it has a tendency to short you will know if it is) cansmo_181.gifcansmo_182.gifmake sure the distributor rotation is check
Sep 09, 2011 | 1996 Chevrolet Blazer
O2 sensors keep failing and a evap leak code i put new gas cap did not cgehan ssomers11@gmail.com
Are you sure it's 02 sensors? Just because code says 02 sensors doesn't necessarily mean they're bad. Bad 02 sensor code can also indicate bad cat. converter. If 02 sensors read exact same reading before and after converter they will trigger OBC to "sensor fault" - they should be reading 2 different readings. (Pre CAT/POST cat) I'd suggest replacing cat converter before replacing sensors.
Mar 14, 2011 | 1999 Toyota Camry Solara
What do the codes 1128, 1129, 1133, and 1134 mean on my Porsche Boxter 2001?
code P1128 02 sensor bank 1 lean
code P1129 02 sensor bank 1 lean to limit
code P1133 02 sensor bank 2 lean
code P1134 02 sensor bank 2 lean to limit
fuel system is lean.
Jan 29, 2011 | 2001 Porsche Boxster
Sony UVW-1800 error message: 02-274 -- What does this mean?
I found a site where the error code are.
http://z.baidu.com/question/97641503.html
02-274 Failed to detect the T reel FG during threadingI hope this helps
Sep 26, 2009 | Fuji M321SP Betacam Tape
Code P0157 and P0137
Hi P0157 is
02 sensor circuit low voltage bank 2 sensor 1
P0137
02 sensor circuit low voltage bank 1 sensor 2
May 06, 2009 | 2000 GMC New Sierra 1500
'02 civic engine code P0420. What does this mean?
it means your 02 sensor pre cat is not working or the cat is no longer any good start with the 02 sen its easy to do and cheaper than the cat
Feb 19, 2009 | 2002 Honda Civic
Avh-p5900dvd... I keep getting error -02-9e and it wont play cd,s or dvd,s can you help.
Owner's manual doesn't really say what the -02-9e error code means other than a disc error. They do recommend resetting the unit as a possible solution:
  1. Turn the ignition off.
  2. Remove the faceplate.
  3. On the right side of the front of the head unit (with the faceplate removed), press the reset button with a ball point pen.
You may have to call Pioneer directly to find out what the -02-9e code means specifically. 1-800-421-1404
Apr 03, 2008 | Car Audio & Video
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
