Question about Dryers
Amana Lga80aw.the automatic feature has not worked for 3 years or better. for that it would run fine except the timer wouldn't move. so we ahve been using it in timed dry...now when you start it the burner lights and burns for maybe 5 minutes and shuts off.....then it will try to light and the ignitor glows as it should for maybe 15 seconds and then shuts off. i figured the first problem is with the electronic board in the panel compartment.....This may be too, what do you think??
  • 1 more comment
  • jameskrantz Aug 22, 2010
    Its clean..... I am really wanting to fix the problem with not re-lighting.....
  • jameskrantz Aug 23, 2010
    does this cause the burner not to be able to re-light???
    Yes!!! this is what I wanted to know!!! Good work...... If i knew which capacitor it was I'd replace it too!! thanks!
  • Dryers Master
  • 8,220 Answers
The way that gas assembly work is power from a cold klixon mounted on the blower housing goes to the gas assembly. All of the coils the ignitor and flame sensor are energized at once, The coils won't open unless the resistance in the circuit changes. With the flame sensor and ignitor out of the circuit AND the ignitor screaming hot the coils now have the means necessary to yank open the gas gates. Amana Lga80aw.the automatic feature has - d8a68de.jpg6fd88ce.jpgThe raw gas hits the ignitor and Ka-whoosh we have ignition. So if he ignitor is glowing it is ok and if the ignitor shuts down after it gets hot then the flames sensor is working. That means the coils must be getting intermittent and quitting with a little age on them. Replace those coils Amana Lga80aw.the automatic feature has - 9f412cc.jpgl be well. 9f412cc.jpgYour dryer has strips that wet clothes rub against inside the front under the filter. That means you have an electronic drying control board. Wet clothes are electrically conductive. With electronic sensing dryers as the wet clothes tumble, they touch the two metal bars in the drum. (Auto dry dryers utilize a system of cycling the timer motor with the element, and has nothing to do with how wet the clothes are by the way.) There is a capacitor on the control that is trying to build up a charge, but when wet clothes create a short from one bar to the other, this charge is released to the frame of the dryer, therefore discharging the capacitor. As long as the capacitor charge is low, the control knows the clothes are wet. As the clothes become dryer, they short the bars fewer and fewer times. Once the capacitor charge builds to a certain level, the control knows the clothes are mostly dry, and it advances the program to the final timed portion, usually less than 20 minutes, some of which is a cool down portion to reduce wrinkling. If your dryer is shutting off after only 10 minutes, that means the control capacitor is never getting discharged. This can be due to a few different reasons: 1. Sensing bar wire is disconnected or broken; 2. Load is not large enough (remember the bars must be contacted repeatedly); 3. Bars are "coated" by fabric softener build up and need to be cleaned with Windex or 409. 4. Defective control board. 5. Airflow is restricted and moisture can't escape the drum. 6. Corrosion built-up on sensing board connection.(yank out tAmana Lga80aw.the automatic feature has - 94c4018.jpgd clean the contacts that sometimes is all it takes) 94c4018.jpgAddress the airflow condition and load size. Clean the sensor bars and make sure the wires are all connected securely.
Amana Gas and electric dryer service manual
Rate it or Hate it:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 23, 2010
  • 10,319 Answers
Do this first.. remove the exhaust vents and clean thoroughly. the moister sensor detects lint build up. Try it after cleaning it out
Posted on Aug 22, 2010
  • frank thomas wilson
    frank thomas wilson Aug 23, 2010
    then the moister sensor is at fault if the lint is completely cleaned out
I have an Amana Designer Series Gas Dryer. It worked fine for more than 10 years. Suddenly, yesterday it still ran, but there was no heat. I opened the bottom panel while it was running, and...
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Sep 22, 2011 | Amana ALG331RAW Gas Dryer
I have an amana model lga80aw that I need a belt diagram. Anyone have one?
Hi and welcome to FixYa, I am Kelly.
See this link for all Amana Dryer belt routing and note the direction of the belt ribs:
http://www.repairclinic.com/Dryer-Belt-Diagrams#DiagramA
Thanks for choosing FixYa,
Kelly
Feb 20, 2011 | Dryers
We have an Amana dryer Model #LGA80AW that squeals when the dryer is running. Sometimes it only makes the noise for a short time, other times a little longer. Could it be the belt?
It has a shroud with glides on the front and rollers in the rear.
I have a manual and photos here
It is one of my latest tips. If it is helpful give it a rating for me would you? Thanks.
Sep 02, 2010 | Amana Dryers
TIMER ON WASHER MAKES A TICKING SOUND DURING CYCLE
HI, this timer is faulty and, these are early warning signs of potential failuer of this device in the near future. i would prepare to replace the timer control soon. the actual mechanism is showing signs of breakdown.
May 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Will a 6 speed tranny listed for a '89 thru '96 fit an '85.
Dude that tranny is a classic my brother has one while I have the automatic.if you have a stock 35000 mile AND THE TRANNY IS FINE,I WOULDN NOT SCREW WITH IT.i HEAR IT IS EASEIR TO DROP AN AUTOMATIC OF THE SAME YEAR.I BELIEF YOU MAY HAVE TO CHANGE ALL THREE SHAFTSAND ADD MOUNTS TO MAKE IT WORK
Dec 03, 2008 | 1985 Chevrolet Corvette
Amana Refrigerator ARS9167AB Ice Crush does not produce ice at all.
either the switch is bad that moves the selection from crushed to whole ice or the ice crushing motor is out
Oct 28, 2008 | Amana Refrigerators
Whirlpool gas model LGC8858EQ1 dryer works fine except the timer does not move.
ckd for wire from thermostat on rear of blower or high limit might be easier to look at wiring diagram wire is usually orange they have been known to come off voltage is feed to timer motor during auto setting from a thermostat
Jul 30, 2008 | Dryers
Refrigerator will not get cold, but freezer works
Do you know if the compressor in the back is running? If you can check that out get back to me and we can go from there. Most times if the fan in the freezer is running the defrost timer is ok.
Jul 09, 2007 | Amana ARSE66MB Side by Side Refrigerator
Dryers Logo
105 people viewed this question
Top Dryers Experts
