Question about Smoothfitness Smooth EVO Treadmill Safety Key with Cord and Clip
I am unsure on how to hook my Direct TV up to my TM. do i have to have another box for it or can i use an existing box of a nearby TV?
  • 294 Answers
Just use a T-splitter and send the 2nd cable over to the machine. Whatever show is on the main TV will show up on the little screen
Posted on Nov 23, 2010
Can I use existing directv service from my house to hook up a tv in my garage 800 feet away
Probably not unless the signal is strong enough to reach the garage. Check with your direct tv service if they have a signal extender (amplifier) that might just do the trick.
Most of those wireless units have weak transmitters good only for close proximity.
Nov 10, 2015 | Pool & Spa
Keep getting no signal on 32 in lg
Start at the beginning:
Hook a DVD to one of the rear sets of audio/video jacks--go to that input and verify it works.
If so, hook the direct TV to another rear input and select that---if no picture that way---the box may be the issue or wrong hookup--composite to composite or component to component (most likely).
If the set works with DVD and not DIRECT TV it is not smart enough to know what is hooked to it.
In that case a setting or the connection out from the box is the problem---check on screen menu for the box in setup.
Box may need to be rebooted with it connected to set or wrong hookup of cables.
Mar 31, 2012 | Televison & Video
BRAVIA KDL-52XBR4 PARTIAL IMAGE DELAY
Three suggestions:
1. Try to hook cable direct without box to see if same problem---ie the box might cause this problem.
2. Check to see if it does it with DVD or when you change active inputs.
3. If number one contact cable provider as box may be your problem.
Mar 11, 2012 | Sony BRAVIA KDL-52XBR4 LCD TV
Hooking up my x-box 360 through Direct TV
Ok i had it installed today too....i already had it so i have experience with it....get a vcr....in th eback there should be some ports for AV cables hook that up and get one of those cords that look like the direct tv cords and put that in you VCR out to tv...and screw it in with your hands in your tv.....when you have your VCR on the direct tv wont show and if your direct tv is on when your xbox and VCR are on it still wont so turn off the VCR to get direct tv back again.....im 13 and i figured this out...hopefully this helps a bit
Sep 26, 2009 | Microsoft Xbox 360 Console
No print sharing. Existing but lder Belkin router has no problems, but WRT54g-TM will not print share. Have a Netgear switch box as well, can I integrate the two or even all three to solve print share...
If you are using a belkin router, wrt54g-tm and netgear switch box. Basically they won share the printing. you need a wireless print server..try the linksys WPS54GU2
Jul 28, 2009 | Linksys WRT54G-TM Wireless Router
Have direct TV, need to hook up sanyo tv to a panasonic DVD.
leave direct tv cables where they are, and hook up dvd player directly to tv (do not hook up dvd player to direct tv box, it will not work)
Mar 15, 2009 | Sanyo Televison & Video
Hooking up converter box when i have a dvd player and direct tv
Hook your Insignia box between your antenna and your television. You still need the antenna.
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
N2750W PROBLEMS WITH DIRECT TV
just press the "PIP" button on the remote it happened to me and i just thought that it looked familiar and i pressed it and it worked hope it helps :)
Nov 19, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Rf modulator for direct tv box
Re: Hiding the direct tv box
Your primary concern with hiding the receiver is how it works with the remote control. By default, Directv remotes use an IR (infared) beam to communicate with the Directv receiver, and this means there must be clear line of sight from the remote to the receiver. However, you can possible use RF (radio frequency) to transmit signals instead. This would allow you to pretty much hide the receiver anywhere you wanted. Currently, standard receivers do not have this capability, but DVRs and HDs do. Contact Directv customer service and ask if you will need to order an RF remote (there may be a charge). https://forums.att.com/t5/DIRECTV-Installation/Hiding-the-direct-tv-box/td-p/4425309
Jan 02, 2018 | Televison & Video
Smoothfitness Smooth EVO Treadmill Safety Key with Cord and Clip Logo
112 people viewed this question
Top Smoothfitness Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Smoothfitness Exercise and Fitnes Expert? Answer questions, earn points and help others
