Question about LG 42LB5D 42 in. LCD Television
Half picture on LG LCD TV
I have a LG LCD TV model #42LB5ZDF and late when I turn it on I only get half a picture. One side of the screen comes in clear while the other is pxelated and streaky. Once the tv warms up - anout 20 seconds, the picture returns to normal
Any idea waht could cause this?
  • ivanhoe68 Dec 28, 2008
    I hav kind of the sam problem but in the left half on the screen it`s grey and on the other half it`s stripes and other strange stuffs, sometimes it vanishes and sometimes it can go on for ours.....
zjut
  • 106 Answers
SOURCE: lcd tv backlight prob
You need to replace the inverter board if you can find the spare part. Otherwise you need to replace the whole lcd panel.
Posted on Jan 01, 2008
SOURCE: No picture after 20 mins on LG LCD Tv
i have a 32" lg hd flat screen an it now does the same thing i got it on boxing day an its not even 5 months old
Posted on May 15, 2008
SOURCE: frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Posted on Feb 28, 2009
SOURCE: I have an LG 42" LCD tv with blurred image on half the screen
lg 42 in lcd tv power button blinks nine times before staying on and has sound but no picture
Posted on Feb 05, 2010
  • 8457 Answers
SOURCE: Half the tv screen goes black randomly,then returns to normal
The Tuner signal board have problems.The board CPU,Chip,have intermitten short.When the chip is completely dead.The tv will get only LED light indicator power only,will not get tv signal pictures.
Posted on Apr 12, 2010
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
LED screen comes on and goes black
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
LG LED TV has no picture (black screen) but still sound ...
Dec 09, 2015 | LG 47LS4500
I have a 37" JVC LCD TV Model # T370HW02 and the left half of the picture if filled with vertical colored lines for approximately 30 minutes after the set is turned on then the picture clears up and s
The problem with your TV is the screen tabs this is where the electronics bond to the screen a technician may be able to fix it with compression pads otherwise it a new screen
Apr 11, 2017 | JVC Jlc37bc3000 37 Lcd Tv 1080p
Half screen is blank 42lg20 or 42lg50 when
This is likely to be the T-con board. If the entire screen glows but you have no picture on the second half of the screen then it is the main board, not the backlight inverter. If the screen is half picture and half gray it is the T-con board.
Replacement of one of the above will fix the issue.
Please rate if this helped :)
Mar 07, 2011 | LG 42LC2D 42 in. LCD HDTV
Feb 04, 2010 | LG 42LC2D 42 in. LCD HDTV
37'' LG lcd tv, no power
I just want to clear things here.
The stand by light will remain on whenever the tv set is turned on by a button on the side of the tv.
Then use your remote to turn on the tv, but wait as it can take 10secs before you get a picture.
Nov 04, 2009 | LG 37LC7D 37 in. LCD HDTV
Lg lcd tv picture goes in and out with "boxes" on the screen
This sounds like the power supply that feeds your back-light is going out. This repair should be done by a qualified technician
Mar 13, 2009 | LG RZ32LZ50 32 in. LCD Television
My LG 37LC55 LCD TV has one half of the screen darker than the other
Is the XD Demo on. This shows half of the screen with the XD picture engine on and the other with it off. Check your picture settings in the menu.
Good Luck
Jan 05, 2008 | Televison & Video
LG 42LB5D 42 in. LCD Television Logo
526 people viewed this question
Computer Repairing
Computer Repairing
