Question about Troy Bilt Tb70ss Gas Trimmer
The rope broke to my troy bilt wed eater and when I put it back together it ran for a little while and suddenly died. I can't seem to get it to start again, do you have any ideas?
    President:
  • Troy Master
  • 1,545 Answers
You have to start with the basics and by process of elimination work your way up from there. This machine NEEDS to have 4 things to start:
1. Compression
2. Good strong spark (blue in color)
3. Fresh clean fuel
4. Clean air supply to engine.
If you are sure these 4 things are up to par, then you can proceed with a more detailed and comprehensive evaluation of the problem. From experience....I will say it probably is a fuel delivery problem....but is the fuel fresh? Is there a nice strong Spark? Is the fuel filter clean and working (in the fuel tank)? Is the air filter nice and clean? All these things affect the machines ability to EVEN start up, much less run right. For my money, if the machine has several hours on it...it could be carboned up or it could need the carb rebuilt...or it could need the air gap to the ignition module re-adjusted....see what we are up against?
Posted on Aug 23, 2010
Why does the weed eater not trim even though it spins?
it is getting hot from friction because you cannot tighten it so the head spins but everytime it hits a wed it tries to stop spinniing because it is slipping from the bolt not tightened. fix the bolt hole with a tap and put in a new bolt
Jul 14, 2015 | Troy-Bilt Troy-Built Gas String Trimmer...
Hard pulling starter rope
You say Pull rope mechanism is ok, How do you know that? Ive's seen them get the rope a little off and gets caught being wedged into a small clearance. Is the rope wearing? I bet if you take it apart put a new nylon rope and some wd-40 in rubbing surfaces including the ratchet area it will be good as new. Crank bearing has to get really bad to effect pull. How is the spark?
Mar 13, 2015 | Troy-Bilt Troy Bilt Chipper Vac Plus Parts...
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
How do i fix my flooded TB32 EC troy bilt weed eater?
be sure fuel filter is on the primary fuel line in the tank.check primer bulb and fuel lines.also check fuel tank cap.vented cap may be stopped up
Sep 10, 2012 | M T D Southwest Inc Troy-Bilt TB32EC...
Rope pull start rope is stuck on Troy-Bilt weed trimmer
There should be 3 screws holding the cover on. Take those out and pull the cover off. The is a spindle and spring on the inside. rewind the cord and put it back together with the spring tabs in place. The tabs tend to come undone.
Apr 24, 2011 | Sport & Outdoor - Others
Pull mower rope on troy built self propelled mower and it jerks it back out of your hand,hard,,and will not start
This sounds like the engine is out of time.
Usually this happens when the blades hit something hard and shears a small aluminum"key" between the crank shaft and the flywheel.
This is reparable. The little key is less than a buck. A person needs some skills to remove the flywheel to replace the "key".
Wayne
Jul 30, 2010 | Troy Garden
Pull string for Weed Eater Featherlite Plus came out
If you have the starter spool out (the one the rope goes in)...Here is what to do. Take the starter spool and change the rope out putting it back exactly as it was. Leave the rope hanging. Hold the spool and set it down on the rewind spring. Turn the spool on the rewind spring until you feel it is tight enough. While turning, hold the rope in the little slot in the spool so it can go around without hanging up. Once it is tight, get the rope in line with the spool opening and SLOWLY let the rope rewind. Put on the handle and put the unit back together.Good luck...Lee
Sep 06, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy bilt string trimmer starter rope
you need to rotate the starter pulley up first to tension the spring.... then feed in your rope tie a not and let it retract the rope into the starter pulley
Aug 06, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
I have a Troy Bilt TBP6040 XP 4 cycle weed eater with the spring assist starting. The pull cord broke and I am trying to replace it but I can't seem to get the cord to go all the way back in. I need help....
I just had this same issue. I found out that you have to take the cord out of the handle then put the spool in. You then rotate the spool back in and align the spool with the spring and fish out the cord which will put a small amout of tension on it. You keep the tension on it and put the handle back on.
Rgds,
Mark J
Apr 16, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My TB475SS starts and then dies right away. i
It usually wont idle very well when it's cold, Goto #1 on the choke give the rope a couple of "quick" tugs, and then move it to #2 Give it one or 2 more tugs with a little throttle, now it should be running witha little throttle, let it run like that for a minute then move it to #3 kinda still pumping the throttle a little and it should take off fine. If this is the 4 stroke, mine did the same thing until it was broke in good. (About 4-5 uses), now I have to say its more reliable than any 2-stroke I've owned and I use it commercially. 1st or 2nd pull everytime and is ready as soon as it fires! Hope this helps!
Apr 14, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy Bilt Tb70ss Gas Trimmer Logo
47 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
