How to get rid of the mold in my Front Load washing machine (Maytag Neptune)? The rubber sealing the door is full of mold. Do you know if I can get a spare part or clean it up? I'm living in Canada
  • Anonymous May 26, 2009
    mold on door seals on front loader
How do I get rid of the L5 flashing on the estimating time remaining?
Posted on May 04, 2008
Mold on rubber seal on Maytag front load washer
this was and is still a common problem with maytag and for the most part all front load washers... make sure if your rubber seal has a hole in the ceter for the drain it is clear and not clooged partially... the only solution really is clean it with a cleaning solution to kill mold and then after each cycle try to leave door cracked so that air gets to boot/seal so that it stays dry....
hope this helps.... maytag actually had a lawsuit over the neptunes and now are owned by whirlpool coorporation due to that law suit and a dishwasher they had that would catch fore... servicer for 18 years now good luck to you
Jan 08, 2011 | Maytag Neptune MAH5500B Front Load Washer
Neptune washer front door seal has black build up
Try pouring a cup full of distilled white vinegar into the soap dispenser drawer while it is filling up on a hot wash. Don't put any washing in, just let the machine go through the full cycle. Repeat if necessary.
You may be able to scrub lightly affected areas of the door seal with a scourer or old toothbrush etc. and something like Jiff. To be on the safe side you should wear goggles and a mask when dealing with black mold.
It may be worth trying a black mold remover available from supermarkets but read the instructions to make sure it is safe to use on rubber if intending to use it on the door seal. If badly affected - the only way to get rid of it - is to replace the door seal.
Nov 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
RUBBER LINER COLLECTING MOLD
I have been struggling with the same issue for a long time. Regular bleach and mold-killing products did not work. But I just tried Clorox "Washing Machine Cleaner" and was amazed. I scraped off the loose mold from the rubber gasket and then painted on the product, which is thicker than bleach. After about 20 min. I scrubbed it down with water and painted a second coat on the tough areas. No more mold. I also ran some through the machine per the instructions for good measure and ran another rinse cycle. I am in no way connected to Clorox, but I am so happy to be rid of this problem. Good luck. <!-- from fixya rte -->
Jul 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
I can't see it but my maytag neptune has moldly smell. How do I get rid of it?
Maytag's solution was to run an empty load using hot water and a cup of bleach instead of soap. According to them you are supposed to do this quite often. If the rubber ring that seals the door gets mold on it you are supposed to use a water/bleach solution and wipe it down with a rag.
Feb 16, 2010 | Maytag Neptune MAH5500B Front Load Washer
My front-loading Frigidaire washer has black mold on the rubber seal. How can I get rid of the mold? And can it be prevented?
Clean with bleach solution and a Mr Clean Magic eraser.
leave the door open to dry out the machine from now on.
Nov 08, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Mold on rubber gasket on Maytag Neptune washer -- how do I get rid of it?
you can not the door boot has to be replaced there is a black commercial one available although unsightly it will not cause any harm
Aug 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Black mold on washer door seal
this is a very common problem with the neptune washers.
use a javex and hot water solution and scrub the rubber boot.
you should also do an acid wash. (hot wash with bleach, and no clothes) if there is mold on the boot it is inside the washer as well.
There is a way to prevent this. when the washer is not in use, hang a small towl on the washer door, and do not close the door.
this will allow for air movement in the washer
May 27, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Black mold on rubber seal
youust replace it, and start from scratch. From day one you have to maintain the boot with Affresh, whipe out water
Nov 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag front loader washing machine. Mould
How old is the washer? Did you try straight bleach on a towel and placed over the "mold" spot for about 5 minutes, be sure to wear gloves. Then scrub with a small brush being careful not to splatter bleach on yourself and rinse well. May need to replace the seal. I always leave the door cracked open after every use to "dry" out the inside and the boot. I also leave the drawer pulled out when not in use for that area to dry out as well. I have never had mold on the door seal of my Neptune washers, only the water holes above the dispenser drawer.
Sep 08, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune
When the door lock fails, there is a part on the electronic control board that fails (resistor burns up). Both will have to be replaced.
Jun 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
443 people viewed this question
Top Washing Machines Experts
