Question about Gaggia Baby Espresso Machine
My Baby Gaggia is about five years old...just shut off. Is there a fuse?
    President:
  • 1,618 Answers
Yes, remove top panel and test all the thermostats one of them tripped.
Posted on Aug 24, 2010
Weak coffee/water flows too fast
you need to take it to a service center as it is still under warranty they should be able to get it fixed for you
Jan 25, 2014 | Gaggia Baby Espresso Machine
Gaggia Titanium: stuck on 'rinse'.
Try first unplugging power cable for five minutes, see if this reset machine.
Aug 20, 2008 | Gaggia Titanium Espresso Machine
Instructions!!!!!!!!!
Check out this site they have a large selection of gaggia manuals.
www.espressotec.com/store/pc/Gaggia-Home-Espresso-Machine-Manuals-12p213.htm
May 04, 2009 | Gaggia Baby Espresso Machine
Problem with steam
I'll take the machine if you are throwing it away:) You have a blown fuse. There are 2 fuses inside the mahine. Uplug the mahine, Pull the top of and locate both fuses. Connect a wire going from one end to the other of the fuse. This will temporarily short circuit the fuse. Now plug the machine in, and test it out. If it works, than that is obviously the bad fuse. If not, try the exact same procedure on the other fuse. My thermal fuse went out and it only set me back $1.98 to fix. Good Luck!
Jan 05, 2009 | Gaggia Baby Espresso Machine
Gaggia blew a fuse
ensure that you have replaced w the same rating of fuse, amp and voltage
also check for a possible broken part or wiring problem that could cause a short circuit
cheers
Sep 15, 2008 | Gaggia Baby Espresso Machine
Baby Gaggia White Color
If you take of the top then you can see the boiler, on the top of the boiler you will see thermostat in the middle on one you will see a little pin, press down the pin to reset.
Jun 29, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Crack in coffee machine
if is a plastic or similar material you can fix whit epoxi glue. is it in two different tube you only have to mix de glue en the hardener. to get very tough stuf. be sure to well preparing surface by sanding to get more grip on surface.you can make littel hole on each side of de crack to get a better grip for the epoxi.
Jun 30, 2007 | Gaggia Baby Espresso Machine
Gaggia Baby Espresso Machine Logo
167 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
