Question about Toys
Just go a 1974 or 1975 lionel santa fe double diesel# 08294 and would like to know how to hook up the power
maklean
  • 1665 Answers
SOURCE: Hyundai Santa Fe diesel crdi
Check exhaust emission control system and catalytic converter.
These items have been integrated into a highly effective system which controls exhaust emissions while maintaining good driveability and fuel economy.
Posted on Jun 24, 2008
tabiri1
SOURCE: hyundai santa fe 02 diesel
my 2001 hyundai santefe won't start. I diagnosed it and had this code, P0340 camshaft position sensor mulfunction, I checked the wiring system, replaced the cam sensor, but still keep having the same code. can anybody help me out?
secondly there is no current to the injectors. What do i need to do
Posted on Feb 11, 2009
SOURCE: hyundai santa fe 2003 diesel difficult starting ok
CHECK INJECTOR LEAKAGE
COMMON FAULT WITH BOSCH INJECTORS
Posted on Feb 22, 2009
  • 9 Answers
SOURCE: I know my santa fe, and i started listening a horrible humming
what kind of noise? if rattling noise and noiser when you accelerate, either in idle position or while moving, then you need to overhaul. if high pitch sound and noiser when you accelerate, then check you bearing in timing belt mechanism
Posted on Nov 22, 2009
  • 880 Answers
SOURCE: where can I find an owners manual for a 2002 Hyundai Santa Fe
Here is the site.
http://www.pdfee.com/2002-hyundai-santa-fe-gl.html
Posted on Mar 05, 2010
How do I drain Santa Fe fuel tank
Put your key back in your pocket! Don't run the engine ! https://www.mynrma.com.au/blog/2015/03/27/wrong-fuel-woes-how-to-save-on-unwanted-repair-costs/
http://www.motorama.com.au/blog/servicing-tips/how-to-fix-petrol-diesel#.V-Yq_fl97IU
http://www.autofuelfix.com/blog/petrol-in-a-diesel-car-guide-and-videos
Call a mobile car repair service to advise you on emptying car as it can be an ******* to drain the fuel out as where do you get rid of the fuel
Sep 24, 2016 | 2011 Hyundai Santa Fe
How to replace the front light on a lione santa fe train engine
From the Lionel User Guide for this engine.
it forward to release the two rear clips from the frame slots.
2. To remove the lamp, gently push the lamp down and turn counter clockwise to disengage
the lamp from the socket. Refer to Figure 6.
3. Replace the expired lamp with Lionel part no. 600-0363-300, available from your local
Lionel Authorized Service Center or Lionel Service. (For more information, see Lionel
Service on page 12.)
4. To reinstall the shell, first insert the rear tabs on the body into the slots on the frame. Line
up the screw holes on the frame and body shell, and reinsert the screw. Make sure all of the wires are inside the body before you tighten the screw.
This is a 14V bulb
This
Mar 14, 2014 | Lionel Santa Fe Diesel Locomotive Engine...
Lionel f7 only runs in reverse
Have you checked to see if the direction switch is on? Most Lionel locomotives can be set to run in one direction by turning the direction sequencing off. This is true for the newer electronic direction circuits and the older electromechanical E-units. Sometimes the direction units fail and the locomotive will only go in one direction or sits in neutral. If that is the case, the direction unit will need to be serviced (mechanical type) or replaced (electronic type). Go to Lionel.com for additional information and help.
Mar 03, 2014 | Lionel Trains Santa Fe Flyer Freight Train...
Lionel o guage santa fe steam engine locomotive won't reverse even with reverse switch on?
You do not specify which Santa Fe steam engine you have, but I am going to guess it's the Santa Fe RTR O27 set...
Here's a link to the manual for it. Go to page 9, read the last paragraph on the page. It may be the answer to your problem
.http://www.lionel.com/media/servicedocuments/71-1900-250.pdf
Hope this helps.
Jan 05, 2013 | Lionel New Haven Freight Train Set
My brand new Sante Fe "O" guage quit running in the forward direction after about 15 minutes on Christmas Eve. I took it to the dealer and was treated rudely by the repair person. I was accused...
If sounds like something is wrong with circuit board that controls direction. If it is new it should still under warranty. Find a decent repair shop from Lionel and bring it in.
Feb 01, 2011 | Lionel Santa Fe Diesel Locomotive Engine...
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
Looking to fit power chip. Where is diesel rail
on top of the injectors,alloy tube about 15" long
Jul 15, 2010 | 2007 Hyundai Santa Fe Limited
NO POWER ON COLD START UPS AND BLACK SMOKE COMING
are you letting the igniter heat up before starting it?
Apr 21, 2010 | 2007 Hyundai Santa Fe Limited
Toys Logo
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
