Question about Refrigerators
Would the compessor become hot if the compressor start device is broken?
  • 6,784 Answers
Not necessarily. When a compressor overheats, It is usually the cause of the coils being covered with filmy thick lint, thus, preventing the heat dissipating effect that is very important for proper compressor function. A broken condenser coil fan will also overdrive the compressor, thus, causing it to overheat and shutdown. The compressor cannot start when the start device has failed. In this case, the relay has failed mechanically and there may be some isolated heat in the area of the start relay device. You can pull that start device off the compressor and shake it. It will normally rattle if it is damaged.
Posted on Aug 22, 2010
When the tank is empyt the compessor comes on with no problem and runs until it's full, once pressure gets low the compessor should automaticly come on and refill, that"s when the compessor comes...
Hi mcfadden21...
Check and clean or repair or replace your compressor's unloader valve.
The unloader valve is suppose to discharge the compressed air from the tops of the piston heads to the outside to make it easy for the compressor to start when the pressure in the tank drops to the starting point.
Please take time to rate me thumbs up
Sep 15, 2011 | Air Tools & Compressors
It doesn't cool, and in freezer side its collecting water, and also water dripping in the refrigirator .
If this is happening while compressor is running normally , first check temperature of condenser coils (black tubing)while running. If hot to touch,compressor is ok.(Good news)If not hot ,it's shot,or your defrost heater stuck on.(not likely)
If compessor not coming on at all it could be a control problem.eg thermostat ,or stuck defrost timer.
If compessor wants to come on or you hear clicking ,suspect start relay or start capacitor.
hope this helps
Aug 15, 2011 | Whirlpool ET8WTKXK Top Freezer...
My compressor is working but my moter having loaded & burn i change another motor the same problem is happening. please guide me. thanks
The motor will run hot/overload if wrong size or too long cord is used. Also if pressure is set too high (most set at 125 ~ 135 at shut-off). In-tank checkvalve will also have effect on motor by loading the compressor at start-up. Easy test. Run compessor till you have over 100lbs in tank then unplug from power. At this point try to turn the motor /pump by hand, it should turn rather/very easily (this test is hard to do if the motor /pump is completely enclosed, you need to be able to turn the pump even if by truning the fan blade). If it does not turn easily let all the air pressure out of tank and then try to turn by hand. If it turns easily with tank empty try one more test. Run compessor till the pressure switch turns it off. Then unplug machine and turn compessor again by hand, should be easy. If not easy then unloader / checkvalve not working. The checkvalve could be leaking air back from the tank loading the pump. Replace parts as needed.
Apr 01, 2011 | Puma Air Tools & Compressors
I just put a new pressure switch on but when i fill the tanks the compressor wants to empty the air and it tries to kick back on to fill back up with air and some times it kicks and drawls a load on the...
Air leaking from tank back into compessor is indication that in-tank check valve is leaking. This condition will stress motor when trying to start. Test : With air in tank, unplug compressor from outlet and remove hose from compressor at checkvalve and test for leak (soapy water). If leaking drain air and remove checkvalve. Examine checkvalve for debris under seat (resurface seat or replace valve). Parts are at www.toolpartsdirect.com Good luck
Mar 10, 2011 | Hitachi EC12 145 amp 2Horsepower 4Gallon...
Compessor is running hot, fan is not running
need to know brand and model. which fan was replaced ( evap or cond ) . if evap fan it may be the door sw as some model only run fan wth door closed. if it's the cond (fan) motor then ck wiring at compressor . or borken wire. in or about the compresser area .. hope thes help . mm
Jul 05, 2010 | Refrigerators
Smoke at compressor
Your start relay is mostlikey burning up.
Unplug the machine.
Remove the back panel.
There is usualy a black box with wires going to the compressor. take the black box off . it might not have a box and has a wire holding a device on it with a wire. This is the start device. Remove it carfully and inspect it. Yours might be burned up.
A new one might or might not repair your problem.
You might need a new compessor, But is worth trying a new start device.
On all post please provide : Model number and make of machine. and all information about the problem.
Help up Help you :)
Jan 09, 2010 | Refrigerators
Mistral mss20 split a/c only cooling somtimes 4 about 10 m then
Sounds like your unit may be a bit short of refrigerant and the compressor is therefore cutting out on low pressure.
Jan 24, 2009 | LG Art Cool LA1000PR Air Conditioner
Chest freezer
do you have voltage at the compressor? if not you have an open circuit or bad t-stat. if voltage is present and compressor is not running you have a bad start device or bad compessor. if voltage present and compressor runs you have a refrigeration issue get a new freezer.
Jul 17, 2008 | Whirlpool 14.8 cu. ft. Chest Freezer...
We have a roof top mount cetral heating & air unit and its a day& night unit it will blow air out but not cold air .went on top of roof to check condencer and it is hot and coils are normal...
sounds like the compessor over load is cliking on&off compressor not starting could be a capacitor or compressor or if your lucky a contactor dan
Jul 13, 2008 | Heating & Cooling
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
