Question about Fisher and Paykel AeroSmart DG62TD1 Dryer
My aerosmart dryer wont heat up - Fisher and Paykel AeroSmart DG62TD1 Dryer
  • Fisher and P... Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Aerosmart dg62t27dw2 belt squeeking and making clothes stink
Your belt is not on the pulley correctly. You will likely need to purchase a new belt as the damage has likely been done. Remove back cover and then remove casing (video on youtube) Replace belt. You may be able to fix quicker by flipping dryer on side and replacing the belt from the bottom, but it is a tight fit.
Jan 12, 2014 | Fisher Paykel Fisher & Paykel AeroSmart...
Aerosmart dryer periodically makes a popping sound, like a small firecracker exploding. This happens when the dryer is not being used, and there is no smell or heat. Again , this happens only...
-It hard to tell. But hers is some basic step to check.
-Unplug the main power and open the back panel cover.
-Check all wire terminal and around all wire . Do you see any white spot or any sight of electrical shock?
Good luck
Mai
Oct 31, 2013 | Dryers
My dryer wont heat up and vent is clean. what do i check for?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 09, 2011 | Fisher and Paykel AeroSmart DG62TD1 Dryer
Model number DE62T27 Dryer turns on, but won't heat up.
heatman101
Mar 15, 2011 | Fisher and Paykel AeroSmart DE62T27D Dryer
The Aerosmart dryer display is lit up, but is all white. The different dryer selections do not appear.
The LCD panel board has gone bad and there is not a "fix" for this. I had the same problem and the only solution was to replace the display. It comes from F&P at a premium price, but fixes the problem and was very easy to do. Only one plug and handful of screws. I was almost able to do by myself but another hand was helpful.
Jan 21, 2011 | Fisher and Paykel AeroSmart DG27CW1 Gas...
Dryer runs does not heat
heatman101
There is no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 13, 2010 | Fisher and Paykel AeroSmart DG27CW1 Gas...
The dryer bangs like it's hitting something on every revolution. Do you have any idea what could be causing this?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 07, 2010 | Fisher and Paykel AeroSmart DE62T27D Dryer
Fisher and Paykel AeroSmart DG62TD1 Dryer Logo
156 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
