Question about Frigidaire Ovens
My kenmore model 970(frigidaire) electric range displays F10 fault when i use the oven shutting down the oven and beeping. Help me please
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F10 error indicates that the Electronic Range control (ERC) has gone bad and should be replaced. However, before replacing it you can take the screws out and then blow some air with the help of hair dryer so that if there is any moisture it blows it off. If still the issue is not resolved then replaced the ERC. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 27, 2010
What does Fault code F10 on a Kenmore Range, Model #970-678421, mean please?
run away temp either temp probe or EOC board is the problem
Jan 30, 2017 | Kenmore Ovens
I can't use my oven it keeps turning off and my oven is beeping and the problem light is flashing how can I fix this so I can use my oven
Kenmore electric oven keeps shutting off.... ' Sears PartsDirect
www.searspartsdirect.com > Ask an Expert
Oct 15, 2010 - Kenmore electric oven keeps shutting off. ... Can't locate your model number? Use ... hi, i purchased and replaced my etc (#316455420) for kenmore electric range model # 790.9011.2010. i was ... How to use the site (3:58) ...
Frigidaire oven Bake functions randomly beep and shut off ...
Dec 25, 2015 | Ovens
F10 code on a Kenmore self-clean range model #970-6061
Your Kenmore oven has a built-in fault detector. When the oven detects an issue, the display screen on the control panel will flash a fault code. The F10 fault code on your Kenmore oven indicates that the thermal protector on your oven's control unit, or microcontroller (MCU), has overheated. If the MCU overheats, the computer stops all motor functions. Several items on your oven could cause the thermal protector to overheat. Therefore, you must troubleshoot the F10 code to determine why it appeared on your display panel. Instructions 1 Inspect the area around and behind the oven to ensure you did not place the oven next to a source of heat, such as a register vent or other appliance that becomes very hot. If this is the case, you must remove the oven from the heat source to prevent the issue from occurring again. 2 Inspect the oven to ensure all vents on the oven are open and unblocked. This includes heat vents that vent to the outside of the home. Remove any clogs from the oven's venting and check to see if the code reappears. 3 Inspect all of the wiring harnesses that connect to the MCU. Remove the back cover from the control panel with a screwdriver. Look for disconnected harnesses or any harnesses with black residue on them. This indicates an issue with the MCU. Remove the bolts that secure the MCU to the control panel housing and then replace the MCU with a new one. Reconnect all of the harnesses and retest.
Aug 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Digital display is reading F10 and beeping and the oven shuts off after burning Banana Bread I also had smoke coming out the back panel of the stove top
The F10 error code means that a button on the touchpad is stuck.The error code can be cleared by pushing the cancel/off button and if the F10 returns the clock needs to be replaced since on that model the touchpad is part of the clock.
GENE
Sep 23, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Hello- my oven is a kenmore model 790.94224409 and I keeps getting overly hot and shutting off 10 minutes into baking. It beeps and i get a F10 error type code. Every time i open the range door, it...
Sorry to read about your problem, I hope this helps you out.
you have a defective temp sensor
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Kenmore Ovens
My Kenmore oven, model 790, displays and beeps the F10 Fault
June 8, 2010
Same thing happened to mine this morning....cut the circuit breaker for a hour....open oven and let it cool....
mine stopped, finally. Dont know if its a long term fix yet.. but at least it stopped the beeping.
May 06, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
F10 DIsplays on oven and beeps frigidaire oven with flat top
Go to the Frigidaire web site if you don't have the manual and download it. I saw the F errors listed. They even have the electrical drawings.
Apr 08, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Beeping F 10
Hello
Welcome to fixya.com
You r answer to the F10 code is:
The F10 error code indicates a runaway oven temperature. This would indicate that the oven temperature sensor or the electronic control has failed. According to the service manual you need to unplug the range & after restoring power the oven continues to overheat you will need to replace the electronic oven control.
This a job for a hands on tech!
Thank you for trusting us with your questions.
Please remember to leave a solved rating before you sign out!
Thank You
Dec 25, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
280 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
