Question about Making Memories Folding Paper Trimmer
Can I get a replacement clear plastic ruler for my paper trimmer. the end has broken on mine.
Mine's a bent shaft. I guess only Victa agents can replace/repair the centrifugal clutch or internal broken cable?
not necessarily--- the broken drive cable can be removed /replaced by removing the trimmer head from the shaft at the bottom
undo the clamp and if there is a small screw/ bolt into the shaft undo that as well and pull the head off
the flexible drive cable will slip out
check the ends and they should be square in form
Mostly the cable breaks but occasionally that square section will wear round
slip in a new cable and reassemble
Oct 16, 2015 | Garden
Replacement of starter cord on HC-150 hedger
You may have wrapped it the wrong way. If not, your spring is either broken, the bend on the end which slides into the plastic has straightened, or the plastic spool has broken where it holds the other bent end of the spring.
Nov 07, 2013 | Echo HC-150 COMMERCIAL SERIES HEDGE...
Where can I get a replacement for broken plastic paper grip?
Unfortunately no, the company went out of business quite some time ago, replacement parts are virtually impossible to find.
Nov 07, 2010 | Making Memories Folding Paper Trimmer
Braun Pulsonic model 9595. Trimmer will not close properly. Can I repair this myself?
The trimmer is replaceable and can be purchased as an assembly http://buyitnow64.stores.yahoo.net/brshrese7pul.html You will T-6 and T-8 torx drivers to take apart the head end of the shaver. Using these tools, remove the swiveling head, the hold down cover over the motor assembly, and then pop off the drive arm for the trimmer. Now the broken trimmer assembly can be slid out of the end of the shaver by carefully prying between the case where the on/off button is located and the black trimmer assembly base with a small flat blade jeweler's screwdriver. The new trimmer assembly can then be slid into the case and the shaver reassembled. Just be sure the ends of the retraction spring on the new trimmer assembly are installed over the little chrome retaining lugs for them or your trimmer will not fully retract (my trimmer assembly arrived with the spring ends loose and not retained by the lugs).
Mar 29, 2010 | Braun Health & Beauty
Magiccolor 2350. Paper jamed(paper end only)in
Kindly open the delivery door and back side of the printer. Check the space between metalic roller and the plastic with the help of a pin or something thin like ruler. Probably a pin or stappler might be stuck there just remove it. your printer will work fine. Secondly check that if any plastic is burnt or melt over there if so then use something rough to make it plain.
Feb 17, 2010 | Konica Minolta magicolor 2400 Laser...
Says paper jam but there is none. pixma mp450
Take any paper out of the paper feeder and get a plastic ruler the softer the better lift the top of the printer up so you can see where the print cartridges are now push the ruler down through the paper feed roller be careful because you could break the rollers go from left to right right to left twice and check for any debris once you have done this unplug the printer for about 20 seconds then plug back in and let it reset then try copying or printing a doc and see how you go!
Feb 21, 2009 | Canon Pixma MP450 All-In-One InkJet...
TRIMMER STAYS IN OPEN POSITION
I had this problem, and it was due to the breakage of a plastic part.  If you slide the trimmer open you can see a piece of spring wire beyond the end of the word 'trimmer'.  The broken piece should locate the end of this spring; if it fails then the spring no longer forces the trimmer blade fully shut.  As the trimmer was opened and closed I could see that the spring did not stay symmetrically placed.  I could also see one end of the spring inside the mechanism, rubbing on the surface under the slider - but not the other.
To help with the instructions, let me identify some parts: "A" is the sliding part that your thumb pushes to open the trimmer; it carries the word 'trimmer'.  "B" is the hinged part that carries the trimmer blade itself and the word 'washable'.  "C" is the flexible piece of black plastic that connects A to B and on which the central section of the spring pushes.
To fix, first remove the sliding section A: slide the trimmer open and push a thin screwdriver down one edge of the slider.  Prise the lugs that hold A in place, away from their slots. Disconnect the connector C from the blade part B (gently push the lugs outwards, one at a time). Turn over the slider A and you should be able to see that one or both lugs that are intended to keep the ends of the spring in place, have broken.  (They are on a silver moulding fixed to the underside of slider A).  I fixed both ends in place with some two-part epoxy - be careful not to get glue on the other parts!  Allow to dry completely and reassemble.
Aug 20, 2008 | Braun 9595CC Electric Shaver
Paper tray stuck
On the Brother DPC130C
Take off the back cover, sort of triangular piece of plastic.
Take power cable out, turn the device on its side and look at the back in the centre there is a white piece of plastic lift that up with a ruler or such device lift the white plastic thingo and slide the tray out.
Don't forget to put all pieces back in place before using printer.
Jul 02, 2008 | Xerox Phaser 8200 Laser Printer
Printer won't eject paper correctly
I would try to clean the rollers with a damp rag. I would also recommend a good 'dusting' with some canned air. Pulling the paper out is never a good idea... you can always hit cancel to release the paper. If this printer is used in an office, I would put a little reminder on it for others. Hope this helps!
Sep 15, 2006 | HP OfficeJet G85 All-In-One InkJet Printer
Making Memories Folding Paper Trimmer Logo
Top Making Memories Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Making Memories Measuring Tool and Sensor Expert? Answer questions, earn points and help others
