Question about GE Profile Spectra JGBP90 Gas Kitchen Range
I had a spill in the oven and the bottom ignitor went out. The stove works fine, the broiler works fine. However, I cannot get the oven to work. I have located the ignitor and tried to light it with a match but I cannot light it. Not sure if the ignitor is works with electric or gas. This is a gas range.
  • GE Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on Aug 23, 2010
My oven is not working The Broiler works and the stove top works fine but the oven will not heat and when you turn it on no gas comes out I tried turning it on and using a lighter but nothing happens
You gave us good clues in information!-- Thanks!
Most modern gas ovens have a device called a Glow Ignitor to light the burner.
If this ignitor has filed, it will NOT left the gas valve open-- (Good thing, right? :-) )
You say the broiler lights fine-- so let's observe something when the Broiler lights:
Do you see a bright glow near the Broiler burner?
(Usually toward the top rear of the oven--)
Well, you should see a similar bright glowing near the BOTTOM rear of your oven, for the main burner to light off-- If you do NOT see this glowing-- then you need a new ignitor-
You can remove the bottom burner cover, and dig deeper into the repair if you like-
But a new ignitor needs to be exactly like the failed one-- the safety circuit is very fussy about the exact same ignitor-- or it will not allow lighting-- even with a new 'generic' installed.
How deep do you want to go into this repair?-- Maybe it is time to call the service people into do the job?-- You can tell them that you think the ignitor needs replacing-- and approx. what will they charge you for the service call and the ignitor?
I hope this helped.
Mack B
Jan 27, 2011 | GE 30 In Freestanding Gas Range ...
Hotpoint oven model rgb745wea1ww oven doesn't light. Broiler and stove top work fine.
heatman101
Jan 04, 2011 | Hotpoint Ovens
MY MAYTAG OVEN WILL NOT TURN ON WHEN I SET THE ELECTRONIC DIGITAL THERMOSTSTAT LIKE SAY I PROGRAM IT TO 350 DEGREES,,, NOTHING HAPPENS,,, BUT WHEN I GO TO SET THE BROILER THE BROILER WORKS JUST FINE,,, I...
First I want to commend you for your giving us good information to start with!
So-- we know we have gas, and we know the Broiler Valve and ignitor works-- Good observation!
However-- we have no ignitor (No bright red/Yellow glow)-- like you go for the Broiler-- right?
Well, we can NOT get ignition on the main burner-- unless we have the ignitor for the main burner getting hot, and then the gas valve to that burner can light, and give you heat...
Soo-- Likely we have an ignitor failure for the Main burner---
Do you have a warranty on the stove?
Do you have a service person qualified to tackle this job?
There will be electrical work, and parts obtainment issues to deal with now---
I suggest you call the local service people for this stove, and tell that that you need to have the main gas burner ignotor replaced for this stove model number-- and see what they tell you.
Let me know if I can help more--
Mack B
Dec 30, 2010 | Maytag Ovens
Oven/Broiler doesn't work. Stove top works
heatman101
Jun 03, 2010 | Tappan TGFS26C Gas Kitchen Range
MGR5755QD CleanDesign Gas Kitchen Range: oven wont light. stove and broiler work fine. bad ...
heatman101
dfasfdas
May 17, 2010 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Ge gas/prop stove bottom oven burner will not light.Broiler and stove top burners work fine
you will neeed a new ignitior
its a pretty easy repair
take out the racks
take out the bottom of the oven
you should see the ignitor
pull ou the drawer you will see the connection
disconnect it
make sure your very careful with the new one they are very brittlle
Oct 09, 2009 | GE JGBP28 Gas Kitchen Range
GAS STOVE
yep replace the bottom ignightor take out the rackes remove the two bott screws in the oven remove the bottom plate and just keep going down
May 21, 2008 | Kitchen Ranges
When turn oven on GE XL 44 Gas Stove bottom of oven does not get hot. However there is an orange glow coming from bottom of oven under the shield. What do you think it could be? Broiler works fine. Thanks...
The glow that you see is the electronic ignitor. If it is glowing and not getting hot you will need to replace the ignitor. It is not strong enough to open the gas valve. They grow weak over time.
Apr 26, 2008 | Kitchen Ranges
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
53 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
