Question about Dryers
I have a whirlpool heavy duty thin twin model LTE4243DQ1. I need to remove the heating element and the thermal fuse where is this located?
  • 4 more comments
  • jason_phi680 Aug 22, 2010
    So if the dryer is blowing cold air and there is no heat what should I check?
  • jason_phi680 Aug 23, 2010
    So if the dryer is blowing cold air what should I check?
    The incoming voltage is good. So how do I remove the thermal cutout and the hi-limit thermostat (2-part kit) and while I'm at it.... the heating element? So I can take it and get the continuity checked.
    I did copy and paste it. The machine looks different than mine. My control panel is in the middle of the machine, the manuel shows it's control panel at the top.. The manuel says its Large-capacity thin twin laundry system. Mine is a heavy duty thin twin....same system? It looks different....?
    Sorry these manuals are different models. My machine is a electric Model #LTE5243DQ1. Whirlpool heavy duty thin twin. I need the right manual so I can remove the right parts.
  • jason_phi680 Aug 25, 2010
    It was very helpful. I could not have replaced the thermal fuse without there guidance. Totally worth 6 bucks.
    Thanks
    Top Expert:
  • Dryers Master
  • 75,822 Answers
Please go to the web link below for instructions, the thermal fuse can also replaced at that time
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Posted on Aug 23, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You can check this service/technical manual on how to remove the heating element and thermal fuse:
Whirlpool Thin Twin
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • Dryers Master
  • 3,361 Answers
The thermal fuse located on the left side of the main exhaust duct prevents the dryer from running due to a restricted airflow.
The thermal cutout is located on the top of the heating element duct and prevents the heating element from working,usually due to a defective hi-limit thermostat.
The thermal cutout and hi-limit thermostat comes as a kit(2 parts).
Copy and paste this Factory Service manual to find all your part locations and troubleshooting guide.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d322131b309497a852571ca006ce7d2/$FILE/L-56_4314124A.pdf
Let me know if I can be of further assistance.
Posted on Aug 22, 2010
  • 1 more comment
  • steve
    steve Aug 23, 2010
    The first place to check would be incoming power with a volt meter set for 220 or higher voltage.
    If you have less than 220 volts at the terminal block on the rear of the dryer,your have a voltage problem in your circuit breaker/fuse panel.
    The second place to check would be the thermal cutout, then the hi-limit thermostat,then the heating element.
    All must be checked with a volt meter set for ohms.
    An OL reading or no reading at all would be a bad component.
    The bad component(s) must be replaced.
  • steve
    steve Aug 23, 2010
    You should copy and paste the Factory service manual I referenced.
    It will detail how to remove the rear panel and will identify the parts to be tested.
  • steve
    steve Aug 25, 2010
    The diagrams referenced will show the location on the parts to access.
    Remove the rear dryer panel to find these parts.
    http://www.appliancepartspros.com/partse...
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 | Dryers
I have a kenmore 70 series heavy duty 110 96573230. It doesn't heat up. Can't find where the thermal fuse. Where is it located? Do I need to unscrew the back?
Yes, you need to take it all apart. ( Including the back.)
All of the things that can cause your problem are in the back and the bottom of your machine.
There are actually about 3 to 7 things that can cause "no heat".
Not only the "thermal fuse", but also the heating element, and any of the "overheat thermostat switches" can have failed, beside the possibility there is a wire has burned in two.
You will need a testing instrument like a multi-meter or a volt-ohm meter to check all these out.
Be blessed.
Mar 22, 2013 | Dryers
Whirlpool heavy duty 5cycle 3 temp dryer won't turn on suddenly stopped..no sound whatsoever..changed heating element and still not on
Check your thermal limiter . It should look like a white bar about a inch long . You can find it on the blower housing
Feb 17, 2013 | Whirlpool Dryers
Dryer is taking too long to dry, can the element be worn out? whirlpool, thin twin heavy duty, large capacity
If it heats the element is good. Most likely cause is bad ventilation. check the vent on the outside of the house while dryer is running to make sure you are getting plenty of air flow. If you want to check to make sure its working properly general rule is 6 towels should dry in 60 minutes.
Sep 20, 2010 | Whirlpool LTE6234D Top Load Stacked...
Dryer has stopped producing heat
I have a Thin Twin manual that will give you an idea of where to start:
THIN TWIN SERVICE MANUAL
Jul 12, 2010 | Whirlpool WHP1500S Electric Dryer
How many thermostats are there and where are they located?
If the model number is correct, your heating circuits are comprised of the following components:
1. Heating Element
2. Thermal Cut-Out
3. Hi-Limit Thermostat
4. Internal Bias Thermostat
5. Thermal Fuse
You can access your heating circuits by UNPLUGGING the dryer and removing the rear panel.
As viewed from the rear of the dryer, your Heating Element will be located on the RIGHT hand side inside a heater box. The Thermal Cut-Out will be located on the outside of the heater box at the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
The Internal Bias Thermostat and Thermal Fuse are two small components mounted on the Blower Fan housing on the lower LEFT hand side.
You can refer to the following parts illustration for assistance:
http://pcappliancerepair.com/model-display.php
The components are listed as follows:
Heating Element (Item 17)
Thermal Cut-Out (Item 9)
Hi-Limit Thermostat (Item 15)
Internal-Bias Thermostat (Item 8)
Thermal Fuse (Item 7)
If you need assistance on how to troubleshoot a dryer, you can refer to this link:
http://www.fixya.com/support/r3574266-thorough_dryer_advice
If you have any questions, or need further assistance, please post back and let me know. I hope you find this information helpful.
Mar 21, 2010 | Whirlpool WED5700S Electric Dryer
Whirlpool heavy duty thin twin broken heater, the dryer just stop heating, please help I can repair my self, unit is about 6 years old and it works grat
Hi, thanks for the inquiry.
If it's a gas dryer, it's most likely a thermal fuse. Basically, the voltage has to go through the fuse before it goes to the ignitor.
If it's an electric, it's either the heating element or the thermal cut-off, most of the time.
You'll proabably have to get to the element and fuse from the back. What I would do is just tilt the entire unit forward, if it's in a tight closet.
Best of luck and please feel free to contact me if you have any questions.
Ned
Sep 21, 2009 | Whirlpool LTE6234D Top Load Stacked...
No heat
Hello Friend, Your problem is very simple to fix. You need a thermal fuse and or heater element, both very simple and affordable to replace. Try replacing the thermal fuse first to see if that's the problem. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. If this don't solve your problem you will need to replace the heater element. To replace the heater element, with the back cover off of your dryer just look down and to the right of were the air blows out. You will see the electric heating unit with two fat red wires plugged into it. Unplug these wires and you will see on the sheetmetal housing two screws that hold it on, one on each side. On older elctric dryers there is only one screw that holds element in place, it is on the bottom center of element screwed in from behind. Remove screw(s) and remove old heater element. Now, lay the new element next to the old one and take notice that there is a heat sensor attached to the old element where one of the red wires unplugged from. Gently remove this sensor and install it onto the new element in the same location as the old one. If you have an older electric dryer, the old heater element doesn't have the heat sensor on it, just skip this step. Now, plug in your two red wires and re-install your heater element. Your dryer will run like new. Happy to help, Tim.
Apr 21, 2009 | Kenmore 62802 Electric Dryer
Whirpool twin thin no heat
Make sure you have 220 volts first at dryer. Heating element is on back of dryer. You'll need a test meter to see what's wrong unless you can see broken wire in element itself. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool dryer
First make sure you have power to the unit through the plug. If power is present, then you most likely have an open Thermal Safety Fuse. The Thermal is a Safety feature that shuts off the power to the Heat Element in the event the Blower is not blowing or the Lint Vent becomes clogged not allowing air to flow over the Heat Element. NO air flow, Heat Element over heats, Thermal Safety Fuse opens, power shuts off. If the Thermal Safety Fuse is open find out why. Was the blower not working? Was the Lint Filter clogged? ( Lint Filter should be cleaned after each use to assure continued air flow.) Was Lint Vent Clogged? This is the Vent Hose that goes from the Dryer to the outside of your house. It should be checked for free air movement. The next thing-- Could be a defective Timer or Control Module.
Find where you lost power and WHY!!
Jan 27, 2008 | Dryers
Dryers Logo
596 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
