Question about i-mate JAMin Smartphone
Sd card not working on imate jamin says - sd card not installed.
Reformatted card, still does not work. card works elsewhere. please help
  • sanj981 May 21, 2008
    my imate jamin does not detect any sd cards that i insert into the top.
    the card is fine, it can be read on other imate phones.
Hi I had the same problem and posted under sanj981, my phone was over a year old so had built up alot of dust and over the conectors, etc.
I simple used a new soft brissled paint brush to dust the inside of the memory card slot gently. also did it by moistening the brush with electronic circuit cleaner (available from hardware stores), left the imate to dry with battery removed for about an hour, turned it on and inserted the card and it worked.
be careful not to get too much cleaner liquid in the slot, it will drip down and go under the lcd screen. it will then take a few days to evaporate.
Posted on May 24, 2008
Hi Experts, Could you please help me with SD Card
Usually, and not to say this is going to solve your problem. I have always experienced when moving sd cards from device to device, most are not hot swapable. Meaning that you would have to format your sd card to make it work in your other device. NOTE; This will erase ALL data on the SD card.
Nov 24, 2009 | i-mate JAMin Smartphone
Gprs setting on imate jamin.
Download imate-configurator from the imate website.
Go to: http://www.imate.com
  1. Enter your country name
  2. Select "Support"
  3. Select "Device Support"
  4. Select "Your Phone"
  5. Select "Patches"
  6. Download i-mate configurator
install the cab file in your device, the settings will automatically be done.
You may then connect to the internet.
Please rate if this helps you...
Jul 22, 2009 | i-mate PDAL Pocket PC
How to reset imate jamin password?
You can try with hard reset, i am not sure if it will work : keep pressed volume - , on/off button and reset button( from the bottom side of the device) for a few seconds
Jul 18, 2009 | i-mate JAM Pocket PC
How do i reset my imate jamin password.forgot password
how do i reset my imate jamin password.forgot password
Jun 21, 2009 | i-mate JAM Pocket PC
My imate jamin wont read any sim card
Mate...same thing happen to me. I put in 3 different sim cards which all work on my other phone. So, try fiddling with the plated contact on the sim card holder (lack of other term for it). I just raised the contacts a bit, making sure there is good contact between the sim card and the leads. Works fine now. Good luck.
PS
be careful not to raise the pin to high or the pins might snap.
Mar 09, 2009 | i-mate JAMin Smartphone
Imate jamin mobile
hi thanks for using fixya!!
You may install programs to your Imate by using ActiveSync, just install first your activesync to you computer and then after the successull installation of the Activesync, connect your Imate to your pc using usb cable, then click activesync from your pc then it will automatically prompt you for your preferred activesync settings.
Then on installing programs, if you have the program in you pc just click the program to run and then it will automatically install it to your pc and PDA, but if you want it to install directly to your PDA, you should copy the program using activesync to your PDA, just save the prorgam file to the internal memory or to the sd memory and then from your PDA you may install it smooth and easy.
If you do not the activesync you may download Here
If you need further, let me know!
Please rate my simple solution positively! thanks!
Jan 31, 2009 | i-mate JAMin Smartphone
No sound, no outgoing call jamin imate
I dissambled my iMate JAMin and found that one of the wires for the speaker had been broken, they seem to be pretty weak - resoldered the wire now speaker works fine.
Jan 28, 2009 | i-mate JAMin Smartphone
I mate Jamin
I have had the same problem with my jamin and most of times soft resetting it via the button at bottom solves it. If it happens regularly, you might want to hard reset it. please make sure you backup your data and settings etc
Oct 09, 2007 | i-mate JAMin Smartphone
Imate Jamin Sync problem
Hi Alwyn, i had the same problem & had to reinstall everything & then it worked. However it does revert back to giving the same error code from time to time. I think its coz i bought my imate jamin from a firm in sydney over the internet. When i got it, it had no mms settings on it [i later discivered it was an 'import' so i had to delete all its software & reinstall everything from software off the net]. I've been through hundreds of dollars trying to solve this problem [i originally thought it was my desktop soo i bought a laptop to synch with & it did the same]. You just need to persist in re-setting up the bluetooth when it does it but remember to cancel all previous bluetooth settings. I'll never buy an expensive phone off the net again - i'd prefer to pay $1000 from a shop rather than $900 of the net & have these problems.
Jan 11, 2007 | i-mate JAMin Smartphone
Computers & Internet Logo
259 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
