Question about GPX KC318S CD Player
Need mounting template - GPX KC318S CD Player
I'm installing a GE spacemaker JVM130K but don't have the mounting templates where can I find them?
I checked the manual and it did not provide one or mounting dimensions. If you already have the unit, reverse engineer a template... You can either do it by holding paper to the sides and marking the mounting points, or simply take the measurements for the mounting points from a good known reference - such as the front if you are looking to moun the front flush to the face of the cabinets.
Dec 04, 2014 | Microwave Ovens
Need Installation 'Paper' Template for MMV4184AAW Maytag Microwave
see the video
and proceed according. God bless you
Apr 02, 2013 | Microwave Ovens
How do you use a template in scrapbooking?
A template is usually a sheet made out of card or plastic that can be used to help mount or crop photos onto shapes. Some templates can be used to draw shapes and outlines onto the page. In a digital format, templates help give shape to the page and you can drag and drop your photos in the shapes of the template.
Feb 12, 2013 | Crafts & Hobbies
I need the Easy Installation Step-by-step mounting instructions and Pre-sized mounting template for Black & Decker TROS1000 SpaceMaker Digital Toaster Oven. Thanks
For a manual you can go to blackanddeckerappliances.com. Then under the Customer Care tab click manual and follow with info needed for your SpaceMaker. That won't give you the template so try the phone numbers here for Black and Decker to ask them.
Phone Number: 800-738-0245
(Monday-Friday, 8:30 AM to 8:00 PM, E.T.)
1-800-231-9786 Monday - Friday 8:30 AM - 8:00 PM ET
Mar 25, 2011 | Applica TROS1000 Toaster Oven
Can you provide guidance on how to install this microwave? Trying to decide if I should pay $120 for the store to install.
Installation of an over the range microwave is not a very difficult task as long as electrical work to provide power is not needed. If no outlet exists then an electrician will be required.
Tools that may be needed for the installation include a cordless drill, drill bit, measuring tape, masking tape, stud finder, razor knife, pencil.
A template is commonly provided for mounting hole locations that need to be drilled in the cabinet. These holes are the top mounts.
An additional template for the wall bracket is normally supplied as well. Here you will need the stud finder, it is important to locate the studs and mount the wall bracket to them.
The wall bracket serves as the bottom mount and aids in the final mounting of the microwave.
Depending on the oven's size and weight a helper may be needed to complete the installation.
Remember to be safe first and seek advice/help with any step you are unsure about.
Good luck.
Jun 27, 2010 | Whirlpool WMH1162XVS Microwave Oven
Wall template mount for ge profile microwave
You can may be able to order that by looking up parts by your full model number here.
Jan 10, 2010 | GE Profile Over-the-Range Microwave
When installing over the range microwave does template need to be removed
the paper template that they send to mark for mounting instructions? yes...another template you're refering to?
Oct 25, 2009 | Bosch Microwave Ovens
Template for GI 936-760 wood panel
My husband ended up measuring and drawing his own template.
May 13, 2009 | Gaggenau GI936-760 Dishwasher
GE Slim Spacemaker 7-5295 CD
Make your own template with some thin cardboard. (cereal box) Turn the unit upside-down with the 3 spacers in place & mark their location with a pencil. Then mark the front edge & sides of the radio onto the cardboard. Instant template!
Sep 04, 2007 | GE Slim Spacemaker 7-5295 CD Shelf System
GPX KC318S CD Player Logo
85 people viewed this question
Top GPX Audio Players & Recorders Experts
Tequella Chapman
Level 1 Expert
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
