Question about Whirlpool Dryers
My dryer has a three wire hook up can i use a four wire cord.
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Posted on Sep 12, 2010
Master_Tech
  • 770 Answers
SOURCE: changing four prong dryer to three prong outlet
use the ground on the machine.....There are 3 wires on the terminal block if you notice there is a grounding strap off the center post this will act as your ground to the machine back in your panel box the center post leads to ground anyway the other 2 are hot leads (240vac) use the 3 post you will be fine. you will be grounded let me know if you have any problems
Posted on Feb 19, 2008
  • 8 Answers
SOURCE: REPLACING POWER CORD
White to center, red on Right, Black on left, Green goes to case or external ground screw.
Posted on Mar 27, 2008
Illeagle
  • 525 Answers
SOURCE: trying to connect dryer cord
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
I don't quite understand what was wired how but the wiring should be as follows:
For a 4 prong plug and matching outlet
1. Black wire on one end terminal of choice.
2. Red wire on remaining end terminal.
3. White wire only, on the center terminal
4. Green wire on the the dryer frame or chassis terminal.
For a 3 prong cord and matching outlet:
1. Black wire on one terminal end of your choice.
2. Red wire on the remaining end terminal.
3. White wire on the center terminal.
Always be certain that the wire in the breaker or fusebox match the wiring of your outlet.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 02, 2008
SOURCE: switching the cord on maytag neptune dryer
I have the revrse problem I moved and mow my 3 prong needs to be changed to a 4 prong how do I manage to keep it working and not eletrocute anyone with the extra cable
Posted on Sep 28, 2008
  • 1122 Answers
SOURCE: hooking up the four prong cord to the dryer
this is the rule of thumb,white always goes on the middle terminal ,the 2 outside terminal wires it does not matter which side they are on,if you can see the red and black wire on the terminal block then match them up,the green wire gets mounted to the cabinet,you should already have a green wire to the cabinet so remove the screw and put both wires there and your done,let me know how you do-mike
Posted on Oct 15, 2008
Four prong cord three prong outlet
Ok this is how you will wire the three prong to the dryer.
You have 2 wires that are gold/brass in color, those are the hot wires.
You have 1 wire that is crome/silver in color, that is the neutral
On back of fryer where you wire it you put the wires on like this right to left Gold/brass hot, silver/nuetral, then the other hot wire.
On back of dryer you will have screws from right to left this color gold/brass, silver/crome, then gold/brass again.
If you do have a 4 wire cord the extra wire is ground and you screw that to the machine body.
Mar 14, 2010 | Roper RGS7646KQ Gas Dryer
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
The plugin on my dryer has the terminals going in a slant. the outlet in my house are straight. what should i do
You can purchase a dryer main power cord that fits the type outlet you have. Some cords are three wire and some are four wire. Here is some information on changing from a three wire to a four wire configuration or vice versa.These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top/left is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the right/bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helped and best wishes.
Oct 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Plug problem
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Oct 01, 2009 | Whirlpool LER4634J Electric Dryer
Convert three pin plug to four pin
Sep 06, 2009 | Frigidaire GLEQ2152ES Electric Dryer
TRYING TO HOOK A 3PRONG CORD WHAT TO MAKE i"m doing it right
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
3 prong 4 prong
Aug 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Changing from a 3 prong to a four prong
grasshopper_2.gifWiring in a new power cord for your electric dryer? Upgrading your electric dryer outlet from the old three-prong to the new four-prong outlet? Well, grab hold of those two large lumps at the base of your spinal cord and let's romp through the wild and wacky world of dryer cords and outlets.
tn_3cord_dryer_terminal.jpgtn_4cord_dryer_terminal.jpgThese two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Jul 23, 2009 | Dryers
Four prong plug to three prong plug
Is the receptacle in the wall a four prong or three prong. You will have to match the cord on the dryer to the wall recepticle. If the wall is four prong the dryer cord has to be a four prong. The green wire with the yellow line, that is on the end of the dryer cord, is a cabinet ground and should be attached to the cabinet of the dryer and making good contact. The other three wires on the end of the dyrer cord attach to the terminal block.
Jul 08, 2008 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
35 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
