Question about Canon SELPHY CP780 Thermal Photo Printer
Film unraveled now cartridge stuck - Canon SELPHY CP780 Thermal Photo Printer
APS film chamber stuck shut. Door won't open when film chamber release button is pressed
Sorry to hear about this issue. If you have a change bag, I would put a few jewelers screwdrivers in it then put the camera in it. With the bag closed up I would attempt to forcibly open the back. With the camera in the bag there is not any chance to expose the film. After the film is removed wind it back into the cartridge. Now send it off for developing.
Good luck,
Cordially,
May 03, 2014 | Minolta Vectis S-1 35mm SLR Camera
Rewind button stuck
Is there film in the camera? If it is then in a dark closet or change bag open the camera remove the film then manually rewind the film into its cartridge. Once the film is in the cartridge now you can look at the inside of the camera in the light, you should be able to get the rewind to work.
Jan 14, 2014 | Canon EOS Rebel G 35mm SLR Camera
Film cartridge is stuck on #3
either the camera is broken or try putting new film in. sometimes the film gets jammed because they are old
May 24, 2011 | Polaroid OneStep AutoFocus Instant Camera
Odd shaped smudge every 2 1/4 inches on left side of every copy about 3/4" in from left side of paper. Replaced cartridge and still have problem.
A repetitive defect at 2.2 inches indicates a bad fuser hot roller film. This is the teflon coated plastic film that covers the heating element and assists in bonding toner to the page. It will require replacement, unless you can see that something is stuck on the film., however in most cases based on the age of the printer you will likely need to replace the film.
May 06, 2011 | HP LaserJet 1300 Printer
I installed new correction tape, but there's too much play in it. It keeps unravelling. I have no idea how to tighten it up. When I turn the take-up spool, it just unravels it more without tightening...
Verify that you have installed the proper correction tape. The types of tape that can be used with this system are: Item 1030 - Correctable Film Ribbon, 1230 - Correctable Film Ribbon 2pack, 1031 - Multi Strike Ribbon, 1032 - Nylon Ribbon, 3010 - Lift-off correction tapes (to be used with 1030 and 1230 ribbons), 4010 Cover-up Correction tape (to be used with 1031 and 1032 ribbons).
Make sure that the correction tape is installed properly. Pass the tape through the left guide, behind the ribbon guide and out through the right guide. The rough side of the tape should face the platen. Attach the feeder spool to the pin on the left. Attach the take up spool to the pin on the right. Turn the take up spool counter clockwise until a small amount of tape has wound around it. Replace the cassette ribbon and close the case cover. Press [CODE] + [RESET] to move the carrier to the previous position.
Dec 27, 2010 | Brother ML-100 Typewriter
The film magazine stuck in the Canone EOS 10 camera, never happened that before, i could easily insert and remove the film. it's rewinded, luckily, but I need a new one to put there, + I'm afraid if I...
Nikon N75 or Canon EOS 10????????
How is the film stuck? Is the rear door stuck? Does the film door open?
As long as you do not damage the film canister, the film will be ok. If the door opens and the film is rewound, use something to pry out the top of the canister from the camera. Then you can remove the film.
Even a film roll of 36 should not get stuck. Check the cartridge are for anything sticky. Sometimes these older cameras get some sticky residue from decaying foam in the shutter area. This would be a good time to send it in for CLA - Clean, Lubricate, Adjust.
My own EOS 10 had that problem. If you can't get the film out, the repair shop will do that for you.
Jan 20, 2010 | Nikon N75 35mm SLR Camera
4250tn print black spot
You either have a bad spot on the drum or a bad spot on the fuser rollers. Replace the cartridge first. If spot continues, take cartridge out and get inside with a flashlight. You'll probably find a piece of paper stuck to a roller.
Apr 04, 2009 | HP LaserJet 4250n Printer
Stuck remaining exposure count despite new film, new film unlded
You might try closing the film compartment without film in it and press the manual rewind button. This might reset the counter circuit.
Dec 08, 2008 | Kodak Advantix 2100 Auto APS Point and...
Cd stuck
Take a paper clip and unravel it. Insert the paper clip into the small hole located on your CD player. The tray should eject.
Aug 04, 2008 | HP Pavilion zd8000 Notebook
Photo ink cartridge stuck
I had the same issue. Don't try to force the cartridge out though. After being stuck to the paper, tearing the remainder of the film won't get all of it out of the cartridge. You'll need to print a 'dummy' page to get the last bit to be pulled out and afterwards the printer will automatically release the cartridge allowing it to be pulled out normally.
Apr 21, 2008 | Canon SELPHY CP720 Printer
Canon SELPHY CP780 Thermal Photo Printer Logo
106 people viewed this question
old marine
old marine
