Question about American Standard Sink Strainer Drain, Polished Brass
Can i adjust my bathroom drain stopper on my American standard drain?
Which Drain are you talking about?
Posted on Aug 31, 2010
Delta faucet will not hold water
The linkage to the drain stopper has to be adjusted so that the stopper seats when the rod is raised. If the stopper lifts out of the drain, it may be necessary to remove the lifter rod and insert it through the holes in the bottom of the stopper then reinstall. After this, pulling up on the faucet rod will force the stopper to seat rather than drop by gravity. The tradeoff is that you will not be able to remove the stopper without disassembly of the connection
Feb 18, 2013 | Plumbing
We have american standard bathroom faucets with speed connect drains and they're draining slow
Disconnect the speed drain and pull the stopper out to see if it drains fine with the stopper out and if it does then you need to clean the parts and reinstall same.
Feb 11, 2011 | American Standard Hamilton 4 In. Centerset...
About a year ago I installed an American Standard Cadet lavatory faucet with the Speedconnect drain. When I fill the sink with water it leaks out very slowly. I have not had any success in repairing this...
Try adjusting linkage under sink,squeeze metal piece and pull off to adjust to different hole setting,you can fine tune with small screw on chrome rod,so you can pull stopper down tighter
Jan 30, 2011 | Home
Very slow drainage of a small bathroom sink. Liquid Plumber does not help
probably hair stuck in the drain. did you remove the stopper "pop up" if no hair or blockage there or in the trap, then its further down, you will need a small snake. 1/4 inch cable works well in bath and kitchen drains.
you can purchase one at home depot.
Aug 05, 2010 | American Standard Home
Bathroom sink needs new drain, leaks under counter
Is it a new sink? Most of the time if it's new you'll have to get more pvc pipe because the new tail piece that comes with the new faucets usually is either longer than before or shorter. Yes you can get another tail piece or you may be able to by a longer pvc piece to to hook up the the metal tail piece. Make sure you have the plastic seals inside the pipe where they attach together or it will leak. Once you have it all together close your stopper and fill the sink with water and then pull the sink stopper and watch for leaks if it dont leak then it wont leak.
Dec 30, 2009 | American Standard Cambridge 5' Americast...
Tub drain wont stay open
If this is a trip lever waste type of drain it can be adjusted, Remove the 2 screws that hold the adjusting lever, this will allow you to remove the stopper. Clean the stopper of hair and sludge and replace. This will usually fix the problem. If not then adjust the linkage for the stopper.
Nov 23, 2009 | American Standard Scala Bathtub Only ...
Set screw has been removed from American Standard single lever faucet. How do you remove the faucet
Faucets are fastened with nut(s) under the sink.
-Turn off and disconnect the water supply hose from the faucet.
-If this is a faucet with a sprayer you will need to disconnect the sprayer hose from the faucet as well.
-If this is a bathroom sink you will have to disconnect the drain stopper assembly, this should be self-explain when you look at it.
-Remove the nuts or nut holding the faucet in place. This can be a difficult task to get a wrech or pliers on the nut(s). If you are having difficulty you may need to acquire a tool called a "basin wrench" most hardware stores carry them ask for it, if the person knows his department he will take you right to it. They arn't terribly exspensive.
Oct 28, 2009 | American Standard Plumbing
American standard bath drain problem
The stoper assembly has linkage and a plumb bob aparatus
Step 1 remove the 2 screws that hold the chrome overflow cover,
Step 2 you will see a wire connected to the up and sown handle
Step 3 you should be able to fish out the linkage which will have a bumb bob attached
mae sure this is all connected if not reattach if you do not see the blumb bob reach your fingers in and grab the wire
Step 4 inspect the linkage the first link is about 3 inches from chrome cove, second is about 8 inches down and final is at the bob itself bob is pointed and slides in by gravity
If this all looks ok then fish it down , put chrome cover on and move lever up and down ( you should see the stopper mve up and down
Step 5 If stopper is not in just insrt in drain hole and move the lver flow lever up and down and drain should work sometimes the stoper does not go up or down far enough there could be an adjustment on the linkage to reduce or increase the length of the linkage
Good Luck
Dec 28, 2008 | American Standard Evolution 1599.205.020...
American Standard Sink Strainer Drain, Polished Brass Logo
239 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
Mike
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
