Question about Peavey Xr 8600 8 Channel Powered Mixer
Hello, What is the proper way to connect an Ashly XR1000 Crossover and a Pyle Pro PTA1400 power amp to my Peavey XR8600 so I can use 2 subs? The subs are not powered, but do have a passive crossover installed in them. Can I just use the Pyle Pro PTA1400 power amp to run the subs and eliminate the Ashly XR1000 crossover? If so....how would I hook it up to the Peavey XR 8600 ? Thank you -
    President:
  • 1,138 Answers
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00513220_7.pdf I didn't look at the manual for the crossover but this is probably the way I would do it. Look at page 13 in the manual : Come out of the Main out (31 in the diagram) into the main in of your crossover. Go out of your crossover Hi and Mid out setting back into Power amp In 1 (labelled 32 in the diagram). Hook your speakers that you normally use to the output jacks on the back of the Peavey. Make sure you match the output impedances. Go out of your crossover low output into the Pyle power amp and out of the Pyle into your subs. Make sure the impedance ratings of all your speakers match the output impedances of your amps. You will only be running in Mono mode as that is the signal output of the Peavey mixer. You can run faux stereo by using the Main monitor Out as 1/2 the pair and the Main Out as the other 1/2 to both channels of the crossover but you won't be getting a true stereo pan mode.
Posted on Aug 27, 2010
How can I connect my Peavey xr600 mixer amp to my Behringer Super-x Pro cx2310 crossover?
That depends on what you want to end up doing. You will end up patching into/out of the jacks on the front. You do not come out of the jacks on the back to the crossover.
Apr 05, 2016 | Behringer Music
How to connect subs and mains to the same pv2600
This will depend on your Subs. If they have an inbuilt crossover there will be input and outputs on the rear, with the output marked something like 'tops' or 'Output to HF'
If you have these then it should be a simple matter of connecting yout amp to the subs and then the mains to the output.
If you haven't got a crossover in the subs then you will either need to buy a pair of two way crossovers for the right power and frequency and have these in the speaker wiring or use the amp's inbuilt crossover and run one channel for tops and the other for subs. You will lose stereo but the amp will happily drive a 2ohm load so you should still be able to use all four speakers.
Feb 06, 2014 | Peavey Pv 2600 Power Amplifier
How do I properly connect my peavey 118 subwoofer to my peavey 215 speakers
When asking questions please give as much detail as possible, t LEAST give the model or part numbers of the items you are asking about and anything else you will be using with them. Without this information it is impossible to answer more than general questions. However I will attempt to give an answer which could point you in the right direction below.
As you don't say which 118 and 215 you have it is impossible to give an absolute answer. Some 118s have an internal low pass crossover with two inputs in parallel, in this case you can take a connection from the amp to the sub and from the sub to the 215. Again some 215s have a high as well as a full range input so you MAY be able to use this to avoid driving full range into the 215. Some 118s have a high pass as well as a low pass in which case just connect the high out to the fullrange in on the 215. You could also possibly split the amp to use one side as a sub driver and the other for the mid/tops if the amp has a crossover.
You may also find that the wiring on the speakons on the tops needs to be different according to how you are going to use them (2+/- instead of 1+/-)
You will also need to know what impedance your amp is happy to go down to as in some combinations depending on which model 118/215s you have you could end up presenting a 2ohm load.
Dec 10, 2013 | Peavey Music
I have a peavey 1220 powered mixer and I'm trying to hook up to two sp15's top's and 2 18; peavey subs for my band and I can't get the bass seperated so it's out of my tops
Hi. The mixer puts out a full range mix, the solution is in your speaker setup.
Many subs have a built in crossover that splits the signal for the tops. Check your sub specs or manual. If your subs have this, run your output signal to them first and then link them to the tops from the special daisychain socket.
If they don't have one, you can install a passive crossover to your subs or buy an external crossover unit.
The last (and not very good) option is to fake a crossover with the desk's stereo EQ. Connect the subs to the left or right channel and the tops to the other and use the EQ to remove the bass from the tops and vice versa, pan everything dead center. Obviously this sacrifices your stereo sound and isn't brilliant.
Jun 29, 2011 | Peavey XR 1220 Powered Mixer Mixer Powered
I have 2 peavey sp 5 and a pwavey 2600 amp . i wanna know can i hook a peavey 118 passive sub to one of the sp5 and how would it sound?
You would send high as well as low to the sub and unless the sub had a built in crossover it COULD get muddy sounding. The specs SEEM to indicate the 118 DOES have a low frequency crossover so it SHOULD be OK... How would it sound? An 18 inch sub normally adds to the sound of a system... You MAY need to PAN over to send more power to the one side with the extra load on one side. Often people use two sub's... one for each side so it is balanced.
Jan 19, 2011 | Peavey SP5 2-Way PA Cabinet (800 Watts, 15...
Can i connect the pv 112 to the pv 118 subwoofer since the powered mixer i bought it only has 2 main outputs? The powered mixer I bought is the PV XR 8600D powered mixer...
Generally speaking you should only send low frequencies to subs. The highs, while lower in power than the lows, will over time harm the voice coils. The ideal way to do this is to use an external crossover netween the main output and the amp input with the higher range going to a general set of speakers. Send the lows through the second channel of the amp and then to the subs.
In short, while not recommended, yes you can hook them up in parallel.
Dan
Dec 09, 2010 | Peavey Pv118 1x18" Subwoofer Speaker...
CAN I POWER UL15 AND XT115 [WITH CROSSOVER] WITH 1 AMP
You need 1 channel of amplifier per stack. Assuming the ul 15 is a full range box, and the XT115 is a subwoofer. But be careful with your Ohm ratings for the speakers and your power ratings of your amps. You want the proper Ohm load on the amplifier for maximum power. And use proper speaker cable, with correct wiring.
Wire the to the sub first, and then jump to the ul 15.
Feb 20, 2010 | Peavey Pv 2600 Power Amplifier
Run a sub woofer to a peavey board
I would recommend using a separate active crossover such as the Peavey 23XO and a separate amp for your subs.
Jun 20, 2009 | Peavey Pv 2600 Power Amplifier
Peavey Xr 8600 8 Channel Powered Mixer Logo
800 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
