Question about Hunter Ceiling Fan Control Switch
I have a Hunter ceiling fan model 25750 that haa a rather severe wobble that I cannot reduce with the Hunter Balancing Kit. What should I try next?
Crossedwires
  • 44 Answers
SOURCE: Hunter Ceiling Fans
Unfortunatly that is a common thing with most manufactorers now a days! they are not in the service industry. make it, sell it, dump it, make a new one. and the cycle goes on and on. You may be able to find a repair person who can fix the fans for you at a reasonable cost.
Posted on Feb 09, 2008
muttandjeff
  • 359 Answers
SOURCE: wiring connection ceiling fan
copper to green , white to white , seperate the black and the black with th white tracer you wired together connect the black to the black and the black with white tracer to the red in ceiling , without looking this is my best advise ,good lk
Posted on Nov 27, 2008
SOURCE: we have a hunter type 2 ceiling fan installed on a bedroom ceilin
Okay. Turn off circuit breaker. Take the bottom off the fan. Mark how the wires are connected. Remove switch by unscrewing the sleeve you mentioned. Take the switch to Home Depot (or the like) -- buy a replacement.
If you have to turn the breaker back on during this process, make sure you have a wire nut over the end of each of the loose wires you disconnected from the switch.
After you take the switch out, you'll know how to reinstall it, so I won't go thru that.
Charlie
Posted on May 12, 2009
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
SOURCE: need a hunter westside2 model #21621 instructions w/ pictures
Costco.com has an online manual for this fan. That is the same model number you are looking for.
Posted on Jun 13, 2009
I need a light kit for hunter fan model #23530
  1. Hunter Fan - Accessories
    www.hunterfan.com/Accessories
    Need more control? We have many universal remotes and wall control options for yourfan and light ... Customize your lighting. Add a new light kit or change the lighting hardware on your fan. Complete light kits. Need lighting parts? Glass and ...‎Complete Light Fixtures - ‎Controls - ‎Glass/shades
Jul 09, 2015 | Hunter 52" Ceiling Fan With Light And...
Fan blade for Hunter ceiling fan?
I don't think you will get just one blade but if you visit lowes, sutherlands, or home Depot you will find a kit to replace all the blades which would be better since all the blades will be straight and you won't get a wobble.call hunter and see if they will send you one or sell you one and or if you have a 4 or six blade fan remove the opposite blade on the fan for free.it won't be as efficient but it will do the trick.
Feb 04, 2015 | Hunter Dryers
My ceiling fan "wobbles" when turned on. How do you fix that?
Make sure ALL screws are tight, especially the set screws. Make sure the hanging bracket is tight against fan box. If your blade arms are bent, then you need a new set. Make sure blades are not warped. Other than that you can try a balancing kit as long as it's not that last two problems listed. This happens a lot with low-end store brand fans.
Sep 22, 2013 | Hampton Bay 24002 Ceiling Fan
My son has a Hunter fan in his room model 21841. It looks like a catchers mit with baseball bats pictures for blades. The fan wobbles so bad I can't turn it on past the first spin level. The cathcers...
The blades are out of balance. You need to add weight to the lighter weight blades to is turns smoothly with no wobble.
You can go to Home Depot or other home improvement store and buy a fan balancing kit for around $2. It will have instructions.
Dec 24, 2010 | Hunter 21841 The Baseball Fan Ceiling
Casablanca Delta II fan wobbles terribly at high speed. How can this be fixed?
Use the fan regulator to adjust the speed of the fan, and if it does not adjust the speed, then you have to replace the fan regulator.
Good luck...
May 31, 2010 | Casablanca Fan 3245T Ceiling
New fan with downrod wobbles when on high speed and low speed. Does not wobble on medium speed. How do I stop the wobble completely?
Measure from the same spot on the ceiling to the outer most tip of each blade (by rotating to the tape). The distance should be the same, if not check fan blade screws for tightness. You might have to bend the fan blade brackets a little to get the same measurements, if the screws are all tight. If all this lokks good, you might to use a balancing kit...just follow the instructions...it's not too bad to do
Feb 18, 2010 | Hampton Bay Dryers
Wiring light kit to ceiling fan
connect the white wires from light kit filter to the white wire labeled "for light" from fan. then connect black wire from light kit filter to blue wire from fan. use wire nuts to make the connections
Jan 17, 2010 | Hampton Bay 24002 Ceiling Fan
Ceiling fan wobbles How do i balance it ??
you go to the hardware store and buy a ceiling fan balancing kit
Jun 18, 2009 | Honeywell HT-800 Table Fan
Dryers Logo
136 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
