Question about Sport & Outdoor - Others
I bought a Nordic Track Walk Fit manual treadmill at a garage sale. It is missing the belt that goes around the 'pulley wheel' at the side. I thought it would be a matter of going to the Nordic Track website, but nothing comes up on their site when I enter the Walk Fit name. Where can I get a belt for this machine? The model number has been torn off but the date it was made was January 1995.
  • karynlh Aug 25, 2010
    Thanks, but no help. I am not looking for the walking belt but for the belt that goes around the flywheel and the tension bar. I could not find it on this site either. Any other suggestions?
  • 1,675 Answers
Hi this site will help you find what you are looking for..just click link and it will take you there hope this helps please rate thanks
http://www.treadmilldoctor.com/Products-Services2/nordictrack-treadmill-belt
good luck
Posted on Aug 23, 2010
I have nordictrack A2105 and although we "oiled" the belt and replaced motor belt, it still slips. What are we doing wrong?
remove the hood. Turn the treadmill on to speed of 4 or 5 and straddle the walk belt. While the treadmill is running (with good shoes on) step hard on the walkbelt while observing the motor belt and front roller belt pulley. Does just the belt or front roller stop? if so the belt is loose. If the belt does not stop check to see if the front roller stops and the front roller pulley keeps going. If so the front roller pulley is slipping on the roller. If the belt, pulley and front roller are all moving and the walkbelt is the only thing that stops when stepped on then the walk belt is loose. To repair a slipping front roller you have 2 options: 1) purchase a new roller assy or 2) loosen the motor belt and push it to off to the side of the front roller pulley (no needto remove). Realign the roller pulley to the motor pulley. You may have to tap it into alignment. On the inside section of the grooved part of the pulley drill an 1/8" hole thru the pulley and thru the roller housing. (If you drill to the outside portion of the pulley on the left hand side you will hit the roller bearing. Now take a larger drill bit like a 3/8" and lightly countersink the plastic pulley - try not to drill thru the pulley with the larger bit. Using a thin head sheetmetal screw, install the screw so the head is just below the ribbed surface of pulley. If you screw up your first attempt just rotate everything 90° and try again.
Nov 11, 2014 | Nordic Track Nordictrack A2105 Treadmill...
Drive belt replacement
start by putting the new belt on the front roller and then put on the motor pulley bottom. its going to be tight so just try to start it and then roll the pulley around with ur hand until it gets on the pulley
Mar 26, 2014 | Nordic Track NordicTrack Treadmill, A2550
NordicTrack Classic Pro Skier has a noisy pulley
1) LUBE the deck belt inmediately, maybe you have now a WORN deck belt time to replace.
2) LUBE the rollers bearing TOO.
3) test the voltage input motor, if there are the motor NEED repair
God bless you
Oct 14, 2012 | Nordic Track NordicTrack Classic Pro Skier
How to fit new console to nordic track c2500
Locate the Reed Switch (10) and the Magnet (7) on
the left side of the Pulley (8). Turn the Pulley until the
Magnet is aligned with the Reed Switch. Make sure
that the gap between the Magnet and the Reed
Switch is about 3 mm (1/8 in.). If necessary, loosen
the Screw (27), move the Reed Switch slightly, and
then retighten the Screw. Reattach the Hood (not
shown), making sure the screws are in the same holes
from which they were removed. Run the treadmill for a
few minutes to check for a correct speed reading.
Nov 03, 2011 | Nordic Track NordicTrack Treadmill, A2550
Nordic track treadmill stuck on highest speed
Adjusting the speed sensor:If the calibration does not pass you may need to check the speed sensoralignment.1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 09, 2011 | Nordic Track NordicTrack Commercial 1500...
Nordic track treadmill stuck onfull speed
GOOD LUCK.SINCERELY
Need manual for nordic track walk fit 5000 1995 manual treadmill, also resistance belt. and where do batteries go for digital readouts?
I can't help with the manual. But, if you reach under the area where the readout is, push up on the cord or any of the opening underneath the display will pop out. You should be able to find the battery compartment. The unit uses 2 AA batteries. If you find a manual, let me know.
Thanks.
Jul 04, 2010 | Exercise & Fitness
Missing a part on the tension belt for a Nordic Track Achiever
Go to Iconservice.com click on manual input Nordic Track Skier their is 47 matches the friction band tensioner should have a clear diagram of that mechanism
May 29, 2010 | Exercise & Fitness
Treadmill goes normal speed until I get on it and then it slows down
When was the last time you placed the correct lubrication between the walk belt and the walk board. This is a very common issue. Make sure you DO NOT use anything from an aerosol can. The acetone will cause the belt to get dry, hard and crack.
Good luck.
Jun 19, 2009 | Nordic Track NordicTrack Treadmill, A2550
Sport & Outdoor - Others Logo
41 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
