Question about Raymarine E120 GPS Receiver
Raymarine C-120 I have a C-120 that has been back to the shop 4 times for repair. First time the GPS, then the depth finder, next the auto pilot and then last week the screen did a total malfuction. Anyone else having these problems?
  • Anonymous Nov 11, 2008
    dont buy Raymarine they look good but the stuff is **** I have 3 120 screens changed screens 2x one screen is still bad I just lost patience when light level is dimmed ther screen flashes. Raymarine admitted the problem but cant fix it . 25K of ****
    New Friend:
  • 132 Answers
Many are
Posted on Jan 17, 2010
Is there a dvd i can view to learn about the e 120?
I haven't find a dvd seller for this product but you can download the manual from this site :
Nov 21, 2010 | Raymarine E120 GPS Receiver
My depth finder on my E-120 works for a minute or 2 and gets stuck. My tri data also works for a minute or 2 and then the depth portion shuts off with only lines running thru and no numbers. Other portions...
Hi! You will need to reset the unit to work normally. Try this, remove the battery and press/turn the power button for 10secs. while the battery is removed. Put in the battery and turn the unit on and see how it goes. This should reset the system and resolve the problem. Hope this helps and have a good one!
Jun 12, 2010 | Raymarine E120 GPS Receiver
C 80 screen has gone black,cant read infro, Bermuda
If you peer into the screen can you make out anything on it like as if the back lighting is bad? Also it may be set to night mode as well. You can try a factory reset. I have seen their screens go bad from time to time. If none of the above work. Send it in to Raymarine.
Feb 24, 2010 | Raymarine C80 GPS Receiver
Problems talking to autopilot
I think you use the NMEA output to the autopilot .
The plotter shows you only when you have a seatalkconection with a Raymarine autopilot on you Plotter
Apr 06, 2009 | Raymarine E120 Multifunction GPS Receiver
Raymarine C 80 Head up problem
I calibrated my autopilot compass and that resolved the problem. My auto pilot compass was about 100 deg out.
Once i did this the problem was resolved.
Aug 26, 2008 | Raymarine C80 GPS Receiver
Raymarine St 4000 Wheel Drive
i had face with similar trouble
I went to RayMarine Web site and got an ecopy of the manual. Inside there is a 3D Blow up of the inner workings of the Auto Pilot. There are a couple of shear pins inside on the clutch lever. It shows you how to disassemble the auto and replace the shear pins. Total cost was $0.20. It works GREAT now. No more problems. I was also was able to give the inner working a good cleaning and lube. I have a soft copy of the manual if you need it
Jul 24, 2008 | Raymarine St 4000 Wheel Drive E12093
Sea talk failure
Remove all wiring from 4000 head, hook up only 12V, if seatalk fail continues, it is the head. if seatalk fail goes away, hook in instruments one by one until the bad head is found. Seatalk is 12V red, Ground Screen(bare wire) and Data yellow (pulsing voltage). good luck 847-746-0100 John Barry
Jul 14, 2008 | Raymarine A65 Combo GPS...
Rl70c raymarine depth finder problem
fish finder transducer needs to be on before you boot your system. check your hsb cables and termination
Jul 12, 2008 | Raymarine RL70CRC GPS Receiver
Navman 4150 fishfinder
Depth: Could be for a number of reasons, too deep for the sounder - check the manual for it's max depth. Dirty water, sounder unable to penetrate through to the bottom. Weed or other debris covering the transducer. Transducer on a swing mount & being pushed out of alignment then dropping back in once stopped.
Speed: Is the speed readout controlled by a GPS or paddlewheel? If it's GPS, check the power connection of the sounder, may be loose which would also cause the depth to 'drop out'. If it's paddlewheel, you're down to bad connections or faulty unit.
Oct 16, 2007 | Navman Fish 4150sx GPS Receiver
Raymarine E120 GPS Receiver Logo
216 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
