Question about Dryers
Dryer starts the fire but after a moment it stops
  • Steve Tobey Aug 22, 2010
    Maomarin85 --
    What is the Make/Model of your gas dryer? There are a number of safety systems to prevent severe problems. The Flame sensor and Over-Temp sensors are most likely problems. Please write back with more information about your dryer. -- SWT
    President:
  • 1,554 Answers
This is a clear indication of a gas valve solenoid coil failure. One or both of the gas valve solenoid coils work when cool but fail when they get hot. These coils are located sitting on top of the gas valve assembly, one with three prongs while the other has two.
Replace both coils and it should address the problem. Remove the front panel then the bracket securing the solenoid coils and then pull the coils out. Slide the new coils in then secure them with the bracket. Indicate the complete and exact model number of the dryer for detailed and complete replacement procedure.
Click on the link below then check if it applies to your dryer.
http://www.fixya.com/support/t5689834-need_replace_valve
Posted on Aug 23, 2010
The dryer works ok until it is hot then stops. start it again it runs a for a shorter time and stops. the hotter, the shorter the time before it stops.
Your upper limit switch is kicking in to stop a fire from happening.
Switch could be bad and need to be replaced , but first try less expensive options:
Could be a bend or blockage in the exhaust tube. That would keep the temp too high in the dryer.
Clean out the exhaust pipe frequently to prevent a common cause of house fires. With luck that is your problem.
Also check the lint trap. If you open the dryer, check for lint that got past the lint filter too.
Jul 05, 2016 | Bosch Dryers
Igniter Works, but Gas won't fire up on Sensor Dry, Will on Timed Dry
PLEASE do not use this dryer until it is fixed. it may be a saftey hazard. From the sounds of it. Your ignitor is only getting a signal every now and then. Now either is a coupler in there to tell the ignitor when to fire and when not to fire. It seems that it is going out only alloweing the dryer's ignition to come on only when a new cycle is started. That is where i would start... check with an appliance repair shop and find out if it will be something you can do your self or if it is something they have to do....
Now I do STRONGLEY recomend that you have a service technicion come on and service your dryer do to the fact that it is a GAS dryer. if something inside the dryer where to get pinched or broken it could cause a bigger problem....
so please take this advisment under consideration....
Thank you.
Aug 04, 2008 | Whirlpool GGX9868J Gas Dryer
It works very well get to a moment stops then you press button depart and goes but if you take your finger from depart button it stops again
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 17, 2011 | Dryers
Dryer won't stay on
The motor centrifugal switch is not switching from the start winding to the run winding. The switch should stay in the run winding when the motor picks up speed unless power to the motor is interrupted or cut off. The switch is replaceable on most dryer models but sometimes it is an integral or built-in part of the dryer motor and failure of the switch requires the replacement of the motor. Indicate the exact model number of the dryer for more accurate troubleshooting and repair advice.
May 24, 2010 | Kenmore 63932 Electric Dryer
Dryer shuts off right after started
You don't mention the model or make of dryer but this problem is usually due to a small component in the machine called a thermal overload switch. This switch stops the dryer when the elements get too hot. However, it often malfunctions and turns off the dryer the moment you use heat settings. The overload switch is inexpensive and should easily be found at your local appliance dealer.
Best wishes,
Graemevm
Dec 17, 2009 | Washing Machines
Dryr starts to crank up than just stops and wont turn on any more
Hi there, this is motor failure. the actual motor windings are in bad condition at this moment. they are separating and this can ultimately start an electrical fire. the automatic shut off prevents the fire form occurring. you will have to remove the motor and tanke it to an electrialc motor shop for a re thread.
Feb 17, 2009 | Whirlpool GGX9868J Gas Dryer
Start but will not stay running
Some dryers have a broken belt micro switch mounted where a lever will stop the motor from getting into the run mode. They do this to keep the heater from catching fire. If your dryer is a DOT dryer (dryer of tomorrow) made by maytag for kenmore then it certainly has such a switch. If your dryer is a plain jane whirlpool manufactured one then you needs a motor replacement most likely friend. Sowwy.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 29, 2009 | Kenmore 63942 Dryer
Dryer stops after a few minutes of a full load.
You will have to replace the moisture sensor. The heat from the small fire may have damaged it. It's not that hard to do, but the part costs @$60.
Dec 16, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer starts and then quits
You have a faulty heat safety switch. This switch prevents the dryer from overheating and causing fire. Some dryers have as many of 4 of these switches (seems redundant but it prevents fire) Depending on how confident you are with repairs the back of the dryer can be removed and the switches can be replaced. Most of them are circular and are found along the dryer exhaust area. I do recommend that this repair be done by a professional if you do not have allot of experience yourself because of the safety factors involved. Good Luck!!!
Nov 07, 2008 | Kenmore 63932 Electric Dryer
Dryer Problem
Grinding noise most likely due to the front drum bearings worn out - result is the metal drum making contact with the rim of the from panel.
This requires a total disassembly of the dryer to investigate & likely replacement of the front slipper pads (dry nylon slipper bearings 4 x ).
This will only be a succesful repair if you stopped using the dryer the moment it started screeching.
If you have let it run, the metal-on-metal will have gouged the edge of the drum and will rip up any new replacement bearing pads.
Do not attempt this unless you are a very competent handyperson. Many screws lost, cut fingers and swear words will ensure if you are not confident in approaching this job, so either toss the dryer or get a competent repairman to do the job.
Mar 18, 2008 | Fisher and Paykel Dryers
Dryers Logo
55 people viewed this question
Top Dryers Experts
