My averatec 7100 notebook keeps loosing the touchpad functions- Its like it doesnt exist when i search for it. i can use an external mouse, and when i search for the touchpad mouse it only shows my external one. the touchpad stopped working before i added the external
    Novelist:
    Scholar:
  • 134 Answers
Maybe reload the motherboard software..
Posted on May 04, 2008
Touchpad doesnt work
Try reinstalling the touchpad driver.
You can download the touchpad and device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: -
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
May 03, 2013 | Toshiba Satellite A135-S4477 Notebook
Does averatec 7100 u have windows 7 drivers
Greetings! I just finished a successful W7 build on a 7100. Here's the driver set...,
https://dl.dropbox.com/u/17664826/Apps/Averatec%207100%20%28W7%20Drivers%29.zip
Nov 14, 2012 | Averatec AV7155-EA1 (AV7155EA1REF) PC...
Touch pad malfunctioning
Inorder to fix the Touchpad issue, try the hard reset steps:
Sometimes it is necessary to do a hard reset to erase all of the information in the temporary memory and regain functionality of your PC when it stops responding. For example, doing a hard reset is helpful if your keyboard quits responding, you cannot get your PC to come out of hibernation or sleep mode, or if a software program causes the PC to freeze.
The hard reset will not delete saved files on the hard drive.
Hard Reset Procedure:
1. Disconnect the AC Adapter.
2. Remove the Battery pack.
3. Hold the Power button down for 2 minutes.
4. Reconnect the AC adapter and Battery.
5. Turn on the Notebook power.
Also make sure that touchpad button is On. It will be just above the touchpad area where you can see the white led which shows that touchpad is on. If the led is in orange, touchpad is off.
If these steps does not work, update the BIOS version from HP website .
In rare case if the issue still persists, you need to restore the notebook to factory settings using Recovery Manager or recovery discs.
Before performing recovery, you need to backup all your data to external hard drive because it will erase the data from the hard drive:
Vista F11 procedure:
1. Reboot the notebook PC.
2. Press F11 when the HP logo displays.
3. When the Recovery Manager appears, click Next .
4. When prompted to use the Microsoft System Restore program, select No and click Next .
5. When prompted to use the System Recovery, select Yes and click Next .
6. Select the option to perform the recovery without backing up files and click Next .
The recovery process will return your PC to the factory image.
or
On some notebooks, the TouchPad can be turned off by pressing an on/off button located near the TouchPad. If the notebook does not have such an on/off button, you can still disable the TouchPad in its settings control panel.
NOTE: You will need to use an external mouse or some other pointing device to control the cursor when the TouchPad is disabled.
To disable the TouchPad:
Click Start , enter mouse in the search field, and then select the Mouse control panel program from the search results.
On the Device Settings tab of the Mouse Properties panel, click the Disable button to turn off the TouchPad.
The TouchPad can be re-enabled when needed.
May 07, 2012 | HP Compaq 6735s Notebook
List of drivers for an averatec 7100 series
Averatec 7100 Series Drivers for Windows XP can be downloaded from the following links: -
Link-1 (From Category select 'NOTEBOOKS' and Model '7100 Series'
Link-2
Hope it helps! Good Luck!
CreativeTECH
Mar 14, 2011 | Computers & Internet
Mouse pad just stopped working on start-up today. Works with external mouse. Pad and left & right buttons just dead.
You may have turned it off. Check your "function" or "f" keys or the on/off button may be above the touch pad
Mar 20, 2010 | Averatec 7115 EHI 17" Notebook PC Notebook
The touchpad mouse on my toshiba salellite does not function even though it shows it working properly when you go into the touchpad icon. I have an external wireless mouse (usb) hooked up that works fine...
The touchpad is most probably defective. If you have dropped your laptop the touchpad cable could have get out from its connector on the mainboard. You can get a new touchpad/palmrest on ebay. You have to remove your touchpad/palmrest as shown in the link below, steps 17 to 19 :
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Identify the part number of your touchpad/palmrest. Search on ebay.com : Toshiba Satelitte A105 palmrest. Buy the one with the same part numer as yours.
...or have your laptop repaired by a professional.
Oct 09, 2009 | Toshiba Satellite A105 Notebook
The mouse pad on my new acer travelmate 4730 doesnt work
Hold down the function key (Fn) then press the F7 key. This is keyboard shortcut to toggle on and off the touchpad.
Sep 04, 2009 | MSI M510C Notebook
Quickplay touchpad above keyboard
The following illustration and table describe the computer TouchPad.
(6)
TouchPad on/off button Enables/disables the TouchPad.
Component Description
(1)
TouchPad light Blue: TouchPad is enabled.
Amber: TouchPad is disabled.
(2) TouchPad* Moves the pointer and selects or activates items on the screen.
(3) Left TouchPad button* Functions like the left button on an external mouse.
(4) Right TouchPad button* Functions like the right button on an external mouse.
(5) TouchPad scroll zone* Allows you to scroll up or down.
(6) TouchPad on/off button Enables/disables the TouchPad.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 08, 2009 | HP Pavilion dv9000z Notebook
The mouse on my inspiron 1505 doesnt click on like it should.
Pleae update the chipset and the touchpad driver and restart the system. After the touchpad driver is installed look for the utility under mouse properties in control panel. Then get into the utility and select the option where you can disable the touchpad when external mouse connected.
Please rate this comment if it was helpful
Jan 20, 2009 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
