Question about Hitachi 43UWX10B 43" Rear Projection Television
Picture arrey is off try to re align according to manual but nothing happens realignment with remote
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
IT means the two convergence chips need to be replaced.
There are also some resistors around them that need to be looked at. I will attach photos of what parts look like etc.
SET SHOULD USE EITHER TWO OF THE STK-392-110 OR 120 CHIPS---NUMBER WILL BE ON FRONT OF PART.
TOTAL PARTS COST ON EBAY will be under 20 dollars.
Two versions of set : one uses removable board like in photo and other is more difficult.
If pictures or information helped you rate this solution as very helpful as I do this here for free.
SD TECH
NOTE RESISTORS WITH BLACK IN MIDDLE--ABOUT 10 OFpicture arrey is off try to re align according to - 4148a1a.jpgASY TO CHECK.
Posted on Aug 23, 2010
I need to know how to align timing belt and balancer shaft belt on 2.2 honda engine
I had the same problem with my 92 Accord I found an arrey of helpful videos on this I typed in, (92 accord timing belt.)
May 17, 2012 | 1991 Honda Accord
Whilst the cd drawer was in the open position I caught it with my knee leaving the drawer on an angle. When I press the close button nothing happens and any attempt to close manually is met with...
drawer is out of alignment...some players have timing marks to align the gears(similar to engines)...but without a service manual..it may be complicated...you can try to realign the drawer...there is a limit switch that tell the player when the drawer is fully open and one that tells the player when it is fully closed....a good way to try to realign is to move the drawer one tooth at a time and trying it..until it lines up
May 26, 2011 | Marantz PMD320 CD Player
Picture is unclear color are off
there are a few things you might be able to do. First I would try the auto focus or alignment feature of the set. there should be a option in menu to realign the lamps.
May 24, 2010 | Sony KP-51HW40 51" Rear Projection...
Picture colors are seperated on my tv. the sound
Hi i did not want go to far whit this//
usely you will have to replace the convergence module there are 2 stk ic on it,and then use the magic focus button on the front panel/ if it not fix back your color alignement you will have to do manually whit the remote control.
but that needs some experience to do so...
hope that help ,its give a idea
have a nice day
Mar 18, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My printer will not auto align and will not print a complete grid when I try to align it myself. Currently I get nothing when I try to print and my ink tanks are all full
www.devicemanuals.com/.../Canon/Canon-Multifunction-Injet-PIXMA-MP780-User-Guide-TkRBNU1UVT.html
safemanuals.com/annexe_Setup%20Instruction_CANON_PIXMA%20MP780-_E.htm
office.manualsonline.com/manuals/.../canon/canon_pixma_mp780_9791a004.html
You can copy and paste any of these links in your internet address bar under a new tab to take you to your manual page.
You will need to realign the alignment, and print an alignment page. Or reset printer.
Oct 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
HTC Touch Diamond screen alignment
Hi
with the one i have, i have to take the battery out leave it for ten minutes and try again- if that doesnt work do it again -
get someone to phone you - try and tap the settings.
If this doesnt work - try the above again -
after 3 /4 times you will be able to get into settings and realign......
cheers
Sep 11, 2009 | HTC Touch Diamond Smartphone
Double image, fuzzy picture
The problem was caused by poor projector alignment. Alignment was off because we recently moved the TV from a friends house.
This particular set allowed me to realign the projectors with the remote control from a setting in the TV's menu. It was as simple as opening the menu item then aligning the cross-hairs with the remotes cursor. There are 3 projectors, one for each color. One is fixed and the other two are movable. They need to be perfectly aimed in order to get a clear, properly colored image.
When you find yourself with an electronic device and no operators manual it pays to spend the time and effort to download it from the internet.
Problem solved, thanks
C L Ganske.
Apr 11, 2009 | Televison & Video
My Toshiba SE-R0161 Remote no longer works.
There is most likely nothing wrong with your remote. I just had exactly the same issue with my SE-R0161 remote. (I had just changed my remote batteries too and was getting a DR-2 code on the Toshiba DVR RD-XS52 unit's display.) My DVR and my remote had to be realigned so that they both have the same infared (IR) code. The remote and the DVR can have DR 1, DR 2 or DR 3 as remote codes. Pg 54 of the Toshiba Installation Manual explains how to align both your SE-R0161 and your based unit so that the remote works again. Good luck. Hope this helps.
Mar 27, 2009 | Televison & Video
The colors are red blue lime green and the screen shows a double picture
Hi, The most likely cause of this problem, the color guns is out of alignment. Rear Projection Televisions often go out of alignment over time. Your television "should" have an automatic alignment function within the Television Setup Menu. Since you did not provide the model number, I cannot give you specific instructions on how to re-align the unit. Check the user’s manual or contact the Television for instructions on how to automatically realign your television. Thanks, Mike H.
Nov 01, 2008 | Televison & Video
Placement of crt coils on HCN653W
unless you are real good at this you will be treading on thin ice you always have 1 as a reference
you replace or service 2 tubes then realign them to the reference once done you replace the third and align to the first 2. you never need to replace the coolant and it is only a job for an expert as a bad seal here will cause the coolant to leak out onto the neck and then down to the crt socket.. this will short out the high voltage and your troubles will have just begun. you will need to realign this from scratch now.
Oct 07, 2008 | Samsung HCN653W 65" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
26 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
