Question about Dryers
I have a Maytag MDE4700A electric dryer. It quit working (turning) but still heated up. I took the cabinet apart and found that the belt was broke. Need some assistance on beginner steps for replacing the belt.
    President:
  • 1,554 Answers
Disconnect power to the dryer then open the door and remove the center screw of each hinge secured to the inner flange of the front panel in the door opening. Grasp the door with both hands and lift the door in the hinge area then draw the door assembly away from the dryer to disengage the hinges from the slots in the front shroud.
Remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the tI have a Maytag MDE4700A - 0537abf.jpgp.
Disconnect the wires from the door switch, sensor bar, and the lamp holder then unsnap the lamp holder wire harness from the front shroud wire retaining clip.
Remove the four perimeter screws holding the shroud and tumbler front assembly to the cabinet. Remove the lowI have a Maytag MDE4700A - 0ec6011.jpg screw at each corner then the top screw on each side.
Pull the shroud and tumbler front assembly out and away from the tumbler while slightly lifting the top cover.
Kneel near the front of the dryer and reach your left hand inside the dryer at 8 o'clock position and your right hand under the tumbler as close as possible to the bloweI have a Maytag MDE4700A - 71aab86.jpgp the idler puller with your left hand and pull the idler upward and to the left.
Slip the belt off the motor pulley and the back of the tumbler then pull the tumbler out of the cabinet while lifting the top cover.
Place the belt onto the outside of the tumbI have a Maytag MDE4700A - a35ef3c.jpgition it 1 1/2 inches in front of the rear baffle mounting screws with the ribbed side facing the tumbler.
Position the tumbler into the rear felt seal and resting it onto the rear rollers then lower the front of the tumbler onto the blower housing.
Kneel near the front of the dryer and reach your left hand inside the dryer at 8 o'clock position and your right hand under the tumbler as close as possible to the blower then locate the belt and create a small loop with your right hand, ensuring the belt is free of twist.
Position the open end of the loop onto the motor pulley with your right hand. Grasp the idler pulley with your left hand then pull the idler upward and to the left to clear the drive belt.
Relax your left hand and allow the idler pulley to rest down onto the belt. Grasp the baffles with both hands and rotate the tumbler clockwise for the belt to align itself.
Reinstall the shroud and tumbler front assembly in reverse of the removal steps. Lift the front inner edge of the tumbler to allow the front of the tumbler to rest on the teflon bearings on the shroud and tumbler front assembly. Check the felt seal to ensure that it is outside the lip of the tumbler.
Secure the top cover with the hold down brackets then push the front panel posts against the clips in the cabinet until it engage.
Insert the door hinge tabs into the slots in the front shroud and secure the hinges with the screws removed previously to complete the procedure.
Posted on Aug 23, 2010
Dryer heats want start
your belt is most likely either off the tract or broken
Sep 08, 2014 | Maytag Centennial 7.0 Cu. Ft. Super...
In my Maytag dryer model SDE305DAYW the heating element works; however, the tumble drum stopped moving. What's wrong?
This sounds like the drum's drive belt broke. But also ensure there isn't a problem with the drive motor. Do you still hear a motor running when you turn it on? If so, you'll need to replace the drive belt.
I hope this helps! :)
Dec 15, 2010 | Maytag HYE3657A Electric Dryer
Maytag neptune dryer model mde3000ayw
you want to start at high limit thermostat or thermal fuse
its white and has two small wires
it sits on the heat tube
it could be black too
it is shaped like a warped ball
and is rather flat
sears has them in stock
ive included the part number to help
307473
Oct 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Dryer will not start again
Check list:
clear vent pipe
dryer clean of lint
blower wheel tight
drum turns freely
fuse tight against heater.
Wires not shorted on high limit mounted above heater
electric bill paid.
Feb 07, 2009 | Maytag PYE2300AY Electric Dryer
Help me install belt on electric dryer
need model and brand of drier
Dec 30, 2007 | Dryers
Dryer drum wont turn
These units use two circuits to operate. It is entirely possible that the circuit breaker for one is open. The breakers are linked units...generally 30-40 amperes. Turn both off and then on.
Dec 20, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
122 people viewed this question
Top Dryers Experts
