Question about Whirlpool Duet GHW9150P Front Load Washer
Has a flashing code F 70 WILL NOT START - Whirlpool Duet GHW9150P Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F70 is Central Control unit Heartbeat failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface. To resolve this issue you’ll have to:
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 23, 2010
When I turn it on, why doesn't it start?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 24, 2015 | Televison & Video
Service engine soon light started flashing then started to idle erratically
It sounds like it could be the o2 sensors, the mass air flow sensor, or the idle air control valve, take the vehicle to your local auto parts store and have them connect their scanner and pull the codes.
Jan 30, 2018 | 1998 GMC Sierra
Flashing CE CODE
try to clear error code
Aug 20, 2017 | Hayward Pool & Spa
I have a 2001 volkswagen it has started losing speed after going 70 miles and hr. for about 7 miles it start to miss in the motor and my speed goes from 70 to 50 in seconds if i push the accelerator down...
A flashing SES light is a misfire and can cause severe engine damage. You need to have the computer scanned and post the codes here for more help. It could just simply need a tune-up.
Nov 25, 2012 | Motorsports
My dryer is flashing a code of F 70 and it wont start. What does that mean
Check dryer vent lines, make sure clear of lint and etc. Unplug, wait about 5minutes and plug in and try again. Does dryer start at all?
Tips Provided by: www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
Aug 26, 2011 | Kenmore Elite HE4 Electric Dryer
Dryer will not start display works, when i push the start button it just beeps and does nothing, shows a E01 code.
Hi, this is what the error code means,
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Hope it helps.
Jan 19, 2011 | Whirlpool GEW9250 Electric Dryer
Auto zoom error code comes up on my Metz 76 mz5 flash.
I had this problem. A few hard smacks with the palm of my hand cleared it right up.
Aug 17, 2010 | Metz 70 MZ-5 TTL Flash
2010 yamaha r1 shows fault codes 66 & 70. what do these codes represent. thanks.
CODE 66: "Open or short circuit of steering damper solenoid lead."
Check the ESD fuse has not blown first befoe checking the wiring itself.
CODE 70: This model is equipped with an engine auto-stop system. The engine stops automatically if left idling for 20 minutes. In this case, the multi-function meter indicates error code 70, but this is not a malfunction. Push the start switch to clear the error code and to restart the engine.
Hope this helps
Apr 19, 2010 | 2008 Yamaha YZF-R1
F 70 is now flashing. Machine did not start and after repeatedly trying it finally flashed F 70 but my booklet does not tell me what it means.
unplug it and clean out ALL lint the lint sensor will trigger this code,start at lint trap,blower motor, and all the way to the outside vent
Oct 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F 9
F70 is a "communications error" message and the first thing to check is loose wire connections.
If a loose connection is not found, the controller board will probably need to be replaced.
Thank you for contacting Fixya.com
Aug 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
53 people viewed this question
Dan Webster
Dan Webster
Sal De
